SM J320FN frp lock bypass activation hi,there is a way to bypass fro lock on my samsung j320fn? with octopus box? |
Hello. Please, install the latest Software version then select correct phone model and try to perform Reset FRP operation. |
did you try to pun sim card with pin the tap emergency call? then you can access at the web |
the log is this: Platform: Samsung Android Selected port: COM7 Selected model: SM-J320FN Searching for a phone (waiting for ADB device)... how can I do? |
@spyker10 Which Software version You use ? Please, if You are posting Software log, then post here full log, not only some part of it. Also, please disconnect all other devices from PC, connect phone directly to USB port of your PC, install correct drivers for more detailed instructions, launch Software, select correct phone model, press Help button and read Software manual carefully, after try to perform operation which You need. |
Welcome to Octoplus/Octopus Box Samsung software version 2.3.8 ----------------------------------------------------------------------------------- To connect SM-J320FN phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM7 Selected model: SM-J320FN Searching for a phone (waiting for ADB device)...timeout Phone not found. Operation was failed! Performed by 2.3.8 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM7 Selected model: SM-J320FN Searching for a phone (waiting for ADB device)... the phone must be in recovery mode or not? thanks |
Please, read Software manual carefully: 1.Enable ADB by writing boot.img partition from combination firmware 2.Click "Reset FRP" button. 3.Connect then phone to PC via Micro USB cable. 4.Follow software instructions (prompts). |
Combination firmwares for most models are uploaded into the Support Area ("COMBINATION" folder). |
Try to do it in the next way: 1. Select SM-J320A model in Software. 2. Check "Advanced Mode" option. 3. Select SM-J320FN model. 4. Perform "Write Firmware" operation. You should be able to select necessary firmware partitions (boot.img in your case) after these actions. |
-i select SM-J320A OK - check "Advanced mode" in SM-J320A OK - when afeter i select SM-J320FN the menu move in spreadtrum and in this area advanced mode is not visible and not checkable. how can i do? |
how can I fix this? |
