Miracle Box GSMCampus |
12-31-2016, 09:44 | #22418 (permalink) |
No Life Poster Join Date: Nov 2015
Member: 2488031 Status: Offline Sonork: 100.1662695 Thanks Meter: 1,947 | QMobile I6i MT6580 FRP Reset By Format Done Done By Miracle Box+Key QMobile I6i MT6580 FRP Reset By Format Done Done By Miracle Box+Key Read Info Code: Definition Applied 1. Power Off Phone , Remove Battery, Insert Battery Back 2. Insert USB cable. In some cases Required Hold BootKey 3. Use Miracle Boot Key In cases Boot key not Find 4. Battery Should be Charged more then 50% Waiting for USB Port... Set MediaTek PreLoader USB VCOM (Android) (COM8) Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6580 SW:0000 Ver: CA00 Downloading Boot8 ... EMMC Size: 0x00E9000000 Flash Type: EMMC INT/EXT RAM Size: 0x20000/0x30000000 Reading infr(EMMC)... WIFI MAC:BC4434C77684 BT_ADDR:BC4434C83DEE IMEI1:354242072944127 IMEI2:354242077944122 id:ALPS.L1.MP6.V2_TINNO6580.WE.L version:5.1 model:QMobile i6i brand:QMobile manufacturer:QMobile PROINFO BaseAddr:0x80000 Size:0x300000 NVRAM BaseAddr:0x380000 Size:0x500000 PROTECT1 BaseAddr:0x880000 Size:0xA00000 PROTECT2 BaseAddr:0x1280000 Size:0xA00000 SECCFG BaseAddr:0x1C80000 Size:0x40000 LK BaseAddr:0x1CC0000 Size:0x60000 BOOT BaseAddr:0x1D20000 Size:0x1000000 RECOVERY BaseAddr:0x2D20000 Size:0x1000000 PARA BaseAddr:0x3D20000 Size:0x80000 LOGO BaseAddr:0x3DA0000 Size:0x800000 EXPDB BaseAddr:0x45A0000 Size:0xA00000 FRP BaseAddr:0x4FA0000 Size:0x100000 NVDATA BaseAddr:0x50A0000 Size:0x2000000 METADATA BaseAddr:0x70A0000 Size:0x2760000 OEMKEYSTORE BaseAddr:0x9800000 Size:0x200000 SECRO BaseAddr:0x9A00000 Size:0x600000 KEYSTORE BaseAddr:0xA000000 Size:0x800000 SYSTEM BaseAddr:0xA800000 Size:0x4D800000 CACHE BaseAddr:0x58000000 Size:0x8000000 USERDATA BaseAddr:0x60000000 Size:0x87F80000 FLASHINFO BaseAddr:0xE7F80000 Size:0x1000000 Done. Format Code: Definition Applied 1. Power Off Phone , Remove Battery, Insert Battery Back 2. Insert USB cable. In some cases Required Hold BootKey 3. Use Miracle Boot Key In cases Boot key not Find 4. Battery Should be Charged more then 50% Definition Applied you can Set Formatting Addr Waiting for USB Port... Set MediaTek PreLoader USB VCOM (Android) (COM8) Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6580 SW:0000 Ver: CA00 Downloading Boot8 ... EMMC Size: 0x00E9000000 Flash Type: EMMC INT/EXT RAM Size: 0x20000/0x30000000 Formatting Nand Flash... Format Satrt Addr??0x4FA0000, Size: 0x100000 Format nand OK(Android Need to wait a few minutes the phone is switched) Br Suny125 Miracle Team |
12-31-2016, 09:52 | #22419 (permalink) |
Member: 2488031 Status: Offline Sonork: 100.1662695 Thanks Meter: 1,947 | QMobile I6i MT6580 Pattern Read Done By Miracle Miracle Box+Key QMobile I6i MT6580 Pattern Read Done By Miracle Miracle Box+Key Code: Definition Applied 1. Power Off Phone , Remove Battery, Insert Battery Back 2. Insert USB cable. In some cases Required Hold BootKey 3. Use Miracle Boot Key In cases Boot key not Find 4. Battery Should be Charged more then 50% Waiting for USB Port... Set MediaTek PreLoader USB VCOM (Android) (COM8) Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6580 SW:0000 Ver: CA00 Downloading Boot8 ... EMMC Size: 0x00E9000000 Flash Type: EMMC INT/EXT RAM Size: 0x20000/0x30000000 Being analyzed DATA... CODE: 1587 1 2 3 4 5 6 7 8 9 >>Done. Br Suny125 Miracle Team |
