Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Search | Today's Posts | Mark Forums Read |
View Poll Results: Is Thread useful | |||
Yes | ![]() ![]() ![]() ![]() | 3,117 | 92.77% |
No | ![]() ![]() ![]() ![]() | 243 | 7.23% |
Voters: 3360. You may not vote on this poll |
![]() | #197 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2011
Member: 1514778 Status: Offline Thanks Meter: 46 | Did you understand the fact that there is no actual CERT file for N900T? Did you read previous posts before asking for this CERT file? Or did you just arived here to ask fo this CERT file? You can't read, i repeat you can't read CERT files from a Qualcomm device, which means you wont get a N900T CERT file, fo that phone you need to use N900 and or N900Q, or N9005 CERT files. The last one im not quite shure but..... |
The Following User Says Thank You to Enelyam For This Useful Post: |
![]() | #201 (permalink) |
Product Supporter ![]() ![]() ![]() Join Date: Apr 2011 Age: 55
Member: 1564612 Status: Offline Thanks Meter: 11,915 ![]() | @Enelyam, You are right, only from Exinos Cpu is possible Read Cert in Qualcomm only Write Cert, (who not know what platform is his phone, "Google" and "Search" button are both good friends), BUT how N900 Cert (Exinos) is possible Read and Write in Any N900X, also G900 Exsinos Cpu is possible Read Cert and Write in all G900X qualcomm. Hope now is all more clear and should help you all. BR allumts |
![]() | #206 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 11,915 ![]() | Quote:
If not explain we cannot understand, not are only you in this forum, BR allumts | |
![]() | #207 (permalink) | |
When is been released Update is write CLEAR that device change Original Imei if use these new procedure, so is only you fault, only with a few $ had unlocked phone and Original Imei. Br | |
The Following User Says Thank You to allumts For This Useful Post: |
![]() | #208 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2006 Location: Bulgaria Asenovgrad Age: 39
Member: 239176 Status: Offline Sonork: 100.1602815 Thanks Meter: 851 | ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM11 Selected model: SM-G900T Detected phone model: SM-G900T Firmware compiled date: Fri May 23 20:23:24 KST 2014 PDA version: G900TUVU1ANE6 CSC version: G900TTMB1ANE6 SW version: G900TUVU1ANE6 Phone IMEI: 353300061708035 Phone SN: RV8F40ESSZW Android version: 4.4.2 (KOT49H) Reading info... Mode: Normal Firmware compiled date: May 10 2014 Firmware compiled time: 03:00:00 Firmware released date: May 23 2014 Firmware released time: 19:41:46 SW Version: MPSS.DI.2.0.1.c2-00055-M8974AAAAANRZM-1 Reading QCN... Send SPC... Reading mobile property... Mobile property read successfully Reading feature mask... Feature mask read successfully Reading roaming list 0 Reading roaming list 0 read successfully Reading NV items... NV items read successfully Reading NV SIM1 items... NV SIM1 items read successfully Reading NV SIM2 items... NV SIM2 items read successfully Reading NV items... NV items read successfully Reading EFS... EFS read successfully Reading provisioning items... Provisioning items read successfully Reading QCN done! Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\QCN-SM-G900T-353300061708035-28-10-2014_13-08- 53-.qcn file Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-G900T-353300061708035-28-10-2014_13- 12-22-.asec file Wiping EFS... ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM11 Selected model: SM-G900T Selected file: C:\Documents and Settings\Home\Desktop\New Folder \Cert-SM-G900F_352558067456393-00000000000.cert Detected phone model: SM-G900T Firmware compiled date: Fri May 23 20:23:24 KST 2014 PDA version: G900TUVU1ANE6 CSC version: G900TTMB1ANE6 SW version: G900TUVU1ANE6 Phone IMEI: 353300061708035 Phone SN: RV8F40ESSZW Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Phone connected successfully Writing new phone IMEI... Writing Certificate failed have a problem |
![]() | #209 (permalink) | |
Product Supporter ![]() ![]() ![]() Join Date: Oct 2009
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 26,057 | As You can see from your Software log, Wipe Security wasn not perfromed completelely: Quote:
1. Install the latest Software version (Software). 2. Take out SIM and SD cards from the phone. 3. Re-flash the phone. 4. Make Factory data reset and wipe cache partition. 5. Make Wipe Security once again. 6. Write Cert again. 7. Post here full Software log with all of these actions. | |
The Following 6 Users Say Thank You to Octopus box For This Useful Post: |
![]() | #210 (permalink) |
Member: 239176 Status: Offline Sonork: 100.1602815 Thanks Meter: 851 | Sucsesful complete thanks for support ! Welcome to Octoplus/Octopus Box Samsung software version 1.7.3 ----------------------------------------------------------------------------------- To connect SM-G900T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G900T Detected phone model: SM-G900T Firmware compiled date: Fri May 23 20:23:24 KST 2014 PDA version: G900TUVU1ANE6 CSC version: G900TTMB1ANE6 SW version: G900TUVU1ANE6 Phone IMEI: 353300061708035 Phone SN: RV8F40ESSZW Android version: 4.4.2 (KOT49H) Reading info... Mode: Normal Firmware compiled date: May 10 2014 Firmware compiled time: 03:00:00 Firmware released date: May 23 2014 Firmware released time: 19:41:46 SW Version: MPSS.DI.2.0.1.c2-00055-M8974AAAAANRZM-1 Reading QCN... Send SPC... Reading mobile property... Mobile property read successfully Reading feature mask... Feature mask read successfully Reading roaming list 0 Reading roaming list 0 read successfully Reading NV items... NV items read successfully Reading NV SIM1 items... NV SIM1 items read successfully Reading NV SIM2 items... NV SIM2 items read successfully Reading NV items... NV items read successfully Reading EFS... EFS read successfully Reading provisioning items... Provisioning items read successfully Reading QCN done! Backup saved as C:\PROGRA~1\Octoplus\OCTOPL~2\BACKUP\QCN- SM-G900T-353300061708035-28-10-2014_13-30-00-.qcn file Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\PROGRA~1\Octoplus\OCTOPL~2\BACKUP \Security-SM-G900T-353300061708035-28-10-2014_13-34- 12-.asec file Wiping EFS... EFS wipe successfully Phone will restart now Searching for a phone. Please wait... Reading info... Mode: Normal Firmware compiled date: May 10 2014 Firmware compiled time: 03:00:00 Firmware released date: May 23 2014 Firmware released time: 19:41:46 SW Version: MPSS.DI.2.0.1.c2-00055-M8974AAAAANRZM-1 Send SPC... SPC send successfully Writing QCN... Writing NV items... NV items write successfully Writing NV SIM1 items... NV SIM1 items write successfully Writing NV SIM2 items... NV SIM2 items write successfully Wrting EFS... EFS write successfully Writing provisioning items... Provisioning items write successfully. Writing QCN done Wipe security successfully complete. Phone will restart now ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G900T Selected file: C:\Documents and Settings\Home\Desktop\New Folder \Cert-SM-G900F_352558067456393-00000000000.cert Detected phone model: SM-G900T Firmware compiled date: Fri May 23 20:23:24 KST 2014 PDA version: G900TUVU1ANE6 CSC version: G900TTMB1ANE6 SW version: G900TUVU1ANE6 Phone IMEI: Unknown Phone SN: RV8F40ESSZW Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Phone connected successfully Writing new phone IMEI... Checking certificate compatibility... Certificate is compatible Writing Certificate... Phone will restart now Certificate has been written successfully Please, restart the phone to apply changes |
The Following 3 Users Say Thank You to delchoni For This Useful Post: |
