Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > XTC CLIP
Old 07-14-2011, 18:58   #1 (permalink)
GsmEasy's Avatar
Member: 608359
Sonork: 100.1576815
Thanks Meter: 6,678
What is S-OFF ? Please read and try to understand !
What is S-OFF?
after doing your phone S-OFF, you do set follow functions on factory settings
- sim lock
- hboot lock ( this is the bootloader lock, you will be able flash cooked rom after this)
- cid lock (region lock so you can't flash it with other roms, unbrand it, or downgrade it)
- user lock (will be set to factory default)
- pattern lock (will be set to factory default)
- phone usage counter (helps you refurbish the phone)
Temproot and Permaroot
- What's the difference?
First, let me explain root access. Root access, superuser or su (all the same thing) is basically an admin account for Linux. It gives us permission to to access commands that normally couldn't be accessed, and to write information to partitions that normally couldn't be written to. On older devices (such as the Hero), once we had root we could write to the /system and /recovery partitions, and flash custom ROMs. In the case of the IS (and every HTC device since the desire), this isn't true. Getting root access is quite trivial and no where near as useful, because the internal flash memory (NAND or eMMC) is locked down and it means we everything we 'write' to the system (or any other protected partition) is lost on reboot because it is a non permanent change. In short, this stops us from flashing custom ROMs and recovery. This is a problem for any devices that are shipped with the Security flag on (S-ON). To get Permaroot, and the ability to flash custom ROMs, we need S-OFF.
So what's this S-OFF then?
Making the phone S-OFF with XTC clip, means also that you reset the simlock, userlock and CID to factory state !!! Mean, your phone is100% UNLOCKED
Since the Desire, HTC have been securing their phones better than before by locking the internal flash memory (NAND or eMMC) to stop it being written to, unless the file being flashed is signed by a private key only known to HTC. This is controlled by a flag (@secuflag) and is identified as the device being S-ON. Telling the HBoot the device is Security Off (S-OFF) stops this check for the key, and allows us to write anything to any partition, which is what we are aiming for.
There are actually two levels of S-OFF. The Bootloader (HBoot) and the Radio. Getting S-Off on the HBoot gives us everything we need, but doesn't actually turn off the @secuflag which is set in the radio. What it is possible to do is to flash a HBoot that believes the Radio is set to S-OFF, as the HBoot is responsible for setting that flag. Once the HBoot on the phone is S-OFF, we can write to all the partitions and basically do whatever we want, but it is possible to go one step further. Flashing a radio that is S-OFF and actually setting the @secuflag off gives 100% total access to every part of the phone and it's software, as it becomes network unlocked allowing to you to use any SIM and also allows you to flash a ROM from any carrier (known as Super CID). It also makes it nigh on impossible to permanently loose root no matter what you flash. Once you have radio S-OFF, it makes it much easier to flash new HBoots and ROMs even if you flash something that is locked down tight.
Setting the Radio to S-Off is not necessary, and gaining S-OFF on the HBoot is more than most people will ever need. Radio S-Off is just the last step of the puzzle, but it is worth noting the only points you can permanently brick your phone is flashing a radio or a HBoot, if either of these go wrong you will end up with a shiny expensive paper weight so there is risk involved.
What about this XTC Clip, can that help?
The XTC clip is a hardware device that can unlock S-OFF HTC phones, regardless of the software.
S-OFF created by XTC Clip is temporary or permanent?
You can flash your phone as many times you want, your HTC will remain
S-OFF forever, it is a permanent S-OFF !!!
What about people who are getting devices shipped with S-OFF? There are reports that a lot of devices coming out of China and India are shipping with the @secuflag set off. These are lucky people, and have the ability to write to the flash memory, but it can't help those of us who are S-ON. It is also worth noting that because most devices are S-ON, no one has written any ROMs or kernels for the device so they will probably have to wait until we get a way of turning our devices to S-OFF until anyone creates any software for it.
++++++++++++++++Glossary+++++++++++++++++
Bootloader a.k.a HBoot
- This is the piece of software that runs before anything else on the phone. It basically packages it all up, tells what to run in what order e.t.c Every computer device has a bootloader in some form or another, be it an Android Phone, iPhone, Windows PC, iMac e.t.c. The HBoot is accessible by switching your phone off, then holding down volume down as you turn it back on. The first line of the HBoot will tell you if you are S-OFF or S-ON.
