Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus/Octoplus Suite
Old 12-08-2013, 13:09   #1 (permalink)
Member: 882614
Sonork: 100.1608795
Thanks Meter: 141
st21 no signal after unlock
plz help me st21 no signal after unlock
Platform: SONY Qualcomm
Selected model: ST21i
Octopus smart card is present.
Initializing Android Debug Bridge...OK
Disconnect USB cable and power on the phone. Select menu
"Settings"->"Developer options"->"Enable USB debugging" and connect USB
cable...OK
Device serial number: YT9104K0SW
Device status: ACTIVE
Reading info...
Detected model name: ST21i
Firmware version: 11.0.A.0.16
Kernel version: 3.0.8-perf
IMEI: 355875055230441
Old 12-08-2013, 13:18   #2 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 27,406
Hello.
Post here full Software log with Unlock operation.
Old 12-08-2013, 13:23   #3 (permalink)
!!!_babu_!!!'s Avatar
Member: 1627323
Sonork: WhatsApp+8801763009154
Thanks Meter: 481
TRY reset ur phone....................
Old 12-08-2013, 13:58   #4 (permalink)
sadewophone's Avatar
Member: 1624056
Thanks Meter: 130
flashing your phone.... and registering card to network country...........
Old 12-08-2013, 17:07   #5 (permalink)
Member: 882614
Sonork: 100.1608795
Thanks Meter: 141
07/12/2013 21:10:57 > Platform: SONY Qualcomm
07/12/2013 21:10:57 > Selected model: ST21i
07/12/2013 21:10:57 > Connecting to server...07/12/2013 21:10:58 > OK
07/12/2013 21:10:58 > Octopus smart card is present.
07/12/2013 21:10:58 > Checking smart card...07/12/2013 21:11:03 > OK
07/12/2013 21:11:03 > Smart card activations: LG, Samsung, SE Unlimited
07/12/2013 21:11:03 > Authorizing...07/12/2013 21:11:03 > OK
07/12/2013 21:11:03 > Username: redachokri
07/12/2013 21:11:03 > Checking balance...
07/12/2013 21:11:04 > Checking operation...07/12/2013 21:11:04 > OK
07/12/2013 21:11:04 > Your balance: 74 credits.
07/12/2013 21:11:04 > To unlock ST21i you need to have 4 credits.
07/12/2013 21:11:04 > Initializing Android Debug Bridge...07/12/2013 21:11:05 > OK
07/12/2013 21:11:05 > Disconnect USB cable and power on the phone. Select menu "Settings"->"Developer options"->"Enable USB debugging" and connect USB cable...07/12/2013 21:11:05 > OK
07/12/2013 21:11:05 > Device serial number: YT9104K0SW
07/12/2013 21:11:06 > Device status: ACTIVE
07/12/2013 21:11:06 > Reading info...
07/12/2013 21:11:06 > Detected model name: ST21i
07/12/2013 21:11:06 > Firmware version: 11.0.A.0.26
07/12/2013 21:11:07 > Kernel version: 3.0.8-perf
07/12/2013 21:11:07 > IMEI: 355875055230441
07/12/2013 21:11:07 > Checking IMEI...07/12/2013 21:11:08 > OK
07/12/2013 21:11:08 > Checking root access...07/12/2013 21:11:08 > OK
07/12/2013 21:11:08 > Device is already rooted.
07/12/2013 21:11:08 > Reading security area...07/12/2013 21:11:12 > OK
07/12/2013 21:11:12 > Backup saved to "C:\Program Files\Octoplus\Octoplus_Suite\BACKUP\Sony_ST21i_35 5875055230441_07-12-2013_21-11-12.sec"
07/12/2013 21:11:12 > Checking security area...07/12/2013 21:11:12 > OK
07/12/2013 21:11:12 > Calculating security on the server...
07/12/2013 21:11:12 > Sending TA to server...07/12/2013 21:11:13 > OK
07/12/2013 21:11:13 > Calculating. Please, wait...07/12/2013 21:11:14 > OK
07/12/2013 21:11:14 > Receiving TA...07/12/2013 21:11:17 > OK
07/12/2013 21:11:17 > Writing security area...07/12/2013 21:11:20 > OK
07/12/2013 21:11:20 > Rebooting device...07/12/2013 21:11:21 > OK
07/12/2013 21:11:21 > Phone successfully unlocked!
Old 12-08-2013, 17:23   #6 (permalink)
Member: 1146942
Sonork: 100.1587278
What is signed in your phone's screen when You insert SIM card? Does the phone accept card or not? Have You tried to use different SIM cards? Have You tried to select network manually?
Old 12-08-2013, 17:32   #7 (permalink)
Member: 882614
Sonork: 100.1608795
Thanks Meter: 141
yes my st21i acceptet any sim card.i select network manul un message(non enregistré sur le réseua)
Old 12-08-2013, 18:44   #8 (permalink)
Member: 1146942
Sonork: 100.1587278
Try to re-flash the phone. Also, please upload somewhere first security backup ("Sony_ST21i_35 5875055230441_07-12-2013_21-11-12.sec") from your device and post here link; we will try to write it into our phone, unlock it and check, whether the network is OK.
Old 12-08-2013, 19:05   #9 (permalink)
Member: 882614
Sonork: 100.1608795
Thanks Meter: 141
Sony_ST21i_355875055230441_07-12-2013_20-46-41 - Download - 4shared
Old 12-09-2013, 11:47   #10 (permalink)
Member: 882614
Sonork: 100.1608795
Thanks Meter: 141
some probleme
Opening "ST21i_11_0_A_0_16.FSP_TapiocaSS_WORLD_i_1264_7115 _S1(Taiwan).oct"...OK
Please, reconnect battery, hold "Vol-" key and connect USB cable...OK
Reading info...
Chipset: S1 MSM7225A
IMEI: 355875-05-523044-1
Sending loader...OK
Writing Firmware...
Writing System...OK
Writing UserData...OK
Writing AMSS...OK
Writing Modem_fs1...OK
Writing Modem_fs2...OK
Shutting down...OK
Firmware has been successfully written!
Reading info...
Device is not rooted.
Device will be rooted now. Please wait..
Checking root access...OK
Root access garanted!
Reading info...
Checking IMEI...OK
Reading security area...OK
Backup saved to "C:\Program Files\Octoplus\Octoplus_Suite\BACKUP\Sony_ST21i_35 5875055230441_09-12-2013_10-33-03.sec"
Checking security area...OK
Sending TA to server...OK
Calculating. Please, wait...OK
Receiving TA...OK
Writing security area...OK
Rebooting device...OK
Phone's Bootloader successfully unlocked!
Old 12-09-2013, 15:16   #11 (permalink)
Member: 1146942
Sonork: 100.1587278
We have written security backup from your device into our phone, then performed Unlock operation. Phone became unlocked and no problem with network; so, this can be HW problem. Please check phone's HW. Also maybe phone's IMEI is in your network operator's black list. Try to use another SIM card from another operator.
Page generated in 0.24369 seconds with 8 queries
