05-31-2012, 10:28 | #16 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | V1.0.6 - added Write Firmware for Huawei E153 and and Huawei E173. Octopus Suite v1.0.6 Release Notes:
If you have E153u-1, E153u-3, E173u-1 devices with unsupported for unlock firmware version, you can re-flash your device with UNLOCKED firmware from the support area. As result, your device will be unlocked! Write Firmware feature is available only for Octopus/Medusa card owners only (Octopus/Medusa box should be connected to your PC). Download Octopus Suite v1.0.6 ____________________________ WBR, Octopus Box Team |
06-11-2012, 15:48 | #17 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | V1.0.7 - a lot of Alcatel modems are added. Octopus Suite v1.0.7 is out! We've added support for Alcatel S220L, X030X, X060S, X070S, X080S, X090S, X100X, X200S, X200X, X210S, X210X, X215S, X225L, X225S and S228L modems. Octopus Box Suite v1.0.7 Release Notes:
If you don't own Octopus Box or Medusa Box, you'll have to pay 1 credit per one Unlock. Download Octopus Suite v1.0.7 ____________________________ WBR, Octopus Box Team |
07-06-2012, 14:20 | #18 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | V1.0.8 - Huawei calculator added and more! Octopus Suite v1.0.8.
Supported for direct unlock devices and firmware versions:
Please note! If you have E153u-1, E153u-3, E173u-1 devices with unsupported for unlock firmware version, you can re-flash your device with unlockable firmware from the support area and then perform unlock procedure. Not all devices can be re-flashed! Write Firmware feature is available only for Octopus/Medusa card owners (Octopus/Medusa box should be connected to your PC). Download Octopus Suite v1.0.8 ____________________________ WBR, Octopus Box Team |
07-20-2012, 16:01 | #19 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | V1.0.9 - ZTE calculator added and more! Octopus Suite v1.0.9
Important! Note that Unlock of ZTE MF100 and ZTE MF190 modems for Octopus Box (LG or Samsung activated) or Medusa Box owners is FREE. If you don't own Octopus Box or Medusa Box, you'll have to pay 3 credits per one Unlock. Also be aware that Unlock Codes Calculation of the above mentioned ZTE modems is FREE for Octopus Box (LG or Samsung activated) or Medusa Box owners as well. If you don't own Octopus Box or Medusa Box, you'll have to pay 1 credit per one calculation. Octopus Box team is endlessly grateful to customers who were actively involved in improving this software. Download Octopus Suite v1.0.9 ____________________________ WBR, Octopus Box Team |
08-02-2012, 15:17 | #20 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | V.1.1.0 - Added resetting of Pattern Lock for wide range of Sony Ericsson phones! Octopus Suite v1.1.0
Note! To reset phone's Pattern Lock just press "Reset Pattern Lock" button and follow the software instructions. There is no need to enable USB debugging. Important! Note that resetting Pattern Lock of the above-mentioned SE phones for owners of Octopus Box or Medusa Box is FREE. If you don't own Octopus Box, you'll have to pay 1 credit per resetting Pattern Lock of one phone. Octopus Team is endlessly grateful to customers who were actively involved in improving this software. Download Octopus Suite v1.1.0 ____________________________ WBR, Octopus Box Team |
08-22-2012, 15:43 | #21 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | V1.1.1 - added Reset Pattern Lock. Octopus Suite v1.1.1 is out:
Note! To reset phone's Pattern Lock just press "Reset Pattern Lock" button and follow the instructions. There is no need to enable USB debugging. Important! Note that resetting Pattern Lock of the above-mentioned SE phones for owners of Octopus Box or Medusa Box is FREE. If you don't own Octopus Box, you'll have to pay 1 credit per resetting Pattern Lock of one phone. Octopus Box team is endlessly grateful to customers who were actively involved in improving this software. Download Octopus Suite v1.1.1 ____________________________ WBR, Octopus Box Team |
09-19-2012, 15:36 | #22 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | V1.1.2 - new MF190, E173 firmwares added for unlock Octopus Box Suite v1.1.2
Important! Note that Unlock of the above-mentioned ZTE MF190 and Huawei E173 modems for owners of Octopus Box (LG or Samsung activated) or Medusa Box is FREE. If you don't own Octopus Box or Medusa Box, you'll have to pay 3 credits per one Unlock. Octopus Box team is endlessly grateful to customers who were actively involved in improving this software. Download Octopus Box Samsung Suite v1.1.2 ____________________________ WBR, Octopus Box Team |
11-23-2012, 14:58 | #23 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | V1.1.3 - added Repair Phone for a lot of Xperia phones! Octopus Suite v1.1.3 Octopus Suite v1.1.3 is out! Added Repair Phone (Repair Dead Boot + Repair IMEI + Unllock - all with one "Repair Phone" button!) via USB for Sony Ericsson Xperia Ray, Xperia Mini, Xperia Mini Pro, Xperia Active, Xperia Walkman, Xperia Play and Xperia Arc S (no need to solder JTAG wires - only small TP, no credits required either).
