SM-J120G Reset Screen Lock successfully Welcome to Octoplus Box Samsung software version 3.0.6.0 Card S/N : 00000E47 ----------------------------------------------------------------------------------- To connect SM-J120H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- To connect GT-N5100 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- To connect SM-J120G phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Work ID: 0000000001BA3AC1 Platform: Samsung Android Selected port: COM1 Selected model: SM-J120G Operation: Reset Screen Lock Reset Screen Lock operation for SM-J120G will delete all user data on the phone (contacts, pictures and others)! Connecting to server... Connecting to server...Ok! Checking resource files... Downloading resources... All necessary resource files have been downloaded successfully. Please put the phone into Download Mode and connect USB cable. To put SM-J120G into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Firmware write started. Writing Custom section... Custom section has been written successfully. Reset Screen Lock successfully completed. Performed by 3.0.6.0 Software version. |