Recovery
- The recovery is the piece of software that allows us to write files to partitions while they aren't being used. It is the portal to allow us to flash custom ROM's and kernels. There are custom recoveries with more options than the stock such as ClockworkMod.
Superuser a.k.a su or Root
- This is a user that is present on all linux distros that allows higher permissions than standard users have access to. Certain apps need superuser permissions to function, such as Titanium Backup.
PS: parts of this FAQ are "taken" from l0st.prophet @ www.xda-developers.com, 10x
Regards,
GsmEasy
The Following 59 Users Say Thank You to GsmEasy For This Useful Post:
Old 07-14-2011, 19:04   #2 (permalink)
Member: 765909
Sonork: 100.1608098
Thanks Meter: 855
thansk for giving nice info
Old 07-14-2011, 19:10   #3 (permalink)
Registered User
Member: 1185007
Thanks Meter: 25
GOOD Job bro
thanks.......................................
Old 07-15-2011, 03:44   #4 (permalink)
Member: 296238
Thanks Meter: 23
Si señores, gracias por la información.
Old 07-15-2011, 04:19   #5 (permalink)
Dami_gsm's Avatar
Member: 1082892
Sonork: 100.1585374
Thanks Meter: 412
good info xtc team but Htc Smart phone not add this is simple fone plz add ...thanks
Old 07-15-2011, 06:02   #6 (permalink)
reeza khan's Avatar
Member: 662751
Thanks Meter: 27
thats great...can u please explain about gold card creation...
Old 07-15-2011, 08:14   #7 (permalink)
visit999's Avatar
Member: 1013130
Sonork: 100.1605132
Thanks Meter: 461
Old 07-15-2011, 14:21   #8 (permalink)
morton1984's Avatar
Member: 720579
Sonork: 100.1591812
Thanks Meter: 40
thats great good jop
Old 07-15-2011, 23:38   #9 (permalink)
Member: 89837
Sonork: 100.1594891
Thanks Meter: 18
thx good job..........
Old 07-16-2011, 20:52   #10 (permalink)
mobilezone1997's Avatar
Member: 1016132
Sonork: 100.1592677
Thanks Meter: 188
hhhmmmmm why xtc clip given this device name?cozz many thing inside this xtc clip which don't have with old xtc clip.why not given this device name xtcking clip!!!
br
roshan
Old 07-17-2011, 17:32   #11 (permalink)
.:::Ayaz:::.'s Avatar
Member: 1403951
Sonork: 100.1586892
Thanks Meter: 213
Soon this model also add and give u boom update cheer GsmEasy
.:::Ayaz:::.
Old 07-18-2011, 00:26   #12 (permalink)
GsmUniversal's Avatar
Member: 649528
Sonork: 100.1590443
Thanks Meter: 6,958
Hi
here is video manual for creating gold card..
http://forum.gsmhosting.com/vbb/7533229-post1.html
GsmUniversal
The Following 2 Users Say Thank You to GsmUniversal For This Useful Post:
Old 07-18-2011, 19:46   #13 (permalink)
KHAMI's Avatar
Member: 1092309
Sonork: 1001606496
Thanks Meter: 52
very helpfull
thank you sir for your lesson.
Old 07-19-2011, 22:45   #14 (permalink)
Member: 649528
Sonork: 100.1590443
Thanks Meter: 6,958
Video Manual About S-Off Working On XTC Clip
link is Here : GSM-Forum - View Single Post - Video Manuals Related With XTC-CLIP !! Check Inside !!
GsmUniversal
The Following User Says Thank You to GsmUniversal For This Useful Post:
Old 07-25-2011, 16:34   #15 (permalink)
naveedbutt's Avatar
Member: 1015336
Sonork: 100.1608410
Thanks Meter: 813
veryyyyyyyy goddddddddd jobbbbbbbbb
The Following User Says Thank You to naveedbutt For This Useful Post:
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-15-2011 13:08
Page generated in 0.24005 seconds with 9 queries
