Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | ★ Wholesale Unlock ★ | Direct Unlock Source | Mark Forums Read |
![]() | #1 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2002
Member: 13929 Status: Offline Thanks Meter: 0 | IC Prog with CP and CPD ! it's possible that I use CP and CPD with IC Prog when I put in the PIC the file flash of SimEmu ? I have tried but after is not possible write the ADN in the flash or the name of the provider for tel. 1 to tel. 8 and the security for PIN (+ 3 attempts) don't work !. It's possibile to use IC Prog with CP from 0000h to for example 1000h ? This is good because would like to use above all this functions so if I loose my sim, there are not problem for my ADN write in the flash and don't visible for the man that can find my SIM !! |
![]() | #3 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2002 Location: Spain Age: 62
Member: 10582 Status: Offline Thanks Meter: 98 | As one time I explained, don't uncheck the WRT because all the internals updates to flash are forbidden. In the flash reside the last part of phonebook, descriptions of positions and PINs/PUK's tries. It is not possible to protect flash areas for reading via ICProg and maintain internals updates. See Microchip docs. For this reason, the KI/PINs/PUKs are located in the internal EEPROM because it is possible to protect it and allow to program update this area. Regards |
![]() | #5 (permalink) |
Member: 10582 Status: Offline Thanks Meter: 98 | The hardware does not allow to do this. See Microchip docs if you want to undestand more. This table was extracted of 16F87x doc of Microchip manufacturer. TABLE 4-1: READ/WRITE STATE OF INTERNAL FLASH PROGRAM MEMORY Code: Configuration Bits Memory Location Internal Internal ICSP Read ICSP Write CP1 CP0 WRT Read Write 0 0 x All program memory Yes No No No 0 1 0 Unprotected areas Yes No Yes No 0 1 0 Protected areas Yes No No No 0 1 1 Unprotected areas Yes Yes Yes No 0 1 1 Protected areas Yes No No No 1 0 0 Unprotected areas Yes No Yes No 1 0 0 Protected areas Yes No No No 1 0 1 Unprotected areas Yes Yes Yes No 1 0 1 Protected areas Yes No No No 1 1 0 All program memory Yes No Yes Yes 1 1 1 All program memory Yes Yes Yes Yes Regards |
What programmer to buy to use with IC-Prog? | gary stonecutte | Sim Cloning and Scaning | 2 | 09-24-2004 18:30 |
Why I can't use IC-prog on WinXP? | sir_wo | Sim Cloning and Scaning | 2 | 07-07-2004 07:52 |
which software like ic-prog???? | pisquit | Sim Cloning and Scaning | 3 | 05-28-2004 22:28 |
IC-PROG doesn't write to silver card | virtualj | Sim Cloning and Scaning | 10 | 07-25-2003 18:33 |
ic prog | alrm7 | Sim Cloning and Scaning | 1 | 09-08-2002 03:50 |
