how to root & repair imei in n7100 copy how to root & repair imei in n7100 copy Welcome to use miracle box(World's First Fuzzy Logic Based Tool) SoftWare Version 1.63 Update:13-11-01 Firmware Version:1.10 Connected OK. Connecting Internet... You use Latest Miracte Software 1.63 Fuzzy Logic Method is very safe and reliable ! 1.Phone Power off 2.Add SU, is for not normally Root, you can choose this 1. Phone switch on with battery 2. Need to open the USB debugging 3. Setting defined or line to phone 1.Phone Power off 2.Add SU, is for not normally Root, you can choose this SPDScaning Pinouts,Need not press Power-Key... << Phone contact with The Cable bad. Scanned Failure Scanning USB Serial port... count:=0_ None SU2Serial Port. 1.Please Make sure install the driver 2.The Phone may be required to read and write keys 3.Pulled low may not, manually set. Scanning USB Serial port... count:=0_ None SU2Serial Port. 1.Please Make sure install the driver 2.The Phone may be required to read and write keys 3.Pulled low may not, manually set. Connecting to Phone,Wait..ok Hardware:mtk6577 Board:sp6820gb_s510v11 CPU ABI:armeabi-v7a Manufacturer:SND Model:N7100 Android Ver:4.1.1 bootloader ver:unknown User:BuildUser Baseband ver:DM_BASE_12A_W12.43|sc6820_modem|11-02-2012 17:53:08 Build number:6.0.B.3.162 IMEI1: 355889565522525 Root: Not Root Done WARNING : IMEI CHANGE IS ILLEGAL Connecting to Phone,Wait.. Repair IMEI... Connection Done CPU: mtk6577 MODEL: N7100 VSN: 4.1.1 Wait ... WRITING IMEI1 & IMEI2.. /data/l Done Connecting to Phone,Wait.. Abort by User 1. Phone switch on with battery 2. Need to open the USB debugging 3. Setting defined or line to phone SPDScaning Pinouts,Need not press Power-Key... << Phone contact with The Cable bad. Scanned Failure Connecting to Phone,Wait..ok checking info... Model:N7100 Android Ver:4.1.1 Connecting to Phone,Wait..ok ROOT Fail! Connecting to Phone,Wait..ok checking info... Model:N7100 Android Ver:4.1.1 Connecting to Phone,Wait..ok ROOT Fail! 1.Phone Power off 2.Add SU, is for not normally Root, you can choose this Scanning USB Serial port... count:=0_ None SU2Serial Port. 1.Please Make sure install the driver 2.The Phone may be required to read and write keys 3.Pulled low may not, manually set. Scanning USB Serial port... count:=0_ None SU2Serial Port. 1.Please Make sure install the driver 2.The Phone may be required to read and write keys 3.Pulled low may not, manually set. Scanning USB Serial port... count:=0_ None SU2Serial Port. 1.Please Make sure install the driver 2.The Phone may be required to read and write keys >>3.Pulled low may not, manually set. |
just go to mtk tab clcik on root i fthis root option is not work |
after root & repair imei all is same no imei repair Welcome to use miracle box(World's First Fuzzy Logic Based Tool) SoftWare Version 1.63 Update:13-11-01 Firmware Version:1.10 Connected OK. Connecting Internet... You use Latest Miracte Software 1.63 Fuzzy Logic Method is very safe and reliable ! 1.Phone Power off 2.Add SU, is for not normally Root, you can choose this 1. Phone switch on with battery 2. Need to open the USB debugging 3. Setting defined or line to phone 1.Phone Power off 2.Add SU, is for not normally Root, you can choose this SPDScaning Pinouts,Need not press Power-Key... << Phone contact with The Cable bad. Scanned Failure Scanning USB Serial port... count:=0_ None SU2Serial Port. 1.Please Make sure install the driver 2.The Phone may be required to read and write keys 3.Pulled low may not, manually set. Scanning USB Serial port... count:=0_ None SU2Serial