Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > Sim Cloning and Scaning
Old 12-29-2004, 05:58   #91 (permalink)
Surej's Avatar
Member: 12296
Thanks Meter: 9
I programmed Greencard 2 with out any problems....only thing is it takes some time to switch between lines like it take around 2 min to change lines from one provider to other in an X100..but if you reset from menu and enter pin then it's fast...
WBR
Surej
The Following User Says Thank You to Surej For This Useful Post:
Old 01-26-2005, 19:48   #92 (permalink)
NBG
NBG's Avatar
Member: 3101
Thanks Meter: 6
ON Nec 616 and Nec 313 phone kills green 2 card with 6.01 simemu.It asks for pin,after that goes to search network and phones kills pic content,Only way is to reprogram card again in programmator.Can you do something abouth this?
Thanks
The Following User Says Thank You to NBG For This Useful Post:
Old 01-27-2005, 00:51   #93 (permalink)
JAVA Good's Avatar
Member: 66136
Thanks Meter: 200
some one can tell me what is best software for read KI pls ?
and the time for read it it's between X hours and X hours pls ?
and sorry for my BAD english .
regards,
JAVA Good.
The Following User Says Thank You to JAVA Good For This Useful Post:
Old 01-27-2005, 19:24   #94 (permalink)
simemu's Avatar
Member: 10582
Thanks Meter: 99
@NBG
I'll try to investigate the problem when I have one of these models.
@JAVA
Use Woron Scan
Regards
The Following User Says Thank You to simemu For This Useful Post:
Old 01-27-2005, 20:50   #95 (permalink)
Crazy Poster
Member: 8967
Thanks Meter: 4
Originally Posted by simemu
It is possible to download exclusively from the following pages:
http://simemu.cjb.net
http://simemu.gsmhosting.net
News
Solved problem with the description of the positions
Having actives the 10 positions and introducing more than 12 characters in each one, the option "Sel.Phone #" hanged the SIM-EMU due to a memory overflow.
IMPORTANT
For this revision, it is only necessary to reprogram the flash and to introduce the IMSI/Ki data again using phone menu, SMS's or from PC using the Grabar_SMS.xvb script with a previous data saved.
Regards
Thanks for your SIMEMU.
it's very nice
The Following User Says Thank You to Shebani For This Useful Post:
Old 03-16-2005, 15:30   #96 (permalink)
Member: 107545
Thanks Meter: 44
Dear SimEmu
I have your last SIM_EMU_6.01_CFG_v2.1.msi, but with some problems. Because in Nokia and Samsung X100 when i am selecting phone number from Sel.phone# then it is switching very well but in other sets is not switching to other number then i am going on other number after switch off/on, enter pin for other number and then number does work.
You are requested to please give me your nice opinion on this problem that how i can solve this problem i.e. how i can switched an other number through Sel.phone# instead of switch off/on.
An early attention is requested.
SATZONE
The Following User Says Thank You to satzone For This Useful Post:
Old 04-05-2005, 18:21   #97 (permalink)
Member: 122120
Originally Posted by Angelex
@SimEmu
I use Sony J70 - emul works fine. But some slowly changing number when I use "Sel.Phone". When I use "Reset" - its normal ~10sec. After it ~15sec I cant use phone book. I think its normal too coz I use silvercard.
I can`t try Ericsson, coz nobody of my friends have it
Question - in SimEmu v6.01, I can put only one ICCID, or 10 for each number? If posible 10 - please send me adreses in EE.hex
Regards, Alex
There is a modified version of Sim-Emu 6.01 with the full support of 10 ICCID.
Also added:
∑ Switchable A3A8 counter
∑ Extensible Information/Actual Nr menu (TMSI, LAC and Cell ID indication was added)
∑ Configurable menu (removing of unnecessary items)
∑ ACC (Access Control Class) configuration
∑ Convenient ADN, SMS, FDN calculator
∑ Ability of removing the operatorís name and/or description.
Get it here: http://borozda.com/pic-ador
The Following User Says Thank You to Shocking For This Useful Post:
Old 04-09-2005, 19:06   #98 (permalink)
Member: 135709
Any help please
Impossible to install Sim-Emu 6.01 in my Windows 98 SE
I have this message : SIM\-EMU6.01\instmsia.exe not found
Best regards
The Following User Says Thank You to flashsat For This Useful Post:
Old 04-11-2005, 21:52   #99 (permalink)
simemu's Avatar
Member: 10582
Thanks Meter: 99
Download this http://simemu.gsmhosting.net/utils/instmsiA.exe
Read here http://forum.gsmhosting.com/vbb/showthread.php?t=123603
Old 04-13-2005, 11:41   #100 (permalink)
Member: 136798
Thanks Meter: 2
Hi i need schematic for SIM-EMU 6.01 BESTREGARDS [email protected]
The Following User Says Thank You to monitel_service For This Useful Post:
Old 05-10-2005, 04:31   #101 (permalink)
Member: 131974
I can not see current number/name on my main screen of MOTO MPx220.
The Following User Says Thank You to meokey For This Useful Post:
Old 05-10-2005, 18:02   #102 (permalink)
simemu's Avatar
Member: 10582
Thanks Meter: 99
Yes, that's a phone problem. This model is not capable to show the SPN record info of the SIM.
Regards
Old 05-10-2005, 21:28   #103 (permalink)
Member: 27476
Thanks Meter: 2
@simemu
Don't u work for a new version of simemu? Could u add an ability to the simemu, I want to fix a line to a phone number. So when i activate to line2 i have to call only 1 number which i set. When i activate line1 it is possible to call every numbers. Is it possible to add this ability? if u may do, it will be great. Sorry my bad english.
Best Regards.
The Following User Says Thank You to SaNTaNa For This Useful Post:
Old 05-20-2005, 09:48   #104 (permalink)
Member: 137168
Thanks Meter: 3
Talking
Hi SimEmu!
You are fantastic!
Can you help me to use more then 10 sim in a green card?
Have you seen here: http://borozda.com/pic-ador/
Is a good solution?
I'll wait for a SIMEMU 7 with 20 sim in one green card!
The Following User Says Thank You to PN.ItalyGirl For This Useful Post:
Old 05-21-2005, 00:06   #105 (permalink)
Member: 39679
Thanks Meter: 41
thanks simemu ! we where waiting for that!
The Following User Says Thank You to Gsmtechno For This Useful Post:
Revision SIM-EMU 6.02 (AVAILABLE) simemu Sim Cloning and Scaning 101 07-22-2023 11:48
A question about SIM-EMU 6.01!!! hazzard Sim Cloning and Scaning 4 10-09-2021 23:37
New SIM-EMU 6.01 with Arabic menu language simemu Sim Cloning and Scaning 17 09-03-2003 22:08
New SIM-EMU 6.01 with Slovak menu language simemu Sim Cloning and Scaning 0 08-20-2003 17:15
New revision SIM-EMU 4.01 simemu Sim Cloning and Scaning 54 06-20-2002 06:49
Page generated in 0.20460 seconds with 9 queries
