Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > 7ICE Team > Mkey - Modem Unlock Key
Old 01-08-2019, 18:47   #106 (permalink)
TestBox2's Avatar
Member: 772096
Sonork: 100.69222
Thanks Meter: 8,277
Originally Posted by alamgir80 View Post
After unlock 2g not work, 4g signal too weak, cant turn off
wifi extender always its turned on and many more problem.
Selected Applications port COM50
Found modem         : E5573Cs-609
Model               : Huawei AuthVer 4 modem (New)
IMEI                : 861xxxxxxxxxxxxxx
Serial NR.          : 5LL7xxxxxxxxxxxxxx
Firmware            : 21.318.09.00.00
Compile date / time : May  3 2016 21:42:45
Hardware ver.       : CL1E5573CSM Ver.B
Dashboard version   : WEBUI_17.100.15.01.284_MRE5
Web UI version      : WEBUI_17.100.15.01.284_MRE5
SIM Lock status     : unlocked
Wrong codes entered : 0 (unlock attempts left : 10)
****************************/folder/1nt...#kdkcp7kt88bbd
For Mkey dongle users we have some repair firmware files. Another users try find solution yourself.
E5573cs_All_EOL_21.318.99.03.00_21.318.03.00.00_BL _FW_CD_TRIPLE
Old 01-13-2019, 17:49   #107 (permalink)
Member: 198115
Sonork: 100.1591052
Thanks Meter: 15
Originally Posted by .::Gsm-Play::. View Post
Thanks testbox my modem airtel e5573cs-609 unlock done. you are real hero. world 1st solution.
mine is dead after flashing this
pls help
Old 02-28-2019, 12:25   #108 (permalink)
aaditigerhill's Avatar
Member: 1812419
Thanks Meter: 156
After Flash DEAD
Originally Posted by mani_server View Post
After FLash This File DEAD
Only showing Huawei Mobile Connect 3g pc UI Interface
The Following User Says Thank You to aaditigerhill For This Useful Post:
Old 02-28-2019, 13:47   #109 (permalink)
Member: 1812419
Thanks Meter: 156
boot repair error
Old 02-28-2019, 18:57   #110 (permalink)
TestBox2's Avatar
Member: 772096
Sonork: 100.69222
Thanks Meter: 8,277
https://www.sendspace.com/file/4guc6p
E5573CS_21.329.63.00.284_FW.cbin (35.16MB) try use this FW for repair ur modem.
Old 03-07-2019, 21:37   #111 (permalink)
Member: 1156236
Sonork: Simon
How can fix the dead E5573?
Old 03-31-2019, 10:10   #112 (permalink)
Member: 1431024
I want to unlock my airtel Huawei E5573Cs-609 Version: 21.329.63.00.284 with safely, please complete guide me sir
Old 04-01-2019, 19:14   #113 (permalink)
TestBox2's Avatar
Member: 772096
Sonork: 100.69222
Thanks Meter: 8,277
If you have mkey dongke then make unlock via writing patched fw.
All simple.
Old 04-02-2019, 17:35   #114 (permalink)
alirazamanzoor's Avatar
Member: 2562113
Sonork: alirazamanzoor
Thanks Meter: 89
Originally Posted by samsamsolutions View Post
umt pro dongle have solution of dead repair
confired by nck
it can not repair boot , useless .
Old 04-18-2019, 12:56   #115 (permalink)
Member: 2904514
Sonork: z3eem22
hi
Old 04-18-2019, 13:20   #116 (permalink)
Member: 2562113
Thanks Meter: 89
Originally Posted by RABIA57 View Post
hi
Do Not flash Downgraded firmware on Latest sec which have secure boot 1 it check Root CA certificate at boot up time . Use only Operator Fimrware In these types of devices .
it is Emergency Comport but you can not recover it without Signed Bootloader
so,next time flash only operator Firmware only.
Old 09-05-2019, 14:17   #117 (permalink)
RICKY great's Avatar
Member: 641849
Sonork: 100.1619689
Thanks Meter: 44
can you provide jtag pinouts
Old 09-05-2019, 18:31   #118 (permalink)
TestBox2's Avatar
Member: 772096
Sonork: 100.69222
Thanks Meter: 8,277
jtag not found for this cpu. leave it.
Old 10-05-2019, 19:43   #119 (permalink)
Member: 2876006
Request for Re-upload
Originally Posted by balwinder27 View Post
FREE SOLUTION ARTEL E5573CS-60 SOFTWARE VER 21.329.63.00.284
DETECT MODEM IN DC
THEN GIVE AT^GODLOAD COMMND
THEN RUN FILE
AFTER FLASH DONE MODME WILL UNLOCK DONE
Balwinder ji, Can you please check the link / upload the file again ? The link seems to be broken and the file is not available.
Old 12-25-2020, 20:33   #120 (permalink)
Member: 2800096
After Unlock no network problem please shere solution for no service
Page generated in 0.23111 seconds with 8 queries
