11-23-2016, 01:00 | #1 (permalink) |
Freak Poster Join Date: Sep 2012 Location: Minneapolis MN USA
Member: 1815016 Status: Offline Thanks Meter: 77 | G928T 2.4.4 Remove Screen Lock MAJOR PROBLEMS Selected port: COM3 Selected model: SM-G928T Connecting to server... Connecting to server...Ok! Checking resource files... Resource files already downloaded. Please put the phone into Download Mode and connect USB cable. To put SM-G928T into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Firmware write started. Writing Custom section... Custom section has been written successfully. Reset Screen Lock successfully completed. Performed by 2.4.4 Software version. BUT... ALL data has been erased from phone and storage also now shows as only 8 GB instead of 32. WTF????? |
11-25-2016, 21:56 | #3 (permalink) | |
No Life Poster Join Date: Sep 2005 Location: Cali Colombia Age: 43
Member: 181405 Status: Offline Thanks Meter: 249 | hello Quote:
1 Download combination file 2 write firmware combination 3 factory reset 4 now write stock firmware now you have 32GB again | |
11-26-2016, 08:26 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,418 | Hello. Unfortunately new reset Screen Lock method removes user data. Currently this is the only way for phones with new firmwares. We'll try to improve the solution in future. |
11-26-2016, 18:52 | #6 (permalink) | |
Member: 1815016 Status: Offline Thanks Meter: 77 | Quote:
Flash TWRP --> issue adb command --> flash stock recovery. Easy. I can do that manually myself - still works on new firmwares. Why not do that - revert to old method? At least remove new method or give warning about data loss. | |
