12-12-2018, 14:02 | #1 (permalink) |
Registered User Join Date: Jan 2011 Location: rawalpindi
Member: 1494799 Status: Offline Sonork: 100.1602242 Thanks Meter: 15 | ST26A unlock problem [Solved] ------------------------------------------------------------------------------------------- Platform: SONY Qualcomm Selected model: ST26a Octopus smart card is present. Initializing Android Debug Bridge... ADB Server was found. Trying to kill...OK Disconnect USB cable and power on the phone. Select menu "Settings"->"Developer options"->"Enable USB debugging" and connect USB cable...OK Device serial number: YT9108WQL2 Device status: ACTIVE Reading info... Detected model name: ST26a Firmware version: 11.2.A.0.33 Kernel version: 3.4.0 IMEI: 353933052588824 ------------------------------------------------------------------------------------------- Platform: SONY Qualcomm Selected model: ST26a Connecting to server...OK Octopus smart card is present. Checking smart card...OK Smart card activations: LG, Samsung Username: Default_user Authorizing...OK Checking balance... Checking operation...Failed! Too low balance to provide the security operation! Your balance: 0 credits. To unlock ST26a you need to have 50 credits. ------------------------------------------------------------------------------------------- Connecting to server...OK Username: adnanrawalpindi Authorizing...OK Checking balance...OK Your balance: 50 credits. Octopus smart card is present. Checking smart card...OK Smart card activations: LG, Samsung --------------------------------------------------------------------------- Platform: SONY Qualcomm Selected model: ST26a Operation: Repair Security Connecting to server...OK Octopus smart card is present. Checking smart card...OK Smart card activations: LG, Samsung Username: adnanrawalpindi Authorizing...OK Checking balance... Checking operation... Initializing Android Debug Bridge...OK Disconnect USB cable and power on the phone. Select menu "Settings"->"Developer options"->"Enable USB debugging" and connect USB cable...OK Device serial number: YT9108WQL2 Device status: ACTIVE Reading info... Detected model name: ST26a Firmware version: 11.2.A.0.33 Kernel version: 3.4.0 IMEI: 353933052588824 Checking IMEI...OK Checking root access... Press "Allow/Grant" button on the phone every time when superuser dialog appears! Device is already rooted. Reading security area...OK Backup saved to "C:\Program Files (x86)\Octoplus\Octoplus_Suite\BACKUP \Sony_ST26a_353933052588824_12-12-2018_16-54-01.sec" Checking security area...OK Calculating security on the server... Sending TA to server...OK Calculating. Please, wait...Failed! Last edited by Octopus box; 12-13-2018 at 18:15. |
12-13-2018, 17:21 | #3 (permalink) |
Member: 1494799 Status: Offline Sonork: 100.1602242 Thanks Meter: 15 | Welcome to Octoplus Suite version 1.5.8 ------------------------------------------------------------------------------------------- Platform: SONY Qualcomm Selected model: ST26a Octopus smart card is present. Initializing Android Debug Bridge... ADB Server was found. Trying to kill...OK Disconnect USB cable and power on the phone. Select menu "Settings"->"Developer options"->"Enable USB debugging" and connect USB cable...OK Device serial number: YT9108WQL2 Device status: ACTIVE Reading info... Detected model name: ST26a Firmware version: 11.2.A.0.33 Kernel version: 3.4.0 IMEI: 353933052588824 ------------------------------------------------------------------------------------------- Connecting to server...OK Username: adnanrawalpindi Authorizing...OK Checking balance...OK Your balance: 50 credits. Octopus smart card is present. Checking smart card...OK Smart card activations: LG, Samsung ------------------------------------------------------------------------------------------- Platform: SE Qualcomm Selected model: ST17a Connecting to server...OK Octopus smart card is present. Checking smart card...OK Smart card activations: LG, Samsung Username: adnanrawalpindi Authorizing...OK Checking balance...OK Your balance: 50 credits. To unlock ST17a you need to have 40 credits. ------------------------------------------------------------------------------------------- Platform: SE Qualcomm Selected model: ST17a Please, reconnect battery, attach testpoint and connect USB cable...Canceled. ------------------------------------------------------------------------------------------- Platform: SONY Qualcomm Selected model: ST26a Octopus smart card is present. Initializing Android Debug Bridge...OK Disconnect USB cable and power on the phone. Select menu "Settings"->"Developer options"->"Enable USB debugging" and connect USB cable...OK Device serial number: YT9108WQL2 Device status: ACTIVE Reading info... Detected model name: ST26a Firmware version: 11.2.A.0.33 Kernel version: 3.4.0 IMEI: 353933052588824 ------------------------------------------------------------------------------------------- Platform: SONY Qualcomm Selected model: ST26a Connecting to server...OK Octopus smart card is present. Checking smart card...OK Smart card activations: LG, Samsung Username: adnanrawalpindi Authorizing...OK Checking balance... Checking operation...OK Your balance: 50 credits. To unlock ST26a you need to have 50 credits. Initializing Android Debug Bridge...OK Disconnect USB cable and power on the phone. Select menu "Settings"->"Developer options"->"Enable USB debugging" and connect USB cable...OK Device serial number: YT9108WQL2 Device status: ACTIVE Reading info... Detected model name: ST26a Firmware version: 11.2.A.0.33 Kernel version: 3.4.0 IMEI: 353933052588824 Checking IMEI...OK Checking root access... Press "Allow/Grant" button on the phone every time when superuser dialog appears! Device is already rooted. Reading security area...OK Backup saved to "C:\Program Files (x86)\Octoplus\Octoplus_Suite\BACKUP \Sony_ST26a_353933052588824_13-12-2018_20-17-15.sec" Checking security area...OK Calculating security on the server... Sending TA to server...OK Calculating. Please, wait...OK Receiving TA...OK Writing security area...OK Rebooting device...OK Phone successfully unlocked! ------------------------------------------------------------------------------------------- Connecting to server...OK Username: adnanrawalpindi Authorizing...OK Checking balance...OK Your balance: 0 credits. Octopus smart card is present. Checking smart card...OK Smart card activations: LG, Samsung Great work thanx octopus team soo much its working |
The Following User Says Thank You to adnanrawalpindi For This Useful Post: |
