SM-T585 Reset FRP question [Solved] can someone help me to reset frp on sm-t585 with firmware T585XXU3BRF1 securty bit3 please help me with complete procedure if some one was unlocked frp with this firmware |
I tried with latest combination and reset. I also tried with boot.img from latest combination and no solution I will let you know if anything works. |
Okay found a solution Just downgrade. Just downgrade from XXU3 to XXU2 combination file. Run FRP reset UFS and flash normal firmware. |
i think not possible to degrade from sec.3 to sec.2 are you try this or you sugest me to try? |
If you have any better method please inform. I already tried U3 combination full firmware then normal firmware oem unlock method. I also tried boot.img method. UFS method on U3 combination. I tried combination file adb method. None working except this one. Thanks |
pls help me name of file u2 u use to dowgrade |
Whats name of file need, just search U2 Combination .....and after flash U2 in Binary U3 have phone Stuck in "Failed Binary version". |
to allumts have u find solution for bypass t585 u3 , try combinew , sboot , uart ufs fail all tks so much |
Hi there and welcome to everybody! I manage to bypass FRP on the T585XXU3BRF1. So what I did: 1. Flash T585XXU3BRF1 2. Flash COMBINATION_FA60_T585XXU3ARG1 3. Flash system img only from T585XXU2APL4 4. Factory reset 5. Go to dev options and tick oem unlock. 6. Factory reset and FRP is off:) Thanks |
tested and working 100 % thanks again |
for t585 8.0.1 xxu4crj8 frp? |
http://forum.gsmhosting.com/vbb/13441927-post69.html |
not work.after I wrote the combination this COMBINATION_FA60_T585XXU4ARJ1 becouse allumts is t580 and not write done. I did frp reset and reset factory .after I wrote flash without hidden, cache, recovery, user data frp still on. how should I do? |
