09-15-2004, 10:48 | #2 (permalink) |
No Life Poster Join Date: Jan 2004 Age: 54
Member: 51154 Status: Offline Thanks Meter: 68 | *#06# IMEI *#2254*# Status register: C,BS,RR,MMI,CREAT *#2255*# activate and deactivate the "DEBUG CALL" -Mode; when activated,make a call to busy line an the phone will display some hex codes on the display *#2558*# the time in days, hours and minutes you are connected to the net *#2562*# not clear; the phone reconnect to the net *#2565*# not clear; warmstart ? *#3333*# (NO) blocking -list (15 items) *#2377*# "BEER" : not cler the phone waits a random time and reconnect to net, sometimes make reset *#3377*# Init , Flags , SIM LOCK *#3353*# reset the (NO) BLOCKING list *#7378*# Name, Lenght,SIM phase *#7489*# Security Code *#7693*# you can activate and deactivate the Sleep Menu (when deactivated the battery will go down!) *#7787*# not clear: Spurious Interrupt *#7948*# Switch Off: not clear: it is a timer or something *#8463*# Some information about the SLEEP MODE: Wake, Sleep Req., Sleep |
09-16-2004, 11:26 | #3 (permalink) |
Junior Member Join Date: Aug 2004 Age: 39
Member: 79307 Status: Offline Thanks Meter: 0 | savvy reset codes hi thanx 4 all the codes, but none of them seem to work on the savvy i hav. the phone is working, and has full signal, but cant make or recieve calls. any other suggestions?? thanx |
philips S200 master reset code | zakariababu | Philips | 0 | 03-26-2006 09:25 |
how to master reset philips 530 | moengage | Philips | 0 | 12-24-2005 13:37 |
Philips Savvy PCK code? | xxxxAngel12345xxxx | Philips | 2 | 02-10-2002 20:36 |
keying in nck code value on philips savvy db | pilcris | Various | 1 | 10-04-2000 20:47 |
Philips Savvy NCK code | Janos | Various | 7 | 08-10-1999 02:45 |
