04-13-2014, 20:57 | #1 (permalink) |
No Life Poster Join Date: May 2007 Age: 37
Member: 500858 Status: Offline Sonork: 1589054 Thanks Meter: 392 | I9505 4.4.2 imei repair problem |
04-14-2014, 07:12 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please read phone's info (press "Read info" button at "Android / EFS manager" tab in Software) and post here log with this info. We will look and advise You what to do the next. |
04-14-2014, 19:01 | #4 (permalink) |
Insane Poster Join Date: Jan 2012
Member: 1712559 Status: Offline Thanks Meter: 3 | hello me i have this problem Welcome to Octoplus/Octopus Box Samsung software version 1.5.2 ----------------------------------------------------------------------------------- To connect GT-I9505 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Builds numbers" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Close window. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. Selected firmware file: Root_GT-I9505.oct Please switch your phone to the download mode and connect it to a PC. To put GT-I9505 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing RECOVERY section... RECOVERY section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Firmware writing successfully completed. Selected firmware file: GT-I9505_for_Unlock_and_IMEI_repair.oct Please switch your phone to the download mode and connect it to a PC. To put GT-I9505 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing MDM section... MDM section has been written successfully. Firmware writing successfully completed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM87 Selected model: GT-I9505 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM86 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Mar 28 2013 Firmware compiled time: 09:00:00 Firmware released date: Apr 12 2013 Firmware released time: 00:04:45 SW version: M9615A-CEFWTAZM-4.0.17062 Old IMEI: 357506-05-307001-2 New IMEI: 356844-05-057480-6 Creating NVM backup Reading NVM done! Proper android device not found. Make shure that "USB debug" option on the device is turned on. Write IMEI failed can someone help me please ? |
04-15-2014, 13:20 | #6 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Quote:
04-15-2014, 13:24 | #7 (permalink) |
Member: 1712559 Status: Offline Thanks Meter: 3 | Platform: Samsung Android Selected port: COM86 Selected model: GT-I9505 Reading info, please wait... Detected phone model: GT-I9505 Firmware compiled date: Wed Nov 27 22:11:03 KST 2013 PDA version: I9505XXUEMKF CSC version: I9505MBMEMJ5 SW version: I9505XXUFNA1 Phone IMEI: 357506053070012 Phone SN: RF1D616K74P Android version: 4.3 (JSS15J) |
04-15-2014, 13:35 | #9 (permalink) |
Member: 1712559 Status: Offline Thanks Meter: 3 | Platform: Samsung Android Selected port: COM1 Selected model: GT-I9505 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM86 Mode: Emergency ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM86 Selected model: GT-I9505 Mode: Emergency Write IMEI failed |
04-15-2014, 14:10 | #13 (permalink) |
Member: 1712559 Status: Offline Thanks Meter: 3 | so now i do everything step 1-14 i conect in usb debog normally i have 2 port but now i have 3 port i select read info Platform: Samsung Android Selected port: COM86 Selected model: GT-I9505 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM86 Mode: Emergency Platform: Samsung Android Selected port: COM86 Selected model: GT-I9505 Mode: Emergency Write IMEI failed |
04-15-2014, 14:17 | #14 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Contact us right now to Skype or Yahoo! Messenger, we will look what You do incorrectly. Our contacts You can find in our profile. |
