06-02-2017, 11:50 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,418 | Hello. Please post here full Software logs of all operations, which You've performed with the phone. |
06-02-2017, 12:33 | #3 (permalink) |
Freak Poster Join Date: Aug 2014 Location: kolkata
Member: 2234421 Status: Offline Sonork: 100.1674816 Thanks Meter: 60 | here is log sir https://www.4shared.com/photo/2bC6RNGYei/gggg.html i cannot upload image allways failed so image link is above |
06-02-2017, 12:48 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,418 | "SW version: unknown", "HW Modem: unknown" - this means that phone has damaged modem part. This can be Software (modem firmware or EFS is damaged, or You have written unsuitable firmware) or HW problem. You should re-flash the device with different firmwares one by one and check, whether modem is correct (not Unknown). And only then (when phone's modem part will be correct) perform "Write Cert" operation. It is not possible to repair IMEI, if phone's modem part is damaged. |
