gsm.firmware | 01-10-2017 16:13 | SM-J710F Samsung logo blink then restart again n again after flash SM-J710F Samsung logo blink then restart again n again after flash http://i68.tinypic.com/161yo3b.png
flashing log Code:
To connect SM-J710F phone you have to perform the following steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->More->About Device.
3.Tap on "Build number" 7 times to enable developer options.
4. Go to Menu->Settings->More->Developer options.
5. Turn on "USB Debugging" option.
Selected firmware file: J710FXXU1APE1_J710FOJV1APE1
_KSA_Android_6.0.1.oct
Please put the phone into Download Mode and connect USB cable.
To put SM-J710F into Download Mode, You have to perform the
following steps:
1. Reconnect the battery.
2. Press and hold "Volume-" + "Home" + "Power ON" keys.
3. When phone turns on, press "Volume+" key.
Found phone on
Firmware write started.
Writing BOOTLOADER section...
BOOTLOADER section has been written successfully.
Writing CM section...
CM section has been written successfully.
Writing BOOT section...
BOOT section has been written successfully.
Writing RECOVERY section...
RECOVERY section has been written successfully.
Writing SYSTEM section...
SYSTEM section has been written successfully.
Writing RADIO section...
RADIO section has been written successfully.
Writing CP_DEBUG section...
CP_DEBUG section has been written successfully.
Writing CACHE section...
CACHE section has been written successfully.
Writing HIDDEN section...
HIDDEN section has been written successfully.
Firmware writing successfully completed.
Performed by 2.4.6 Software version. after flash i do wipe/factory reset still same |
