05-27-2019, 10:50 | #1 (permalink) |
Freak Poster Join Date: May 2010 Location: karnataka
Member: 1313327 Status: Offline Sonork: 100.1650723 Thanks Meter: 11 | dear support team and expert plz help when v shot boot point and hold it for bit long time. as textbox said ic will get burned or damaged my que is which ic will get effected when v use to shot boot point as i have some 3-4 device which r dead .due to multiple time shoting the boot point no light or charging light nothing totally dead .. |
05-27-2019, 14:20 | #2 (permalink) |
Product Manager Join Date: May 2008 Location: Ukraine Age: 45
Member: 772096 Status: Offline Sonork: 100.69222 Thanks Meter: 8,274 | Hello, if you have damaged modems via burn-flash ic, then replace flash ic, but as i know in the 90% modems have dameged Power IC controller. I recomended you set resistor around 100 Om in the BootPoint adapter. The little can help in some case. alligator_clip->wires->resistor_100-Om->needle. (make something like this.) |
The Following User Says Thank You to TestBox2 For This Useful Post: |
