06-28-2015, 10:15 | #1 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Indonesia Raya
Member: 636569 Status: Offline Thanks Meter: 192 | unlock sim lock failed E1205Y with octoplus samsung [Solved] Platform: Samsung Spreadtrum Selected port: COM3 Selected model: GT-E1205Y Selected port: USB To connect GT-E1205Y, perform the following steps: 1. Disconnect phone's battery. 2. Press and hold central button and connect the USB cable. 3. Connect the battery. Connecting... Phone found. Sending mainloader... Mainloader send successfully Unlocking phone. This can take some time. Please wait... Unlocking phone... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-GT-E1205Y_28-06-2015_16-05-03-.nv file Phone unlocking failed ----------------------------------------------------------------------------------- Platform: Samsung Spreadtrum Selected port: COM3 Selected model: GT-E1205Y Selected port: USB To connect GT-E1205Y, perform the following steps: 1. Disconnect phone's battery. 2. Press and hold central button and connect the USB cable. 3. Connect the battery. Connecting... Phone found. Sending mainloader... Mainloader send successfully Reading phone unlock codes. It can take some time, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-GT-E1205Y_28-06-2015_16-05-21-.nv file Read codes failed NV : Security-GT-E1205Y_28-06-2015_16-05-21- - Download - 4shared Last edited by Octopus box; 07-01-2015 at 13:56. |
06-29-2015, 11:12 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,434 | Hello. Please check your PM, we have sent You test Software version. Try to perform "Read Codes" and "Unlock" operation with test Software, then post here results and full Software logs. |
07-01-2015, 11:42 | #3 (permalink) | |
Member: 636569 Status: Offline Thanks Meter: 192 | Quote:
software test ok sir...problem solved and thread closed...thanks sir Platform: Samsung Spreadtrum Selected port: COM3 Selected model: GT-E1205Y Selected port: USB To connect GT-E1205Y, perform the following steps: 1. Disconnect phone's battery. 2. Press and hold central button and connect the USB cable. 3. Connect the battery. Connecting... Phone found. Sending mainloader... Mainloader send successfully Reading info, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-GT-E1205Y_01-07-2015_17-38-22-.nv file Phone IMEI A: 359138-06-013540-2 ----------------------------------------------------------------------------------- Platform: Samsung Spreadtrum Selected port: COM3 Selected model: GT-E1205Y Selected port: USB To connect GT-E1205Y, perform the following steps: 1. Disconnect phone's battery. 2. Press and hold central button and connect the USB cable. 3. Connect the battery. Connecting... Phone found. Sending mainloader... Mainloader send successfully Reading phone unlock codes. It can take some time, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-GT-E1205Y_01-07-2015_17-38-42-.nv file Calculating codes. Please wait... FREEZE unlock code: 53192817 NCK unlock code: 00000000 NSCK unlock code: 00000000 SPCK unlock code: 00000000 CPCK unlock code: 00000000 SIM unlock code: 00000000 Work time: 0:00:05 | |
08-26-2015, 12:33 | #4 (permalink) | |
Junior Member Join Date: Apr 2013 Location: South Africa
Member: 1925069 Status: Offline Sonork: 1638142;tehmoor Thanks Meter: 3 | Samsung e-1205y for sim lock Quote:
Welcome to Octoplus/Octopus Box Samsung software version 2.0.0 ----------------------------------------------------------------------------------- Platform: Samsung Spreadtrum Selected port: COM12 Selected model: GT-E1205Y Selected port: USB To connect GT-E1205Y, perform the following steps: 1. Disconnect phone's battery. 2. Press and hold central button and connect the USB cable. 3. Connect the battery. Connecting... Phone found. Sending mainloader... Mainloader send successfully Reading phone unlock codes. It can take some time, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-GT-E1205Y_26-08-2015_04-26-19-.nv file Calculating codes. Please wait... Can't find NCK code! Can't find NSCK code! Can't find SPCK code! Can't find CPCK code! Can't find SIM code! Work time: 0:00:38 SIR PLZ HELP ME | |
08-26-2015, 12:43 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,434 | Hello. Please write Full flash from the Support Area and repeat "Read Codes" or "Unlock" operation again. |
08-26-2015, 12:46 | #6 (permalink) |
Member: 1925069 Status: Offline Sonork: 1638142;tehmoor Thanks Meter: 3 | PLZ TEAM i have a one problem can u help me about that? please i want some sumsung mondal cert file but when i go to support side i can't do nothing thay just page is blank please sir i am very worry about That plz sir help me plzzzz... |
08-26-2015, 12:57 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,434 | Please, disable your firewall and antivirus, set another browser (not IE), as default browser and try to go into the Support Area again. Write here the result. |
