09-13-2002, 19:18 | #1 (permalink) |
Freak Poster Join Date: Apr 2002 Location: Poland Age: 48
Member: 10850 Status: Offline Thanks Meter: 0 | My JGProg doesn't work with GreenCard... My JGProg doesn't support 24C128, ICProg doesn't work with my programmer ... I work with WinXP (except Sim_scan in pure DOS of course ) and have JDM and Phoenix/Smartmouse hardware.... Could You advice me which soft shoud I use ... Thank's in advance! Best regards Last edited by Milenko; 09-13-2002 at 19:38. |
09-14-2002, 07:42 | #4 (permalink) |
Junior Member Join Date: Aug 2002
Member: 14422 Status: Offline Thanks Meter: 0 | Milenko Yesterday I wrote to author of JGprog, if he can do something with this issue. I tried the PicBined which we satfans use to write the Pic2rd with DS9 memory hex. I am not sure if the last version of this SW can write 128 (256), but you can simply edit the ini file to program it. Without editing it write only first half (quotter) You have to add to end of the ini file this section: [Phoenix set1C] name=DS9 /c256 ->> allcam id=0101 secretkey= round=0 ps=parity=N data=8 stop=2 comment=BR=5726/3.57MHz, 9600/6MHz rsq= rsp= rlc=< rao=+= rav=length rco=+= rcv=01 rlq1=01 FF length highbyteaddress lowbyteaddress 00 checksum rlp1=01 FF 00 00 00 highbyteaddress lowbyteaddress length data FF rlq2= rlp2= req= rep= rmaxloop=8000 rlength=10 rcounter=0 raddress=0 wsq= wsp= wlc=< wao=+= wav=length wco=+= wcv=01 wlq1=01 FF 00 highbyteaddress lowbyteaddress length data checksum wlp1=01 FF 00 00 length highbyteaddress lowbyteaddress 00 FF wlq2= wlp2= weq= wep= wmaxloop=8000 wlength=10 wcounter=0 waddress=0 and then on top of the ini file edit this section this way: [Phoenix sets] Phoenix sets=1C Look what is your last section number before editing my was 1B. Like this you can do easy the 128 memory too, only the r/w-maxloop values will be equal 4000. As loader you have to use the DS9-504 hex.!!! PiGeon CSSF Last edited by PiGeon; 09-14-2002 at 07:44. |
09-14-2002, 09:47 | #5 (permalink) |
Member: 10850 Status: Offline Thanks Meter: 0 | I configured PicBinEd the way You wrote, but I still can't programm ext eeprom. Program says that there is an ATR problem You wrote that i should use DS9-504 hex I haven't got such file so i programmed PIC with standart loader from JGProg ... is this wrong? Could You send me DS9-504 hex file? regards |
09-15-2002, 13:13 | #7 (permalink) |
Member: 10850 Status: Offline Thanks Meter: 0 | This link doesn't work for this moment. I'll try again this evening Besides ... could You send me this file via @mail? Thanks once again for replys... regards |
09-16-2002, 18:14 | #8 (permalink) |
Member: 10850 Status: Offline Thanks Meter: 0 | @Pigeon Sorry ... it doesn't work : PicBinEd gives constant errors with your script This is terrible!!! I can't enjoy new sim_emu5.00 Please ...friends ... tell me what soft do You use to program this f...in' greencard Sorry for my language ... but I'm very angry ... regards |
09-16-2002, 19:53 | #9 (permalink) |
Member: 14422 Status: Offline Thanks Meter: 0 | I don't understand. everything I did, is that I copied the section of DS9/64 pasted on end of inifile. edited the head of the section to the next in order "[Phoenix set1C]" modified this 2 lines rmaxloop=8000 wmaxloop=8000 and in section [Phoenix sets] Phoenix sets=1C wrote the last set number which was in my case "1C" Or you can easy edit this way the original section without any copiing and editing section head. Everything you need is only increase the values of following 2 lines rmaxloop=8000 wmaxloop=8000 for 128 enter there 4000 and for 256 enter 8000. And use the original DS/64 which in fact would be 128 (256) |
09-17-2002, 06:23 | #10 (permalink) |
Member: 10850 Status: Offline Thanks Meter: 0 | @Pigeon I corrected: rmaxloop=8000 wmaxloop=8000 to value 4000 and it almost work .... I still got a message about inwerted ATR After select "write option" program asks me if invert all for phoenix. I don't understand that (my programmer is not switched to smartmouse mode ). When I answer "no" EEPROM starts to programm and after verifying it's all OK. Unfortunatelly when I flash PIC and put this card to phone it doesn't work It seems that is an EEPROM problem because phone asks about PIN and then after few seconds says "card error". When I answer "yes" to "invert question" PicBinEd gives still error... Just one thing more: In Your script parameters should be: parity=N data=8 stop=2 (are You sure? ) @all: It seems that on this forum is only one man, who ever programmed greencard ... and wants to help... I'm very sad that noone else wants to help me |
09-17-2002, 07:00 | #11 (permalink) |
Freak Poster Join Date: Feb 2002 Location: At home
Member: 9602 Status: Offline Thanks Meter: 5 | Dunno if this work 4 U, but give it a try anyway. http://www.makinterface.de/SCPROG.ZIP I use it with my Phoenix (Voonix M III ), never tried green-card but the others are ok for me. Put Your Programmer in Phoenix mode Start proggie (Some errors appear...) Put in your card Select Correct Chip in Upper comboboxes Press Identify-button at top Press PRG Loader at bottom Load Ext EE and Write it Now You can prog Your Picfile, maybe from Your Earlier soft if this one canīt handle it for You rgds Eurocrypt |
09-17-2002, 18:07 | #13 (permalink) |
Member: 10850 Status: Offline Thanks Meter: 0 | @Eurocrypt My Phoenix programmer doesn't work with this software It identyfies PIC throught JDM, but with Phoenix still gives an ATR error What frequency is used in MAKInterface for Phoenix mode? What loader should I use? DS9504 is good? |
09-17-2002, 19:43 | #15 (permalink) |
Member: 9602 Status: Offline Thanks Meter: 5 | hmmm I was a bit brain dead when writing the above helppost Do like this: Make sure Your Progger is in JDM mode Select correct chip in upper comboboxes(Both Pic & EE) Erase Pic (A couple of times to be sure) Make sure "->LOADER" is in Lower Combobox Press Button [Prg Loader] Change Your progger to Phoenix-mode Now itīs time to [IDENTIFY] at upper Button (Should be a correct ATR now) Load ExtEE in the lower part of Program Press Button [Write] Now Your EE should be at the right place, very sorry for my earlier mistake brgds Eurocrypt |
My vygis box doesn't work with new version (LG) software | steca | VygisToolbox | 6 | 11-18-2007 13:22 |
This software doesn't work with any of my (working) cables... | James_S | Samsung (USB-Smart) | 14 | 07-15-2006 02:16 |
My Vygis doesn't work any more!!!! | basim | VygisToolbox | 13 | 01-29-2006 10:28 |
my cruiser doesn't work!!! | kysnam | Cruiser Suite | 1 | 10-31-2005 20:07 |
My SmartClip doesn't work after failure upgrade! PLZ HELP ME ! | D-A-F-I | Smart-Clip | 1 | 11-27-2004 19:50 |
