always spd detection read info faild fix this bug [Answerd] SPDScaning Pinouts,Need not press Power-Key... <<............ OK. Spread Boot not OK,Please Manually set(Haved All pull down) Definition Applied Scanning USB Serial port... count:=0_ None SU2Serial Port. 1.Please Make sure install the driver 2.The Phone may be required to read and write keys >>3.Pulled low may not, manually set. but the phone boots ok |
Same problem but suporter not help evan 6 month |
may be update ur driver in diag to serial then connect, ur problem will solved. |
Please Post Here With Scan Short By Which JIG Do You Use For Your Require Operation or If Possible With Device Manager Scan Short Br;)http://i-funbox.com/images/banner_icon.png Palash Ahammad |
