Old 05-10-2013, 16:28   #1 (permalink)
Member: 1847344
Thanks Meter: 300
Karbonn A6 Too Many Pettern Lock Solved By Miracle Box
karbon a6 how to remove google account
Old 05-10-2013, 17:30   #2 (permalink)
Member: 1847344
Thanks Meter: 300
karbonn a6
Definition Applied
Scanning USB Serial port...
SU2Serial Port: COM16
Connecting to Phone,Wait..
>>Please RePower on & off
not format
please solution
Old 05-10-2013, 17:51   #3 (permalink)
Member: 1847344
Thanks Meter: 300
android karbonn a6 to many petern unlock solve
SU2Serial Port: COM124
Done.
Infor: SPRD3
Initialize boot13...
Formating...
>>Format Completed.
intruction start bottun then insert usb cable press volume up key
The Following User Says Thank You to shamsulhaq For This Useful Post:
Old 05-10-2013, 18:38   #4 (permalink)
maanarman's Avatar
Member: 686395
Sonork: 100.1608345
Thanks Meter: 3,822
Good job bro post in successful story
Old 05-13-2013, 18:00   #5 (permalink)
fahad ali khan's Avatar
Member: 1771086
Thanks Meter: 2,410
www.youtube.com/watch?v=xDadwnC2rME
Old 05-22-2013, 09:21   #6 (permalink)
Member: 314589
Thanks Meter: 3
Good job
100% cucceess keep it up bro
Old 07-24-2013, 12:08   #7 (permalink)
Member: 1417077
Sonork: 100.1626477
Thanks Meter: 32
1,re insert battery and press volume + button and connect the mobile to system via usb cable
2;insert the drivers correctly
3.disconnect phone
4;open miracle select spd and select spd 8810/6820
5;select format and press start
6;insert battery to phone and press holding volume+ and connect the phone
7; wait for finish
The Following User Says Thank You to anu remesh For This Useful Post:
Old 08-19-2013, 09:41   #8 (permalink)
Member: 1730888
Thanks Meter: 6
SU2Serial Port: COM54
Done.
Infor: SPRD3
CPU type: 8810/6820
Flash type: NAND
Flash ID: 002C00BC
Flash Model: Micron MT29C4G48MAZAPAKD
Flash Size: 0x20000000(512.0M)
Being analyzed,Wait...
>>Analyzed data Failure.
Old 08-19-2013, 09:59   #9 (permalink)
Harish Gulati's Avatar
Member: 1750704
Thanks Meter: 12,171
Done.
Infor: SPRD3
CPU type: 8810/6820
Flash type: NAND
Flash ID: 002C00BC
data not anlyze from set
so u have to flash ur set
The Following User Says Thank You to Harish Gulati For This Useful Post:
Old 08-21-2013, 12:22   #10 (permalink)
Member: 1730888
Thanks Meter: 6
sir some times datta analysed ok
and flash files gives erro duing dowwnload
r
Old 08-21-2013, 12:33   #11 (permalink)
Member: 1732503
Sonork: bip
Thanks Meter: 8
successfully unlock samsung octopus s5360T
successfully-unlocked for samsung octopus
root with s5360
Platform: Samsung Broadcom
Selected port: COM27
Selected model: GT-S5360
Detected phone model: GT-S5360
SW Version:
S5360TAJKK3/S5360TTLPKK3/S5360TAJKK3/S5360TAJKK3
HW Version: GT-S5360MATTLP
Phone IMEI A: 358757-04-641405-1
Firmware compiled date: Thu Nov 17 19:18:49 KST 2011
Android version: 2.3.6 (GINGERBREAD)
Unlocking phone...
Phone is successfully unlocked
Please, restart the phone to apply changes
test by mi enjoy..............
Old 08-21-2013, 12:49   #12 (permalink)
Member: 1730888
Thanks Meter: 6
file gives error during download pls help Welcome to the ./downloads/Karbonn/A6/ folder of the support area for your service center
Old 08-31-2013, 05:55   #13 (permalink)
Member: 1482335
dont worry brother do flash your set will be ok this file also ok its tasted by me 1000000000000% ok
Old 09-06-2013, 18:29   #14 (permalink)
Member: 628435
please can you help me restore my samsung s5360 I'm Online
Old 09-06-2013, 23:02   #15 (permalink)
.::PankajMobileWorld::.'s Avatar
Member: 1910515
Thanks Meter: 289
Karbonn A6 Pattern Lock solve by miracle box
Thanks to Harish Gulati
Page generated in 0.21568 seconds with 8 queries
