12-18-2018, 20:38 | #1 (permalink) |
Freak Poster Join Date: Feb 2006 Location: Egypt-Saudi Arabia
Member: 237354 Status: Offline Sonork: 100.1680909 Thanks Meter: 19 | E5577s-932 unlock Help MKey when I try to flash this is the log on 2 devices 22.35.52 : --------------- Read device information ----------------------- 22.35.57 : DLOADVER : 2.0 22.35.58 : Model : ~*L~ 22.35.59 : IMEI : 123456789123456 22.36.00 : SwVers : 21.200.09.00.76 22.36.00 : IsoVers : WEBUI 22.36.00 : PrdName : BV7R11EC2__0 22.36.00 : DloadType : 1 22.36.01 : Auth.Vers: : 1000 22.36.01 : New HiSi-TYPE 2 Identified. 22.36.05 : Open Flashing Protocol OK.. 22.36.27 : 22.36.40 : --------------- Flash-mode operations ------------------------ 22.36.43 : Download-mode not entered!!! |
12-18-2018, 22:16 | #2 (permalink) |
Product Manager Join Date: May 2008 Location: Ukraine Age: 45
Member: 772096 Status: Offline Sonork: 100.69222 Thanks Meter: 8,276 | Find file on support E5577s-321_21.316.01.00.00_FW_BL_[UntestedBl].cbin and try. or - https://www.sendspace.com/file/yffm8l both fw is untested . about dpownload mode, no idea. try again, or send samples for learn. |
12-18-2018, 22:18 | #3 (permalink) |
Member: 772096 Status: Offline Sonork: 100.69222 Thanks Meter: 8,276 | Also, all operation at ur risk! because i not now what fw are compatible with other. https://www.sendspace.com/file/71580k |
12-20-2018, 14:42 | #4 (permalink) | |
Member: 237354 Status: Offline Sonork: 100.1680909 Thanks Meter: 19 | Quote:
15.40.09 : --------------- Read device information ----------------------- 15.40.14 : DLOADVER : 2.0 15.40.15 : Model : ~žL~ 15.40.17 : IMEI : 123456789123456 15.40.17 : SwVers : 21.200.09.00.76 15.40.17 : IsoVers : WEBUI 15.40.17 : PrdName : BV7R11EC2__0 15.40.17 : DloadType : 1 15.40.18 : Auth.Vers: : 1000 15.40.18 : New HiSi-TYPE 2 Identified. 15.40.22 : Open Flashing Protocol OK.. 15.40.45 : 15.41.03 : SignAuth = Done 15.41.04 : --------------- Flash-mode operations ------------------------ 15.41.08 : Download-mode not entered!!! shall I open and make PIN Points ? | |
12-20-2018, 15:23 | #5 (permalink) | |
16.21.13 : --------------- Read device information ----------------------- 16.21.18 : DLOADVER : 2.0 16.21.19 : Model : ~žL~ 16.21.20 : IMEI : 123456789123456 16.21.21 : SwVers : 21.200.09.00.76 16.21.21 : IsoVers : WEBUI 16.21.21 : PrdName : BV7R11EC2__0 16.21.21 : DloadType : 1 16.21.21 : Auth.Vers: : 1000 16.21.21 : New HiSi-TYPE 2 Identified. 16.21.26 : Open Flashing Protocol OK.. 16.21.48 : 16.22.04 : SignAuth = Done 16.22.05 : --------------- Flash-mode operations ------------------------ 16.22.08 : Download-mode not entered!!! | |
12-20-2018, 15:30 | #6 (permalink) | |
Freak Poster Join Date: Oct 2018 Location: GSMHOSTING
Member: 2869280 Status: Offline Thanks Meter: 112 | Quote:
12-20-2018, 20:00 | #9 (permalink) |
Member: 237354 Status: Offline Sonork: 100.1680909 Thanks Meter: 19 | I opened and make the PIN points and this is the error 20.58.46 : --------------- Read device information ----------------------- 20.58.47 : DEAD Mode Detected = True 20.58.54 : ---------------------------------- 20.58.54 : Init Rom .. 00FF0100000F60100000007F Ok 20.58.55 : ---------------------------------- 20.58.55 : Write Boot .. 00FF020059982057900000C3 Chk. Error! 20.59.12 : ERROR Repair BOOTCORE! |
12-20-2018, 20:28 | #10 (permalink) |
Member: 237354 Status: Offline Sonork: 100.1680909 Thanks Meter: 19 | after use this file E5577s-321_21.316.01.00.00_FW_BL_CD_[UntestedBl] and making pin points 21.17.50 : --------------- Read device information ----------------------- 21.17.55 : DLOADVER : 2.0 21.17.56 : Model : ~žL~ 21.17.57 : IMEI : 123456789123456 21.17.58 : SwVers : 00.000.00.00.000 21.17.58 : IsoVers : 00.000.00.00.0 21.17.58 : PrdName : BV7R11EC2__0 21.17.58 : DloadType : 1 21.17.59 : Auth.Vers: : 1000 21.17.59 : New HiSi-TYPE 2 Identified. 21.18.03 : Open Flashing Protocol OK.. 21.18.25 : 21.18.45 : SignAuth = Done 21.18.46 : --------------- Flash-mode operations ------------------------ 21.18.51 : Verify download mode: 7200B--SKCBADZM 21.18.59 : Detected: [EHUAWEI BV7R11EC2__0] 21.19.06 : HiSilicon CPU mode-3 Selected. 21.19.10 : Write Part1...[FastBoot] Ok 21.19.23 : Write Part2...[M3BOOT] Ok 21.19.39 : Write Part3...[PtableTail] Ok 21.20.00 : Write Part4...[Kernel] Ok 21.20.31 : Write Part5...[VxWorks] Ok 21.21.06 : Write Part6...[M3Image] Ok 21.21.28 : Write Part7...[DSP] Ok 21.22.02 : Write Part8...[NVTable] Ok 21.22.26 : Write Part9...[System] Ok 21.23.25 : Write Part10...[Kernel] Ok 21.24.06 : Write Part11...[CORE] Ok 21.24.28 : Write Part12...[IsoHDR] Ok 21.24.42 : Write Part13...[CDROMISO] Ok 21.25.30 : Write Part14...[WEBUI] Ok 21.27.58 : Restart modem OK 21.28.02 : All done ! 21.28.03 : - Flashing Completed! 21.28.04 : --------------------------- E N D. -------------------------------- but the device is dead not working at all ! |
12-21-2018, 01:18 | #12 (permalink) | |
No Life Poster Join Date: Oct 2016 Location: Developer
Member: 2634133 Status: Offline Thanks Meter: 2,939 | Quote:
****************************/file/ry6j4...2521.cbin/file write this firmware on boot mode after flash done . then repair imei this is a unlocked patched firmware your modem will work ok br-balwinder 27 | |
12-21-2018, 08:32 | #13 (permalink) | |
