07-21-2022, 14:22 | #1 (permalink) |
Freak Poster Join Date: May 2013 Location: Ortahisar
Member: 1929052 Status: Offline Thanks Meter: 22 | always calculating failed [Answered] ------------------------------------------------------------------------------------------- Platform: SE Qualcomm Selected model: E10i Octopus smart card is present. Initializing Android Debug Bridge...OK Disconnect USB cable and power on the phone. Select menu "Settings"->"Applications"->"Development"->"Enable USB debugging" and connect USB cable...OK Device serial number: 43423531314C59535153 Device status: ACTIVE Reading info... Detected model name: E10i Firmware version: 2.1.1.A.0.6 Kernel version: 2.6.29 ------------------------------------------------------------------------------------------- Platform: SE Qualcomm Selected model: E10i Operation: Repair IMEI Connecting to server...OK Octopus smart card is present. Checking smart card...OK Smart card activations: LG, Samsung, SE Unlimited Username: omerucuncu Authorizing...OK Checking balance... Checking operation...OK Your balance: 150 credits. To Repair IMEI for E10i you need to have 0 credits. Initializing Android Debug Bridge...OK Disconnect USB cable and power on the phone. Select menu "Settings"->"Applications"->"Development"->"Enable USB debugging" and connect USB cable...OK Device serial number: 43423531314C59535153 Device status: ACTIVE Reading info... Detected model name: E10i Firmware version: 2.1.1.A.0.6 Kernel version: 2.6.29 Kernel version is supported Checking root access... Device is already rooted. Initializing flash...OK Checking security...Failed! ------------------------------------------------------------------------------------------- Platform: SE Qualcomm Selected model: E10i Operation: Repair IMEI Connecting to server...OK Octopus smart card is present. Checking smart card...OK Smart card activations: LG, Samsung, SE Unlimited Username: omerucuncu Authorizing...OK Checking balance... Checking operation...OK Your balance: 150 credits. To Repair IMEI for E10i you need to have 0 credits. Initializing Android Debug Bridge...OK Disconnect USB cable and power on the phone. Select menu "Settings"->"Applications"->"Development"->"Enable USB debugging" and connect USB cable...OK Device serial number: 43423531314C59535153 Device status: ACTIVE Reading info... Detected model name: E10i Firmware version: 2.1.1.A.0.6 Kernel version: 2.6.29 Kernel version is supported Checking root access... Device is not rooted. Sending exploit...OK Executing exploit...OK Reconnecting device. Please wait...OK Checking root access...OK Root access garanted! Initializing flash...OK Checking security...OK Reading Partition table...OK Reading SBL...OK SBL type: Original, version: R8A029 Reading TA...OK Backup saved to "C:\Program Files (x86)\Octoplus\Octoplus_Suite\BACKUP \Sony Ericsson_E10i_21-07-2022_16-18-39.BKP" Checking TA...OK Old IMEI: 012******** New IMEI: 352********* Replacing SBL...OK Calculating security on the server... Sending TA to server...OK Calculating. Please, wait...Failed! |
