E15a not service after imei repair. I have a free e15, imei repair it and says no service. Here the log -------------------------------------------------------------------------------- 28/10/2011 11:29:40 > Platform: SE Qualcomm 28/10/2011 11:29:40 > Selected model: E15a 28/10/2011 11:29:40 > Operation: Repair IMEI 28/10/2011 11:29:40 > Connecting to server...28/10/2011 11:29:41 > OK 28/10/2011 11:29:41 > Username: slimwe4 28/10/2011 11:29:41 > Authorizing...28/10/2011 11:29:42 > OK 28/10/2011 11:29:42 > Octopus smart card is present. 28/10/2011 11:29:42 > Checking smart card...28/10/2011 11:29:45 > OK 28/10/2011 11:29:45 > Checking balance...28/10/2011 11:29:46 > OK 28/10/2011 11:29:46 > Your balance: 10 credits. 28/10/2011 11:29:46 > To Repair IMEI for E15a you need to have 10 credits. 28/10/2011 11:29:46 > Initializing Android Debug Bridge...28/10/2011 11:29:47 > OK 28/10/2011 11:29:47 > Disconnect USB cable and power on the phone. Select menu "Settings"->"Applications"->"Development"->"Enable USB debugging" and connect USB cable...28/10/2011 11:29:47 > OK 28/10/2011 11:29:47 > Device serial number: 42583930324139364C55 28/10/2011 11:29:47 > Device status: ACTIVE 28/10/2011 11:29:47 > Reading info... 28/10/2011 11:29:48 > Detected model name: E15a 28/10/2011 11:29:48 > Firmware version: 2.0.1.A.0.47 28/10/2011 11:29:48 > Kernel version: 2.6.29 28/10/2011 11:29:48 > Kernel version is supported 28/10/2011 11:29:48 > Checking root access... 28/10/2011 11:29:49 > Device is not rooted. 28/10/2011 11:29:49 > Sending exploit...28/10/2011 11:29:49 > OK 28/10/2011 11:29:49 > Executing exploit...28/10/2011 11:29:50 > OK 28/10/2011 11:29:50 > Reconnecting device. Please wait...28/10/2011 11:29:57 > OK 28/10/2011 11:29:57 > Checking root access...28/10/2011 11:29:58 > OK 28/10/2011 11:29:58 > Root access garanted! 28/10/2011 11:29:58 > Initializing flash...28/10/2011 11:30:02 > OK 28/10/2011 11:30:03 > Checking security...28/10/2011 11:30:05 > OK 28/10/2011 11:30:05 > Reading Partition table...28/10/2011 11:30:05 > OK 28/10/2011 11:30:06 > Reading SBL...28/10/2011 11:30:07 > OK 28/10/2011 11:30:07 > SBL type: Original, version: R8A029, packed v2 28/10/2011 11:30:07 > Reading TA...28/10/2011 11:30:13 > OK 28/10/2011 11:30:13 > Backup saved to "C:\Archivos de programa\GsmServer\Octopus_SE\BACKUP\E15a_28-10-2011_11-30-07.BKP" 28/10/2011 11:30:13 > Checking TA...28/10/2011 11:30:13 > OK 28/10/2011 11:30:13 > Old IMEI: 012449-00-504539-3 28/10/2011 11:30:13 > New IMEI: 353640-02-941182-0 28/10/2011 11:30:13 > Replacing SBL...28/10/2011 11:30:17 > OK 28/10/2011 11:30:17 > Calculating security on the server... 28/10/2011 11:30:17 > Sending TA to server...28/10/2011 11:30:20 > OK 28/10/2011 11:30:20 > Calculating. Please, wait...28/10/2011 11:30:21 > OK 28/10/2011 11:30:21 > Receiving TA...28/10/2011 11:30:24 > OK 28/10/2011 11:30:24 > Writing security area...28/10/2011 11:30:25 > OK 28/10/2011 11:30:25 > Finalizing...28/10/2011 11:30:27 > OK 28/10/2011 11:30:27 > Rebooting device...28/10/2011 11:30:27 > OK 28/10/2011 11:30:27 > IMEI sucesfully repaired! Br. |
Me, repair TA, flash, Unlock (+10 log), and networkl OK. If before, setool touched then it is. Perhaps the "setool fakesign" because I do not know. If the phone is intact enough to repair imei! |
@ Motoka1 Hello. Please contact us, we will help You remotely. |
