Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Search | Today's Posts | Mark Forums Read |
View Poll Results: Is Thread useful | |||
Yes | ![]() ![]() ![]() ![]() | 3,117 | 92.77% |
No | ![]() ![]() ![]() ![]() | 243 | 7.23% |
Voters: 3360. You may not vote on this poll |
![]() | #346 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Dec 2006
Member: 421331 Status: Offline Thanks Meter: 30 | Please any one share cert file for G900M |
![]() | #349 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: May 2005 Location: Colombia
Member: 142645 Status: Offline Sonork: 100.1604204 Thanks Meter: 234 ![]() | i no can write certificate g900m Please i need ..i no can write certificate g900m ..i try several times.. i make full wipes ..helpppp Code: Plataforma: Samsung Android Puerto seleccionado: COM396 Modelo seleccionado: SM-G900M Selected file: C:\Users\sara\Desktop\Cert-SM-G900M_352558068274001.cert Please, press "OK" button on the phone to allow USB debugging.. Modelo del teléfono detectado: SM-G900M Fecha de creación del firmware: Sat May 10 02:45:02 KST 2014 PDA version: G900MUBU1ANE2 CSC version: G900MUWA1ANE3 Versión del SW: G900MUBU1ANE2 IMEI del teléfono: 35255806745xxxx Phone SN: 00000000000 Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Checking Certificate failed Writing Certificate failed |
![]() | #352 (permalink) | |
Product Supporter ![]() ![]() ![]() Join Date: Apr 2011 Age: 55
Member: 1564612 Status: Offline Thanks Meter: 11,915 ![]() | Quote:
How can see in this log you not done ANY Wipe and get failed. Press Wipe Security Button (you mei is all 000000), Write Cert and have done Br allumts | |
![]() | #358 (permalink) |
Insane Poster ![]() ![]() ![]() Join Date: Feb 2006
Member: 227878 Status: Offline Thanks Meter: 3 | Where can I find SM-G900A certificate for AT&T Samsung galaxy S5. I have try factory, restore, repair, write certificate but keep failing. Code: Welcome to Octoplus/Octopus Box Samsung software version 1.7.4 ----------------------------------------------------------------------------------- To connect SM-N900T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-N900A phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM27 Selected model: SM-N900A Mode: Normal Phone model: SM-N900A Firmware compiled date: May 10 2014 Firmware compiled time: 03:00:00 Firmware released date: Jul 21 2014 Firmware released time: 10:28:29 Incorrect IMEI SW version: MPSS.DI.2.0.1.c2-00055-M8974AAAAANRZM-1 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM27 Selected model: SM-N900A Mode: Normal Phone model: SM-N900A Firmware compiled date: May 10 2014 Firmware compiled time: 03:00:00 Firmware released date: Jul 21 2014 Firmware released time: 10:28:29 Incorrect IMEI SW version: MPSS.DI.2.0.1.c2-00055-M8974AAAAANRZM-1 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM27 Selected model: SM-N900A To Repair IMEI of the device, do the next steps: 1. Root the phone. 2. Perform Wipe Security procedure ("Repair Security/Wipe Security" button). 3. Write Certificate ("Write Cert" button). ----------------------------------------------------------------------------------- To connect SM-G900A phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM27 Selected model: SM-G900A Mode: Normal Phone model: SM-G900A Firmware compiled date: May 10 2014 Firmware compiled time: 03:00:00 Firmware released date: Jul 21 2014 Firmware released time: 10:28:29 Incorrect IMEI SW version: MPSS.DI.2.0.1.c2-00055-M8974AAAAANRZM-1 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM27 Selected model: SM-G900A Mode: Normal Phone model: SM-G900A Firmware compiled date: May 10 2014 Firmware compiled time: 03:00:00 Firmware released date: Jul 21 2014 Firmware released time: 10:28:29 Incorrect IMEI SW version: MPSS.DI.2.0.1.c2-00055-M8974AAAAANRZM-1 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM27 Selected model: SM-G900A To Repair IMEI of the device, do the next steps: 1. Root the phone. 2. Perform Wipe Security procedure ("Repair Security/Wipe Security" button). 3. Write Certificate ("Write Cert" button). ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM27 Selected model: SM-G900A Mode: Normal Phone model: SM-G900A Firmware compiled date: May 10 2014 Firmware compiled time: 03:00:00 Firmware released date: Jul 21 2014 Firmware released time: 10:28:29 Incorrect IMEI SW version: MPSS.DI.2.0.1.c2-00055-M8974AAAAANRZM-1 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM27 Selected model: SM-G900A Detected phone model: SM-G900A Firmware compiled date: Tue Jul 22 13:56:34 KST 2014 PDA version: G900AUCU2ANG3 CSC version: G900AATT2ANG3 SW version: G900AUCU2ANG3 Phone IMEI: Unknown Phone SN: R38F41ED7NE Android version: 4.4.2 (KOT49H) Reading info... Mode: Normal Firmware compiled date: May 10 2014 Firmware compiled time: 03:00:00 Firmware released date: Jul 21 2014 Firmware released time: 10:28:29 SW Version: MPSS.DI.2.0.1.c2-00055-M8974AAAAANRZM-1 Reading QCN... Send SPC... Reading mobile property... Mobile property read successfully Reading feature mask... Feature mask read successfully Reading roaming list 0 Reading roaming list 0 read successfully Reading NV items... NV items read successfully Reading NV SIM1 items... NV SIM1 items read successfully Reading NV SIM2 items... NV SIM2 items read successfully Reading NV items... NV items read successfully Reading EFS... EFS read successfully Reading provisioning items... Provisioning items read successfully Reading QCN done! Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP\QCN-SM-G900A-07-11-2014_18-44-37-.qcn file Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-G900A-07-11-2014_18-50-17-.asec file Wiping EFS... EFS wipe successfully Phone will restart now Searching for a phone. Please wait... Reading info... Mode: Normal Firmware compiled date: May 10 2014 Firmware compiled time: 03:00:00 Firmware released date: Jul 21 2014 Firmware released time: 10:28:29 SW Version: MPSS.DI.2.0.1.c2-00055-M8974AAAAANRZM-1 Send SPC... SPC send successfully Writing QCN... Writing NV items... NV items write successfully Writing NV SIM1 items... NV SIM1 items write successfully Writing NV SIM2 items... NV SIM2 items write successfully Wrting EFS... EFS write successfully Writing provisioning items... Provisioning items write successfully. Writing QCN done Wipe security successfully complete. Phone will restart now ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM27 Selected model: SM-G900A Selected file: J:\Firmware\Samsung\SM-G900A\BACKUP\SM-N900A_359092050091226_S200012760.cert Detected phone model: SM-G900A Firmware compiled date: Tue Jul 22 13:56:34 KST 2014 PDA version: G900AUCU2ANG3 CSC version: G900AATT2ANG3 SW version: G900AUCU2ANG3 Phone IMEI: Unknown Phone SN: R38F41ED7NE Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Phone connected successfully Writing new phone IMEI... Checking certificate compatibility... Certificate is not compatible Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM27 Selected model: SM-G900A Selected file: J:\Firmware\Samsung\SM-G900A\BACKUP\Cert-SM-N900-358021058471446-RF1D93A24AK.cert Detected phone model: SM-G900A Firmware compiled date: Tue Jul 22 13:56:34 KST 2014 PDA version: G900AUCU2ANG3 CSC version: G900AATT2ANG3 SW version: G900AUCU2ANG3 Phone IMEI: Unknown Phone SN: R38F41ED7NE Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Checking Certificate failed Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM27 Selected model: SM-G900A Selected file: J:\Firmware\Samsung\SM-G900A\BACKUP\SM-G900H_353415064151122_R51F600P1C.cert Detected phone model: SM-G900A Firmware compiled date: Tue Jul 22 13:56:34 KST 2014 PDA version: G900AUCU2ANG3 CSC version: G900AATT2ANG3 SW version: G900AUCU2ANG3 Phone IMEI: Unknown Phone SN: R38F41ED7NE Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Phone connected successfully Writing new phone IMEI... Checking certificate compatibility... Certificate is not compatible Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM27 Selected model: SM-G900A Selected file: E:\Unlock Application\Samsung\Root SM-N900T\SM-G900H_353415064151122_R51F600P1C.cert Detected phone model: SM-G900A Firmware compiled date: Tue Jul 22 13:56:34 KST 2014 PDA version: G900AUCU2ANG3 CSC version: G900AATT2ANG3 SW version: G900AUCU2ANG3 Phone IMEI: Unknown Phone SN: R38F41ED7NE Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Phone connected successfully Writing new phone IMEI... Checking certificate compatibility... Certificate is not compatible Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM27 Selected model: SM-G900A Selected file: E:\Unlock Application\Samsung\Root SM-N900T\SM-G900H_353415064151122_R51F600P1C.cert Detected phone model: SM-G900A Firmware compiled date: Tue Jul 22 13:56:34 KST 2014 PDA version: G900AUCU2ANG3 CSC version: G900AATT2ANG3 SW version: G900AUCU2ANG3 Phone IMEI: Unknown Phone SN: R38F41ED7NE Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Phone connected successfully Writing new phone IMEI... Checking certificate compatibility... Certificate is not compatible Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM27 Selected model: SM-G900A Detected phone model: SM-G900A Firmware compiled date: Tue Jul 22 13:56:34 KST 2014 PDA version: G900AUCU2ANG3 CSC version: G900AATT2ANG3 SW version: G900AUCU2ANG3 Phone IMEI: Unknown Phone SN: R38F41ED7NE Android version: 4.4.2 (KOT49H) Writing security backup, please wait... Phone will restart now Security write successfully. Platform: Samsung Android Selected port: COM27 Selected model: SM-G900A Selected file: J:\Firmware\Samsung\SM-G900A\BACKUP\Cert-SM-G900H-353285066458472-RF1F42NXP9V.cert Detected phone model: SM-G900A Firmware compiled date: Tue Jul 22 13:56:34 KST 2014 PDA version: G900AUCU2ANG3 CSC version: G900AATT2ANG3 SW version: G900AUCU2ANG3 Phone IMEI: 353411066142193 Phone SN: R38F41ED7NE Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Phone connected successfully Writing new phone IMEI... Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM27 Selected model: SM-G900A Selected file: J:\Firmware\Samsung\SM-G900A\BACKUP\SM-G900H_353415064151122_R51F600P1C.cert Detected phone model: SM-G900A Firmware compiled date: Tue Jul 22 13:56:34 KST 2014 PDA version: G900AUCU2ANG3 CSC version: G900AATT2ANG3 SW version: G900AUCU2ANG3 Phone IMEI: 353411066142193 Phone SN: R38F41ED7NE Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Phone connected successfully Writing new phone IMEI... Writing Certificate failed Last edited by bod; 05-21-2015 at 11:42. Reason: Was a mess |
