08-24-2014, 12:44 | #1 (permalink) |
Freak Poster Join Date: Apr 2012
Member: 1746056 Status: Offline Thanks Meter: 20 | samsung galaxy nexus i9250t unlock problem..... it's android version is 4.3 . so can i flash it with i9250 imei repair for octopus? Last edited by Octopus box; 01-21-2015 at 14:39. |
08-25-2014, 06:49 | #3 (permalink) | |
Member: 1746056 Status: Offline Thanks Meter: 20 | i9250t unlocking problem... Quote:
----------------------------------------------------------------------------------- To connect GT-S7582 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#7284#" number. 8. Set "UART" radio button to "MODEM" value. 9. Set "USB" radio button to "PDA" value. 10. Press "Save and Reset", phone will restart. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9250T Unlocking phone... Put phone in bootloader mode by pressing "volume up" + "volume down" + "Power button. Searching for a phone. Please wait... Phone found. Unlocking bootloader... Bootloader unlock successfully. Writing fast boot... Fastboot write successfully. Phone will restart now, plaese wait 1-2 minutes Searching for a phone. Please wait... If divece not connect after power on do next step : Go Settings/Developer_options/ and choose USB debugging. Phone found. Firmware compiled date: Fri Nov 15 19:24:23 KST 2013 PDA version: Unknown CSC version: Unknown SW version: Unknown Critical error has encounted. Error message: List index out of bounds (2) after that set reboot from bootloader condition and stuck on startup logo google. but when i remove battery and power on it,set norally power on. | |
08-25-2014, 07:03 | #4 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | As You can see from this Software log, all firmwares parts are damaged in your device: Quote:
Please try to make Repair EFS, then re-flash the phone. Currently we have no firmwares for GT-I9250T, try to re-flash the phone with firmwares for GT-I9250. | |
08-25-2014, 07:17 | #5 (permalink) | |
Member: 1746056 Status: Offline Thanks Meter: 20 | i9250t unlocking problem.... Quote:
and i did not flash any firmware in this set till. and one more thing i wanna know by you that if i flash it by i9250 imei repair file 4.0.1,than this firmware can brick my device? | |
08-25-2014, 07:21 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | We have not tried to re-flash GT-I9250T with firmwares for GT-I9250, so, we can't say You exactly, whether will not be any problems with the device after writing firmware. You can try to write firmware by your own risk. |
01-21-2015, 14:19 | #7 (permalink) |
Freak Poster Join Date: Sep 2006 Location: Tamil Nadu I.N.D.I.A
Member: 352189 Status: Offline Thanks Meter: 131 | Sir Same Error Here Welcome to Octoplus/Octopus Box Samsung software version 1.8.0 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9250T Unlocking phone... Put phone in bootloader mode by pressing "volume up" + "volume down" + "Power button. Searching for a phone. Please wait... Phone found. Unlocking bootloader... Bootloader unlock successfully. Writing fast boot... Fastboot write successfully. Phone will restart now, plaese wait 1-2 minutes Searching for a phone. Please wait... If divece not connect after power on do next step : Go Settings/Developer_options/ and choose USB debugging. Phone found. Firmware compiled date: Fri Nov 15 19:24:23 KST 2013 PDA version: Unknown CSC version: Unknown SW version: Unknown Critical error has encounted. Error message: List index out of bounds (2) any solution to unlock this phone???? |
01-21-2015, 14:33 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Do the next: 1. Delete all files from the folder "c:\Program Files\Octoplus\Octoplus_Samsung\LOG\". 2. Take out SIM and SD cards from the device. 3. Install the latest Software version (Drivers). 4. Run the Software. 5. Make Factory data reset and wipe cache partition. 6. Try to make Unlock again. 7. Close the Software. 9. Upload somewhere the latest created "*.log" and "*.logx" files from the folder "c:\Program Files\Octoplus\Octoplus_Samsung\LOG\" and post here the links, we will research, where can be the problem with your device. |
01-21-2015, 15:54 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Ok, we will research, where can be the problem and say You the result. |
01-22-2015, 09:54 | #12 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | We need also Security backup from this device. Try to do the next: 1. Root the phone. 2. Connect it as GT-I9500 and try to read out Security. 3. Post here full Software log with Read Security operation. Then we will say, what to do the next. |
01-22-2015, 14:19 | #13 (permalink) |
Member: 352189 Status: Offline Thanks Meter: 131 | Sir can't read security.. Platform: Samsung Android Selected port: COM30 Selected model: GT-I9500 Warning: Selected model (GT-I9500) differs from the detected one (GALAXY NEXUS)! If you want select (GALAXY NEXUS) as (GT-I9500) model, please check "manual select". Reading security backup, please wait... Reading security failed. |
