Old 12-23-2016, 08:37   #22201 (permalink)
::kisna::'s Avatar
Member: 2643267
Thanks Meter: 378
Karboon Octasne plus Dead Recovered With FLash By
Miracle Box And Key
Old 12-23-2016, 08:37   #22202 (permalink)
::kisna::'s Avatar
Member: 2643267
Thanks Meter: 378
Micromax Q380 Recovery mode Solved With Flash By
Miracle Box And Key
Old 12-23-2016, 08:37   #22203 (permalink)
::kisna::'s Avatar
Member: 2643267
Thanks Meter: 378
Lava KKT08+ Dead Recovered With Flash By
Miracle Box And Key
Old 12-23-2016, 10:13   #22204 (permalink)
Safyan sufi's Avatar
Member: 2221849
Sonork: offline
Thanks Meter: 279
Alcatel One Touch 4071X read scatter file done
Old 12-23-2016, 19:32   #22205 (permalink)
khalidahmed's Avatar
Member: 2298142
Thanks Meter: 240
Thanks Miracle tem.worlt great and great tem.always help and new solutions give...
Old 12-24-2016, 05:55   #22206 (permalink)
DALIM SARKAR's Avatar
Member: 1703431
Sonork: 100.1619192 QQ 3271159180
Thanks Meter: 2,104
SYMPHONY E75 SPD 7715 EMMC Pattern Lock Read Without Data Loss Done By Miracle Box
SYMPHONY E75 SPD 7715 EMMC Pattern Lock Read Without Data Loss Done By Miracle Box+Key
The Following User Says Thank You to DALIM SARKAR For This Useful Post:
Old 12-24-2016, 05:57   #22207 (permalink)
Member: 1703431
Thanks Meter: 2,104
Lenovo A319 Auto Wi-Fi On With Simple Flash Done By Miracle Box+Key
Old 12-24-2016, 05:59   #22208 (permalink)
Member: 1703431
Thanks Meter: 2,104
SYMPHONY W69 Hang On Logo With Format Done By Miracle Box+Key
Old 12-24-2016, 06:02   #22209 (permalink)
Member: 1703431
Thanks Meter: 2,104
Micromax X324 On Hang Logo Solved Fash Done By Miracle Box+Key
Old 12-24-2016, 06:11   #22210 (permalink)
Member: 1703431
Thanks Meter: 2,104
LAVA Flair P1 SPD 7715 EMMC Apps Lock Remove With Format Done By Miracle Box+Key
Old 12-24-2016, 07:41   #22211 (permalink)
Member: 1703431
Thanks Meter: 2,104
Winstar W777 SC 6531DA Dead Recover Fash Done By Miracle Box+Key
Old 12-24-2016, 08:00   #22212 (permalink)
Member: 2233266
Thanks Meter: 252
samsung j200h adb diver not detect. so many problem. personal solution. mobile dowenlode mode (flash mode) miracle box open and scan usb modem drive and select frp tab. just click start batton. now enjoy frp remove. (hepl 01918892995).
(mrs jhalokati talecom)
Old 12-24-2016, 09:03   #22213 (permalink)
Member: 1313725
Thanks Meter: 22
Could not connect server while opening miracle box
Old 12-24-2016, 09:11   #22214 (permalink)
azaan.skp's Avatar
Member: 2242730
Thanks Meter: 42
Club Mobile Spice MT 6236 Format and logo hang done by Miracle box.
1. Power Off Phone , Remove Battery, Insert Battery Back
2. Insert USB cable. In some cases Required Hold BootKey
3. Use Miracle Boot Key In cases Boot key not Find
4. Battery Should be Charged more then 50%
you can Set Formatting Addr
Waiting for USB Port...
Set MTK USB Port (COM201)
Please Hold "ON" to connect with the phone...
Connected to Phone.
CPU: MT6236_S8A00 Ver: 8A02 md:0000
Downloading Boot6 ...
Nand Flash Type: [TOSHIBA] TC58NYG0S8C
Nand Flash Code: 009800B1(00000055)
Nand Flash Size: 0x8000000 Hex Bytes
INT/EXT RAM Size: 0x18000+0x4000000
Formatting Nand Flash...
Format Satrt Addr??0x4000000, Size: 0x4000000
>>Format nand OK(Android Need to wait a few minutes the phone is switched)
Old 12-24-2016, 11:43   #22215 (permalink)
Member: 940552
Thanks Meter: 3
Thanks Miracle Team For Update....
Page generated in 0.39762 seconds with 10 queries