12-31-2016, 10:03 | #22420 (permalink) |
Member: 2488031 Status: Offline Sonork: 100.1662695 Thanks Meter: 1,947 | Samsung Galaxy S II HD LTE SHV-E120S Read Info / Factory Reset Done ByMiracle Box+Key Samsung Galaxy S II HD LTE SHV-E120S Read Info / Factory Reset Done By Miracle Box+Key Read Info Code: Definition Applied Connecting to Phone,Wait...Done Getting phone Infor... MN(SHV-E120S) BASE(GT-I9300) VER(E120SKSJMK1/E120SKSJMK1/E120SKSLL6/E120SKSLL6) HIDVER(E120SKSJMK1/E120SKSJMK1/E120SKSLL6/E120SKSLL6) MNC() MCC() PRD(SKT) SN(72d93756) IMEI(358362042866089) PN() CON(AT,UMS,UMS) LOCK(NONE) LIMIT(FALSE) SDP(RUNTIME) HVID(Data:196609,Cache:262145,System:327681) Done! Factory Reset Code: Definition Applied Connecting to Phone,Wait...Done Factory Resetting Phone... Please Wait >>Done!Phone will Restart Now. Br Suny125 Miracle Team |
The Following 2 Users Say Thank You to Suny125 For This Useful Post: |
12-31-2016, 12:55 | #22421 (permalink) |
Junior Member Join Date: Dec 2016 Location: Ghazni Afghanistan
Member: 2661274 Status: Offline Thanks Meter: 1 | I have made a big mistake that I bought Miracle box what is wrong with this lazy box, it even can't read or reset pattern lock of most chines mobile, today i tried to reset pattern lock and pin lock of Alcatel one touch 5020d mtk cpu, and one gt-i9260 chine spd cpu, but this lazy team and lazy box failed to do so,. the miracle chines mtk ii box is 100% better than miracle box. it is totally a waste of money to buy this box.:mad |
12-31-2016, 13:11 | #22422 (permalink) |
Member: 2661274 Status: Offline Thanks Meter: 1 | My suggestion for Miracle team: before buying miracle box. I used to use miracle chines mtk ii box, miracle chines mtk ii really does great work, and it reads any type of chines mobile and can reset any password of chines mobile in a blink of eye. so my suggestion for Miracle box team is that u at least learn from miracle chines mtk ii box. |
12-31-2016, 14:24 | #22423 (permalink) |
No Life Poster Join Date: Aug 2015 Location: Bd+
Member: 2441719 Status: Offline Sonork: uninstall Thanks Meter: 2,073 | Symphony V75 Frp Lock Remove Done By Miracle Box+Key Symphony V75 Frp Lock Remove Done By Miracle Box+Key |
The Following User Says Thank You to iOS_Shakil For This Useful Post: |
12-31-2016, 14:25 | #22424 (permalink) |
Member: 2441719 Status: Offline Sonork: uninstall Thanks Meter: 2,073 | Samsung J500H Read Info And Reset Frp Lock Done By Miracle Box+Key Samsung J500H Read Info And Reset Frp Lock Done By Miracle Box+Key |
12-31-2016, 14:26 | #22425 (permalink) |
Member: 2441719 Status: Offline Sonork: uninstall Thanks Meter: 2,073 | Samsung G360H Read Info And Pattern lock Remove Done By Miracle Box+Key Samsung G360H Read Info And Pattern lock Remove Done By Miracle Box+Key |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
All 4 locks on 6110 | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 04-19-2010 02:44 |
i can unlock all nokia 5110/6110/6150 | spterminator | Main Sales Section | 0 | 07-30-1999 03:05 |
all for GSM: http://fly.to/spear | spear | GSM Mobile Links | 0 | 07-11-1999 22:01 |
