01-09-2016, 17:44 | #1 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Root tunnel Age: 36
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | sm-n7505 lollypop write cert failed Code: Welcome to Octoplus/Octopus Box Samsung software version 2.1.6 ----------------------------------------------------------------------------- To connect SM-J700F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------- To connect SM-N7505 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-N7505 Selected file: I:\shani\samsung\CERT ime\CERT ime\cert\SM- N7505_352832060301298_R58F70XSFM.cert Detected phone model: SM-N7505 Firmware compiled date: Mon Nov 23 21:46:55 KST 2015 PDA version: N7505POUDOK2 CSC version: N7505OXADOK2 SW version: N7505XXUDOK4 Phone SN: R38F20XCX5N Android version: 5.1.1 (LMY47X) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Executing exploit... Writing Certificate failed |
01-11-2016, 09:15 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please do the next: 1. Install the latest Software version. 2. Make Factory Reset and reflash the phone. 3. Repeat "Write Cert" operation. Post here result and full Software log of the operation. |