Note: Repair Phone feature for the listed above phones is available only for users with SE Unlimited Activation! Also note that Repair Phone procedure doesn't work for phones which were produced after 12W10 (12W11, 12W12, 12W13 and later) (phones with so-called new security). To repair mentioned above phones you need to perform following operations:
Download Octopus Suite v1.1.3 ____________________________ WBR, Octopus Box Team |
12-14-2012, 16:36 | #24 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | V1.1.4 - added support for Sony Xperia S (LT26i) and Sony Xperia Tipo (ST21i). Octopus Suite v1.1.4
Download Octopus Suite v1.1.4 ____________________________ WBR, Octopus Box Team |
02-08-2013, 17:00 | #25 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | V1.1.5 - phonebook editor added! Octopus Suite v1.1.5 - Android PhoneBook Editor is released! - Main features supported:
Note: to run Android PhoneBook Editor, press "Android PhoneBook Editor" button within the "Sony Ericsson" tab in the main software. Important: to read contacts from the phone, you need to install necessary Android phone drivers that suit your model. Octopus Team will be grateful for the replies and your feedback on the product. Expect more enhancements and improvements in the future. Download Octopus Suite v1.1.5 ____________________________ WBR, Octopus Box Team |
03-22-2013, 16:00 | #26 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | V1.1.6 - added Unlock Code Calculator for many Huawei data cards! Octopus Suite v1.1.6
Important! Note that Unlock of mentioned above Huawei devices for owners of LG or Samsung activated Octopus boxes or Medusa Box owners is FREE. If you don't own Octopus Box or Medusa Box, you'll have to pay 2 credits per one Unlock. ____________________________ WBR, Octopus Box Team |
The Following 2 Users Say Thank You to Octopus box For This Useful Post: |
04-26-2013, 15:43 | #27 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | V1.1.7 - added support for Huawei E303 HiLink, E353 HiLink, E3251 HiLink, E3131! Octopus Suite v1.1.7 - Added support for the following models:
- Released some improvements to the main software. Important! Note that Unlock of mentioned above Huawei devices for owners of LG or Samsung activated Octopus boxes or Medusa Box owners is FREE. If you don't own Octopus Box or Medusa Box, you'll have to pay 2 credits per one Unlock. Download Octopus Suite v1.1.7 ____________________________ WBR, Octopus Box Team |
05-10-2013, 13:59 | #28 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | V1.1.8 - added Read Unlock Codes for Huawei E5830, E5832, E5838 and more! Octopus Suite v1.1.8 * Added support for the following models:
* Added software manuals for supported devices. * Released some improvements to the main software. Important! Note that Read Unlock Code of mentioned above Huawei devices for owners of LG or Samsung activated Octopus boxes or Medusa Box owners is FREE. If you don't own Octopus Box or Medusa Box, you'll have to pay 2 credits per one code. Download Octopus Suite v1.1.8 ____________________________ WBR, Octopus Box Team |
03-11-2015, 15:06 | #29 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | V1.3.8 - added new Samsung and ZTE remote services! Octoplus/Octopus Suite v.1.3.8 is out! We have added new Samsung and ZTE remote services! Octoplus/Octopus Suite v.1.3.8 Release Notes:____________________________ WBR, Octopus Box Team |
04-10-2015, 13:40 | #30 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | V1.4.0 - added new Samsung, Amazon, HTC Nokia and more remote services! Octoplus/Octopus Suite v.1.4.0 is out!We have added new remote services! Also fixed some connectivity issues. Octoplus/Octopus Suite v.1.4.0 Release Notes: ____________________________ WBR, Octopus Box Team Last edited by Octopus box; 04-10-2015 at 17:24. |
nokia interface for nokia data suite | RanGerZzz | Nokia Hardware & Hardware Repair | 7 | 07-27-2000 00:49 |
Win 2K and Data Suite 3 | Nitas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-14-2000 18:42 |
cellular data suite kabel | vingis | Main Sales Section | 0 | 11-25-1999 19:18 |
Cellular Data Suite Cables avaliable !!! | vingis | Main Sales Section | 0 | 11-02-1999 17:35 |
