10-18-2011, 11:29 | #631 (permalink) |
Junior Member Join Date: Feb 2008
Member: 703178 Status: Offline Thanks Meter: 6 | ***************************** Ver5.601 (2011-8-18) **************************** New features: 1£º [MTK] MT6236 supported 2£º [MTK] netword unlock improved 3£º [MStar] MSW8533C Nand supported 4£º [All Chips] Support new flash memory: NOR_K5N6433ATB NOR_MX29GL640E_H_L NOR_MX29NS640E NOR_S29VS064R_T NOR_M58WR032KU NAND_HY27UF084G2B 5£º[MISC] Flasher Log Added 6£º[MISC] Flasher info can copy to the clipboard directly with the right click taken from "about" tab what should i do? |
10-18-2011, 13:19 | #632 (permalink) | |
No Life Poster Join Date: May 2008 Location: hall road pakistan
Member: 782530 Status: Offline Thanks Meter: 8,136 | Quote:
your used old verion. new avatorbox exe verion 5.620 my dear bro open your eyes and see on support .with also chack date 2011-Sep-19 bro AvatorBox Team | |
The Following User Says Thank You to FullFlashPak For This Useful Post: |
10-19-2011, 09:45 | #637 (permalink) |
No Life Poster Join Date: Nov 2010
Member: 1450664 Status: Offline Thanks Meter: 168 | k five k19 flash file here is full info. when i press menu button set go off position. but otherwise incomming and outgoing working fine sir Initializing... DA_LIB_VER_3.6.0.2 It is sensing the pinout fast... RXD=4 TXD=8 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6600700900006A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 115200 ok Reading phone HW info... Read info is done. CPU: SC6600L7 Flash: NOR_ST_M30L0T7000T0 setting the Flash Parameters... Settings have been completed! Reading FileSystem info... File System Ver: 0A IMEI 1=910525400520685 IMEI 2=910525400520693 --------NOR_FLASH_CONFIG-------- Flash Bank count=3053507840 EFS sector count=4093710849 File sector count=822169344 Sector size=0x00000000 Flash start addr=0x00000100 Flash size=0x00010000 Fix NV addr=0x00000000 Product information addr=0x00000000 MMI resource addr=0x00000000 ------Auto Format Address------- Start=0x00000000 Size =0x00000100 Read FS info...done |
10-19-2011, 10:00 | #638 (permalink) | |
its hardware problem chack in h/ware. i also face same probem. not done with software . bro AvatorBox Team | |
10-21-2011, 03:35 | #639 (permalink) | |
Member: 703178 Status: Offline Thanks Meter: 6 | Quote:
thanks | |
10-24-2011, 04:33 | #640 (permalink) |
Member: 782530 Status: Offline Thanks Meter: 8,136 | M1 CPU SC6600L WT6226A Flash NOR INTEL 3040L0 M1 CPU SC6600L WT6226A Flash NOR INTEL 3040L0.rar Br AvatorBox Team |
10-25-2011, 10:01 | #643 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Upleta
Member: 449748 Status: Offline Thanks Meter: 162 | Initializing... DA_LIB_VER_3.6.7.1 It is sensing the pinout fast... D-=17 D+=19 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM13 Connected...sending boot... FDL test...OK ArmBootMode: 6610000000E45A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6610/20 Flash: SF_MX25U6435E setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Unlocking all blocks before program/erase... Unlock Done. Analyzing FileSystem... Error: Unknow Signature. Failed to locate the user data partition. allways reset feild not work rocker m80 need it flashfile 8mb |
10-26-2011, 13:59 | #645 (permalink) |
Member: 782530 Status: Offline Thanks Meter: 8,136 | NOKIA S300 3 SIM CPU SC6600L7 Flash NOR_M36C0W6050T0 NOKIA S300 3 SIM CPU SC6600L7 Flash NOR_M36C0W6050T0.rar Br AvatorBox Team |
