10-07-2022, 18:23 | #1 (permalink) |
Product Manager Join Date: May 2008 Location: Ukraine Age: 45
Member: 772096 Status: Offline Sonork: 100.69222 Thanks Meter: 8,277 | FREE "ZXIC" WiseFone Tools for Repair IMEI:MAC:LAN: on Zte/ZLT/Tozed/Wv/MTS end more. ZTE WiseFone "ZXIC" Tools - we have provide fully free for all peoples who work in official Service centers and don't have a support from Chinese suppliers. ZTE WiseFone "ZXIC" Tools - is able to Personalised security and system data after swap motherboard or reprogramming Flash IC through external programmer. In form: [ Read/Write : WiFi MAC,MAC2,Wlan MAC, IMEI, S/N, SSID/WifiKey] Tested in some unsecured models like WV 4G Connect Mini, WV P21 aka Zlt P21 and some other models like ZTE MF920W and similar. Also you can use this software for play with modem through send AT-Commands. Before use ZTE WiseFone "ZXIC" Tools , please make Hard Reset your modem, and after writing details you need make same Hard Reset again. Repair Dead/Damaged modems can do by Hyper-Cheap 5-USD CH341A USB programmer And on the next day i will tell you how to this procedure with fully free software. Unregistered version of ZTE WiseFone "ZXIC" Tools able to read info and use AT-Commander only. If you know valid AT commands, you can make same procedure as written on this tool. Download link: About registration: Contact to me on PM with your S.C. details with Country/City etc.., and write me Hardware Id what you can see on launched software. B.R. 7ICE Team 2022 Future - made by humans. Last edited by TestBox2; 12-24-2023 at 13:37. |
10-07-2022, 18:25 | #2 (permalink) |
Member: 772096 Status: Offline Sonork: 100.69222 Thanks Meter: 8,277 | About modify CH341A USB programmer hardware i will explain you by some simple pictures. About Programmer settings, try use my default settings, or set any SPI NAND - NOR Flash IC , depend from ur device hardware. If use SPI NAND - I tested Read/Write well on WV 4G Connect Mini and MF927U, some friends tested with successed report on - ZLP P21, but if you use SPI-NOR -flash ic, then i recommending you use alternative programer hardware, like USBAasp 5$, with Atmega 8-CPU on motherboard, with reprogrammed by mega8_2.6.hex, because CH341A hardware is very unstable, and cant set USB-.SPI low Speed mode.. Also, about using USBASP for SPI_nand IC from usb wifi modems, request 1.8V TTL Adapter! Drivers download here: NeoProgrammer Software download here: If Diag port in ur modem was closed: try play with Reset button hold-on 30-40 secund, after plug usb cable, hope work. OS: Windows XP or 7 Preffered only! THe most stable system for using USB programming hardware like CH341A or USBASP. Now you can easy repair ur dead/damaged modem with very cheap USB Programmer and can be more happy . B.R. 7ICE Team Last edited by TestBox2; 10-08-2022 at 17:41. |
The Following User Says Thank You to TestBox2 For This Useful Post: |
10-08-2022, 22:09 | #3 (permalink) |
Member: 772096 Status: Offline Sonork: 100.69222 Thanks Meter: 8,277 | Addenium: Some ppls is dont know about how to set new settings for unknow or unsupported SPI-Nand Flash Ic. //--------------------------------------------------------------------------------- As example take datasheet for : Dosilicon-DS35Q1GA-IB.pdf Find next parametersL Voltage, Nand Size, Spare Size. MEMORY CELL ARRAY - (2K + 64) bytes x 64 pages x 1024 blocks Where we do calc total size: (2048 * 64) * 1024 = 134217728 bytes, or 128MB , aka (2048 * 64)=131072kb. Spare area size is: 64 bytes " (2K + 64) bytes " SUPPLY VOLTAGE - VCC = 1.8/3.3 Volt core supply voltage for Exactly vooltage for PN: DS35Q1GAXXX Q: 3.3V, Quad SPI x1/x2/x4 "DS35Q1GAXXX" M: 1.8V, Quad SPI x1/x2/x4 "DS35M1GAXXX" //--------------------------------------------------------------------------------- Example 2: GD5F1GQ4UAYIG.pdf FEATURE ◆ 1G-bit Serial NAND Flash ◆ Program/Erase/Read Speed -128M-byte -2048 bytes page for read and program, spare 64bytes Where 1G-bit = 128Mb. Spare = 64 bytes, -Full voltage range:2.7~3.6V //--------------------------------------------------------------------------------- Next you can select any compatible flash by SPI_NAND type, 64kb Spare and 128Mb Total Nand size, like ZD35Q1GA. So.. this knowledge will be Quilcly and simple. |
10-23-2022, 21:06 | #7 (permalink) |
Member: 772096 Status: Offline Sonork: 100.69222 Thanks Meter: 8,277 | Next Users get free license for Internal Testing : ID: 361C8C180BE268329A7036CBE566 Activated ID: 361CCC180BE26A46DA8D18CB0D71 Activated ID: 361CCC180BE26AC31A7146A3C16E Activated ID: 361CCC180BE27238A21026CC0D87 Activated ID: 361CCC180BE26AB1206E2634CA72 Activated ID: 35E30D171CC260C199D0369CE184 Activated If someone have wifi modem with ZTE ZXIC CPU - Welcome to take free TEST and report log. |
11-03-2022, 10:22 | #10 (permalink) |
Member: 772096 Status: Offline Sonork: 100.69222 Thanks Meter: 8,277 | ID: B5E0AD46CCE56A39DAAD68CBC564 Activated ID: 361C8C180BE268329A7036CBE566 Activated ID: 361CCC180BE26AC31A7146A3C16E Activated ID: 361CCC180BE27238A21026CC0D87 Activated ID: 361CCC180BE26AB1206E2634CA72 Activated ID: B561AC4624E666C161ED26BC1989 Activated ID: 37624D1893CD8837E20D2734D284 Activated ID: B5E0AD46CCE56A39DAAD68CBC564 Activated ID: B7E24D188BC988B899904813C270 Activated ID: B5E0AD46CCE56A39DAAD68CBC564 Activated ID: 369BD11893E56AB7591096CB0D6F Activated Dear usrers, make test and post result of read info log and some operations. |
12-02-2022, 09:18 | #14 (permalink) | |
Member: 772096 Status: Offline Sonork: 100.69222 Thanks Meter: 8,277 | Quote:
SSID and wifi key always change - because you try use free unlock. And for solved you need to write FW via Mkey with Fullrepair mode. So, try find in ur city ppls who buy Mkey dongle and give him 10$ for repair ur MF79U modem. Bt! If you want to use really free way for repair = try clone SPI NAND flash trough external flash prgrammer. The cost you 5$ for buy CH341A only. And time. But in this case you need have similar modem with fully working state for backup firmware. | |