Port. 1.Please Make sure install the driver 2.The Phone may be required to read and write keys 3.Pulled low may not, manually set. Connecting to Phone,Wait..ok Hardware:mtk6577 Board:sp6820gb_s510v11 CPU ABI:armeabi-v7a Manufacturer:SND Model:N7100 Android Ver:4.1.1 bootloader ver:unknown User:BuildUser Baseband ver:DM_BASE_12A_W12.43|sc6820_modem|11-02-2012 17:53:08 Build number:6.0.B.3.162 IMEI1: 355889565522525 Root: Not Root Done WARNING : IMEI CHANGE IS ILLEGAL Connecting to Phone,Wait.. Repair IMEI... Connection Done CPU: mtk6577 MODEL: N7100 VSN: 4.1.1 Wait ... WRITING IMEI1 & IMEI2.. /data/l Done Connecting to Phone,Wait.. Abort by User 1. Phone switch on with battery 2. Need to open the USB debugging 3. Setting defined or line to phone SPDScaning Pinouts,Need not press Power-Key... << Phone contact with The Cable bad. Scanned Failure Connecting to Phone,Wait..ok checking info... Model:N7100 Android Ver:4.1.1 Connecting to Phone,Wait..ok ROOT Fail! Connecting to Phone,Wait..ok checking info... Model:N7100 Android Ver:4.1.1 Connecting to Phone,Wait..ok ROOT Fail! 1.Phone Power off 2.Add SU, is for not normally Root, you can choose this Scanning USB Serial port... count:=0_ None SU2Serial Port. 1.Please Make sure install the driver 2.The Phone may be required to read and write keys 3.Pulled low may not, manually set. Scanning USB Serial port... count:=0_ None SU2Serial Port. 1.Please Make sure install the driver 2.The Phone may be required to read and write keys 3.Pulled low may not, manually set. Scanning USB Serial port... count:=0_ None SU2Serial Port. 1.Please Make sure install the driver 2.The Phone may be required to read and write keys 3.Pulled low may not, manually set. Connecting to Phone,Wait.. Abort by User MTKScaning Pinouts,Please press Power-Key... <<.... Abort by User Waiting for USB Port... if Input is space, read sn WARNING : IMEI CHANGE IS ILLEGAL Waiting for USB Port... none usbport, maybe driver not installed if Input is space, read sn WARNING : IMEI CHANGE IS ILLEGAL Please Turn on your phone by battery before pressing START Waiting for USB Port... Abort by User none usbport, maybe driver not installed Please Turn on your phone by battery before pressing START Waiting for USB Port... 1.Phone Power off 2.Add SU, is for not normally Root, you can choose this 3.Clear code for USB debugging can not manually open 4.With clear code function Cleared password, please recover ROOT none usbport, maybe driver not installed Waiting for USB Port... Waiting for USB Port... Set MediaTek PreLoader USB VCOM (Android) (COM30) Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6575 SW: E201 Ver: CB00 Downloading Boot8 ... Nand Flash Type: NOR_NEW_0071 Nand Flash Code: 009800BC(00900066) Nand Flash Size: 0x21000000 Hex Bytes INT/EXT RAM Size: 0xC4800+0x0 Reading ROOT DATA...5C0000_A00000 C:\Program Files\miracle box\MTK6575nandboot1311012020.img Writing ROOT DATA...5C0000_A00000 Root OK. total?? 1 mins31 s if Input is space, read sn WARNING : IMEI CHANGE IS ILLEGAL Waiting for USB Port... Set MediaTek PreLoader USB VCOM (Android) (COM30) Open Port Err: *** the Port be occupied. Waiting for USB Port... Set MediaTek PreLoader USB VCOM (Android) (COM30) Please Hold "ON" to connect with the phone... Waiting for USB Port... Set Connecting AT Mode Test Mode, Reading Information From the Phone... W IMEI1 OK: 35525602145727-9 W IMEI2 OK: 35950200278134-4 W IMEI3 OK: 35950200278134-4 R IMEI4 OK: FFFFFFFFFFFFFF-15 if Input is space, read sn >>WARNING : IMEI CHANGE IS ILLEGAL |
try with version 1.54 and post result |
