Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 04-18-2014, 17:06   #1 (permalink)
Member: 775704
Thanks Meter: 14
SM-N900L 4.4.2 imei:00000000 repair
SM-N900L 4.4.2 imei:00000000000000,
Enter "*#0808#" number. Select "DM+Modem+ADB". Cannot find driver,Cannot install this hardware
Enter "*#9090#" number.screen show "DIAG CONFIG NOT SUPPORTED"
Old 04-18-2014, 17:11   #2 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 25,453
What devices appear in PC Device Manager when You connect the phone to PC? What driver You can't install?
The Following User Says Thank You to Octopus box For This Useful Post:
Old 04-18-2014, 20:06   #3 (permalink)
Member: 775704
Thanks Meter: 14
driver is ok ! operation successfully , but imei still 0000000000 .
Has been operating for many times .still same
Welcome to Octoplus/Octopus Box Samsung software version
1.5.4
To connect SM-N900L phone you have to perform the
following steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->More->About Device.
3.Tap on "Build number" 7 times to enable developer
options.
4. Go to Menu->Settings->More->Developer options.
5. Turn on "USB Debugging" option.
6. Go to dial window.
7. Enter "*#0808#" number.
8. Select "DM+Modem+ADB".
9. Press Home button.
10. Go to dial window.
11. Enter "*#9090#" number.
12. Set "Diag config" to "USB" value.
13. Restart phone.
14. Press "Read Info" in software.
Platform: Samsung Android
Selected port: COM1
Selected model: SM-N900L
Phone was not found on the selected port!
Searching for USB diagnostic port...
Connecting to phone on COM19
Mode: Normal
Phone model: SM-N900L
Firmware compiled date: Dec 19 2013
Firmware compiled time: 11:00:00
Firmware released date: Jan 13 2014
Firmware released time: 22:42:01
Phone IMEI: 000000-00-000000-0
SW version: M8974A-AAAANAZM-1.0.180102T2
Selected port: COM19
Mode: Normal
Old IMEI: 000000-00-000000-0
New IMEI: 357507-05-000001-0
Creating NVM backup
Reading NVM done!
Connecting to ADB, please waite...
Firmware compiled date: Mon Mar 17 20:43:31 KST 2014
PDA version: N900LKLUENC3
CSC version: N900LLGTENC3
SW version: N900LKLUENA8
Phone IMEI: 000000000000000
Phone SN: RV1D956TFKR
Android version: 4.4.2 (KOT49H)
Cheking Root
Erasing old IMEI. It can take some time. Please wait...
Reading security backup, please wait...
Backup saved as C:\Program Files\Octoplus
\Octoplus_Samsung\BACKUP\Security-SM-N900L-
000000000000000-19-04-2014_02-58-15-.asec file
Phone will restart now. Please don't disconnect cable!
After phone being rebooted and powered on perform the
following steps:
1. Disconnect USB cable.
2. Wait for 1-2 minutes.
3. Connect phone via UART cable to the Box.
Serching phone...
Phone found.
Writing new IMEI. Please wait...
Please connect phone to USB cable and press OK button.
Serching phone...
Found phone on COM19
Repairing NVM for SM-N900L phone...
Repairing 3G/4G...
3G/4G repair successfully
IMEI successfully repaired.
To finish the operation, please restart the phone via
phone's menu (don't disconnect the battery!)
Mode: Normal
Old 04-19-2014, 11:10   #4 (permalink)
Member: 1146942
Sonork: 100.1587278
After of which actions, phone's IMEI has become 00000000000000?
Please do the next:
1. Close Octoplus Samsung Software.
2. Delete all files from folder "c:\Program Files\Octoplus\Octoplus_Samsung\LOG\".
3. Run Octoplus Samsung Software.
4. Re-start the phone.
5. Perform "Repair IMEI" operation again.
6. Read EFS backup ("Read EFS" button in Software).
7. Read Security backup ("Read Security" button in Software).
8. Close the Software.
9. Upload somewhere the latest created "*.log" and "*.logx" files from the folder "c:\Program Files\Octoplus\Octoplus_Samsung\LOG\", upload read Security and EFS backups and post here links, we will research, where can be the problem with your device and write You the result.
Old 04-19-2014, 11:50   #5 (permalink)
Member: 775704
Thanks Meter: 14
OK, but "Read EFS" and "Read Security" button no-response . the V1.5.4 software has a bug? only read NVM and self backup the Security-SM-N900L-000000000000000-19-04-2014_18-27-54-.asec
log and nvm down here http://pan.baidu.com/s/1o6Lk2Zg
Old 04-21-2014, 02:29   #6 (permalink)
Member: 775704
Thanks Meter: 14
Old 04-22-2014, 08:28   #7 (permalink)
Member: 1146942
Sonork: 100.1587278
We have prepared and sent You test Software version to PM. Please try to repair IMEI with this Software and write here the result.
Old 04-23-2014, 02:17   #8 (permalink)
Member: 775704
Thanks Meter: 14
I tried again and again, can not download,
The customer has to get the phone
Wait for the next update. thanks !
Old 04-23-2014, 06:39   #9 (permalink)
Member: 1146942
Sonork: 100.1587278
We have sent You new link to PM, please, check.
Old 05-07-2014, 12:55   #10 (permalink)
..::Thanh_gsm::..'s Avatar
Member: 207400
Sonork: 100.1582556
Thanks Meter: 261
Hi, how to root N900L 4.4.2? Thanks.
Old 04-17-2015, 19:36   #11 (permalink)
faisal jee's Avatar
Member: 882981
Sonork: 161363
Thanks Meter: 291
please tell me
Old 04-17-2015, 19:57   #12 (permalink)
Member: 1146942
Sonork: 100.1587278
Try to root the phone with latest versions of Towel Root, VRoot, IRoot, or Kingo Root Software.
Old 04-20-2015, 12:40   #13 (permalink)
faisal jee's Avatar
Member: 882981
Sonork: 161363
Thanks Meter: 291
i try but not success
another way
Old 04-20-2015, 14:49   #14 (permalink)
Member: 2087065
Sonork: 100.1660973
Thanks Meter: 30
Samsung Roots..
Check Here Dear..
How-To: Root SAMSUNG SM-N900L (kot49h.n900lklufnk1) 4.4.2 |
Free download Kingo Android Root
Good Luck...
Qais Khan Swati...
The Following User Says Thank You to Qais Khan Swati For This Useful Post:
Old 04-23-2015, 12:36   #15 (permalink)
faisal jee's Avatar
Member: 882981
Sonork: 161363
Thanks Meter: 291
Originally Posted by Qais Khan Swati View Post
thanks to reply
but no success
another way?
Page generated in 0.36992 seconds with 7 queries
