SM-J700F frp remove failled Welcome to Octoplus/Octopus Box Samsung software version 2.2.4 ----------------------------------------------------------------------------------- To connect SM-J700F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-J700F To put SM-J700F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock..success Resetting EE lock..success Resetting Samsung Account lock..not supported Operation was failed! Performed by 2.2.4 software version ----------------------------------------------------------------------------------- i allready try to downgrade with old binary 5.1.1 but flashing also failled |
Hello. Unfortunately currently no stable solution for FRP lock removal for SM-J700F with new firmwares. Problem with reset of FRP lock can occur if phone has latest firmware. Samsung disabled ability to remove FRP lock in latest firmwares. You can try to use solution suggested by mr.khudda1234 here: http://forum.gsmhosting.com/vbb/f684...46/index2.html Another solution was suggested by mr.calvinpower here: http://forum.gsmhosting.com/vbb/f684...oblem-2080233/ |
both solution not working |
Currently no other solution. We are aware of the issue and searching for a solution. |
