Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > Sim Cloning and Scaning
Old 08-05-2006, 12:29   #1 (permalink)
Member: 36425
Thanks Meter: 4
no network after read sim card
I try read my sim card with sim card reader.
After read my sim card having no network.
Is any one having this problem.
Old 08-07-2006, 16:37   #2 (permalink)
Member: 16493
Thanks Meter: 3
its about a38 limit, when you reach limit, card will block by inside (cpu) no more usage available, get new simcard from operator
Old 08-19-2006, 21:31   #3 (permalink)
Member: 66471
Thanks Meter: 7
Alas - this problem is real: how to determine A38 limit before scanning sim - in order to avoid blocking. Some manufactores set the limit not at "usual" 65536, but at lower level (approx 40000).
Other users of the same provider could help (if they are acquainted with the sim-cloning technology).
Old 08-20-2006, 10:21   #4 (permalink)
::Yasir::'s Avatar
Member: 47281
Thanks Meter: 17
I get same prob as yours. Sim card Registration failed after writing.
I use SIM MAX: when I scan original sim i get the correct CCID(same as written at the back of the SIM) but when i try to write file, it displays the "reversed" version of CCID
E.g if software read 8965215665..
I get 9856216565...
Why's that?
Old 08-20-2006, 20:33   #5 (permalink)
Member: 66471
Thanks Meter: 7
You problem seems to be not THE SAME. Comrade anthony cheah reported (as i understood) that his original simcard had failed to register. Whereas you told about a SIM-MAX [software] bug
I get 9856216565...
Why's that?
Looks like the software bug. It doesn't reverse syllables (but should).
ICCID is not very important parameter, but if the same bug exists in dealing with other parameters (IMSI or Ki) - your clone never register. For sure..
Old 08-21-2006, 16:00   #6 (permalink)
::Yasir::'s Avatar
Member: 47281
Thanks Meter: 17
Exclamation
I changed software. I used Sim Scan V 2.0 and read both KI & IMSI. it was written in a file somthing lik KI_IMSI.dat and when i Click on WRite KI/IMSI, i get an error message saying wrong file or something like that.... Can u tell me what's the prob now?
Old 08-21-2006, 23:02   #7 (permalink)
Member: 66471
Thanks Meter: 7
Of course - no, since i do know nothing about SIM-MAX and its sofware. I use SIM-Emu Configurator (by Daniel Jabif) and Light version by PIC-ador. This software works fine.
1200-1208-1650-1209 charge no respon after change sim card xiangmdn Nokia Hardware & Hardware Repair 1 10-01-2010 13:14
3220 no network and insert sim card JeAn-cLeM Nokia Hardware & Hardware Repair 5 11-27-2008 13:04
MC60 no read SIM CARD bossko Siemens Hardware Repair Area 4 02-04-2006 18:36
SE Z600 no read sim card pabloo81 Sony Ericsson Hardware Repair 4 10-16-2005 09:00
Page generated in 0.15839 seconds with 9 queries
