Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2005 Location: burkina faso
Member: 202306 Status: Offline Thanks Meter: 13 | E15i unlock failed [Answered] ------------------------------------------------------------------------------------------- Platform: SE Qualcomm Selected model: E15i Connecting to server...OK Octopus smart card is present. Checking smart card...OK Smart card activations: Samsung Username: inoussanacoulma80 Authorizing...OK Checking balance... Checking operation...OK Your balance: 210 credits. To unlock E15i you need to have 40 credits. Initializing Android Debug Bridge...OK Disconnect USB cable and power on the phone. Select menu "Settings"->"Applications"->"Development"->"Enable USB debugging" and connect USB cable...OK Device serial number: 434235313151584D5639 Device status: ACTIVE Reading info... Detected model name: E15i Firmware version: 2.1.1.A.0.6 Kernel version: 2.6.29 Kernel version is supported Checking root access... Device is not rooted. Sending exploit...OK Executing exploit...OK Reconnecting device. Please wait...OK Checking root access...OK Root access garanted! Initializing flash...OK Checking security...OK Reading Partition table...OK Reading SBL...OK SBL type: Original, version: R8A029 Reading TA...OK Backup saved to "C:\Program Files (x86)\Octoplus\Octoplus_Suite\BACKUP \Sony Ericsson_E15i_11-04-2022_20-16-14.BKP" Checking TA...OK IMEI: 012448-00-969371-1 Replacing SBL...OK Calculating security on the server... Sending TA to server...OK Calculating. Please, wait...Failed! ------------------------------------------------------------------------------------------- Platform: SE Qualcomm Selected model: E15i Connecting to server...OK Octopus smart card is present. Checking smart card...OK Smart card activations: Samsung Username: inoussanacoulma80 Authorizing...OK Checking balance... Checking operation...OK Your balance: 210 credits. To unlock E15i you need to have 40 credits. Initializing Android Debug Bridge...OK Disconnect USB cable and power on the phone. Select menu "Settings"->"Applications"->"Development"->"Enable USB debugging" and connect USB cable...OK Device serial number: 434235313151584D5639 Device status: ACTIVE Reading info... Detected model name: E15i Firmware version: 2.1.1.A.0.6 Kernel version: 2.6.29 Kernel version is supported Checking root access... Device is not rooted. Sending exploit...OK Executing exploit...OK Reconnecting device. Please wait...OK Checking root access...OK Root access garanted! Initializing flash...OK Checking security...Failed! ------------------------------------------------------------------------------------------- Platform: SE Qualcomm Selected model: E15i Connecting to server...OK Octopus smart card is present. Checking smart card...OK Smart card activations: Samsung Username: inoussanacoulma80 Authorizing...OK Checking balance... Checking operation...OK Your balance: 210 credits. To unlock E15i you need to have 40 credits. Initializing Android Debug Bridge...OK Disconnect USB cable and power on the phone. Select menu "Settings"->"Applications"->"Development"->"Enable USB debugging" and connect USB cable...OK Device serial number: 434235313151584D5639 Device status: ACTIVE Reading info... Detected model name: E15i Firmware version: 2.1.1.A.0.6 Kernel version: 2.6.29 Kernel version is supported Checking root access... Device is not rooted. Sending exploit...OK Executing exploit...OK Reconnecting device. Please wait...OK Checking root access...OK Root access garanted! Initializing flash...OK Checking security...OK Reading Partition table...OK Reading SBL...OK SBL type: Original, version: R8A029 Reading TA...OK Backup saved to "C:\Program Files (x86)\Octoplus\Octoplus_Suite\BACKUP \Sony Ericsson_E15i_11-04-2022_20-21-34.BKP" Checking TA...OK IMEI: .........00-969371-1 Replacing SBL...OK Calculating security on the server... Sending TA to server...OK Calculating. Please, wait...Failed! ------------------------------------------------------------------------------------------- Platform: SE Qualcomm Selected model: E15i Please, reconnect battery, hold "back" key and connect USB cable...OK Reading info... Chipset: S1 MSM7227 IMEI: 012448-00-969371-1 MSN: CB511QXMV9 Sending loader...OK Selecting output file...OK Destination file: "Sony Ericsson_E15i_01244800969371_11-04-2022_20-26- 08.TA" Reading TA_MISC...OK Reading TA...OK Shutting down...OK ------------------------------------------------------------------------------------------- Platform: SE Qualcomm Selected model: E15i Please, reconnect battery, hold "back" key and connect USB cable...OK Reading info... Chipset: S1 MSM7227 IMEI: 012448-00-969371-1 MSN: CB511QXMV9 Sending loader...OK Reading TA... Reading TA_MISC...OK Reading TA...OKOK Backup saved to "Sony Ericsson_E15i_01244800969371_11-04-2022_20- 26-32.TA" Writing TA_MISC...OK Writing TA...OK Shutting down...OK ------------------------------------------------------------------------------------------- Platform: SE Qualcomm Selected model: E15i Connecting to server...OK Octopus smart card is present. Checking smart card...OK Smart card activations: Samsung Username: inoussanacoulma80 Authorizing...OK Checking balance... Checking operation...OK Your balance: 210 credits. To unlock E15i you need to have 40 credits. Initializing Android Debug Bridge...OK Disconnect USB cable and power on the phone. Select menu "Settings"->"Applications"->"Development"->"Enable USB debugging" and connect USB cable...OK Device serial number: 42583930324254344157 Device status: ACTIVE Reading info... Detected model name: E15i Firmware version: 2.1.1.A.0.6 Kernel version: 2.6.29 Kernel version is supported Checking root access... Device is not rooted. Sending exploit...OK Executing exploit...OK Reconnecting device. Please wait...OK Checking root access...OK Root access garanted! Initializing flash...OK Checking security...OK Reading Partition table...OK Reading SBL...OK SBL type: Original, version: R8A029 Reading TA...OK Backup saved to "C:\Program Files (x86)\Octoplus\Octoplus_Suite\BACKUP \Sony Ericsson_E15i_11-04-2022_20-28-16.BKP" Checking TA...OK IMEI:.........00-969371-1 Replacing SBL...OK Calculating security on the server... Sending TA to server...OK Calculating. Please, wait...Failed! |
