micromaxx a62 not supported cpc 8810 pls help Welcome to use miracle box(World's First Fuzzy Logic Based Tool) SoftWare Version 1.89 Update:14-07-08 Firmware Version:1.12 Connected OK. Connecting Internet... You use Latest Miracte Software 1.89 Fuzzy Logic Method is very safe and reliable ! Please scan ports first! SPDScaning Pinouts,Need not press Power-Key... <<..... OK. Spread Boot not OK,Please Manually set(Haved All pull down) Definition Applied Scanning USB Serial port... count:=0_ None SU2Serial Port. 1.Please Make sure install the driver 2.The Phone may be required to read and write keys >>3.Pulled low may not, manually set. br 3cellcare |
This boot problem not driver problem use boot key |
