Old 09-18-2017, 06:01   #26941 (permalink)
DALIM SARKAR's Avatar
Member: 1703431
Sonork: 100.1619192 QQ 3271159180
Thanks Meter: 2,104
SYMPHONY Xplorer W69 On Stuck On Logo Solved With Flash Done By Miracle Box
Old 09-18-2017, 06:03   #26942 (permalink)
Member: 1703431
Thanks Meter: 2,104
Lenovo A327i On Stuck On Logo Solved With Flash Done By Miracle Box
Old 09-18-2017, 06:04   #26943 (permalink)
Member: 1703431
Thanks Meter: 2,104
SYMPHONY Xplorer W72 Hang On Logo With Format Done By Miracle Box
Old 09-18-2017, 06:07   #26944 (permalink)
Member: 1703431
Thanks Meter: 2,104
SYMPHONY Xplorer W16 Pattern Lock Read Done By Miracle Box
Old 09-18-2017, 10:14   #26945 (permalink)
Member: 2750710
Sonork: 100.650600
Thanks Meter: 7
INTEX AQUA ACE V05 INDIAN SER FRP REMOVE
MARICLE BOX ONE CLICK
Definition Applied
1. Power Off Phone , Remove Battery, Insert Battery Back
2. Insert USB cable. In some cases Required Hold BootKey
3. Use Miracle Boot Key In cases Boot key not Find
4. Battery Should be Charged more then 50%
Waiting for USB Port...
Set MTK USB Port (COM20)
Connecting to Phone,Wait..
Connected to Phone.
CPU: MT6735 SW:0000 Ver: CA00
Downloading Boot8 ...
EMMC Size: 0x03A3E00000
Flash Type: EMMC
INT/EXT RAM Size: 0x20000/0xC0000000
Reset Setting...
>>Done.(Need to wait a few minutes the phone is switched)
Old 09-18-2017, 11:48   #26946 (permalink)
orhan5's Avatar
Member: 2621892
Sonork: 1677742
Thanks Meter: 459
Starting...
Selected Port : COM14 (Qualcomm HS-USB QDLoader 9008 )
Device Programmer : prog_emmc_firehose_8909_ddr.mbn
Raw File : rawprogram0.xml.bak
Patch File : patch0.xml
Flashing Programmer : prog_emmc_firehose_8909_ddr.mbn
Reading Data : Please Wait
Mapping Files.. Please Wait
Unpacking File : amss.mbn
Unpacking File : apps.mbn
Unpacking File : dsp1.mbn
Unpacking File : dbl.mbn
Unpacking File : osbl.mbn
Unpacking File : dsp2.mbn
Unpacking File : efs1.mbn
Unpacking File : efs2.mbn
Unpacking File : efs3.mbn
Unpacking File : sbl1.mbn
Unpacking File : sbl2.mbn
Unpacking File : rpm.mbn
Unpacking File : tz.mbn
Unpacking File : dsp3.mbn
Unpacking File : acdb.mbn
Unpacking File : wdt.mbn
Unpacking File : mba.mbn
Unpacking File : C:\Users\ORHAN5\Downloads\Compressed\CASPER E1C FRP\prog_emmc_firehose_8909_ddr.mbn
Unpacking File : Requested ID 13, file: "C:\Users\ORHAN5\Downloads\Compressed\CASPER E1C FRP\prog_emmc_firehose_8909_ddr.mbn
Writing File.. ok
Switching Mode.. Please Wait
Flashing File : rawprogram0.xml.bak
Starting Flash Task...
Loading File.. 'rawprogram0.xml.bak'
Loading File : rawprogram0.xml.bak
Opening Port : COM14 (Qualcomm HS-USB QDLoader 9008 )
Loading File : NON-HLOS.bin
Unpacking File : WARNING: Couldn't find the file 'sbl1.mbn
Unpacking File : {ERROR: 'sbl1.mbn
Flashing File : patch0.xml
Loading File.. 'patch0.xml'
Loading File : patch0.xml
Writing Configuration..
Xml Written Successfully..
Running Post Flash Tasks
Setting Bootable Drive..
>>All Done - Please Check Phone Screen.
Old 09-18-2017, 15:11   #26947 (permalink)
Thanks Meter: 4,075
Gionee P5L FRP Reset Done In One Click By Miracle Box
Old 09-18-2017, 15:13   #26948 (permalink)
Thanks Meter: 4,075
Intex Cloud Q11 4G FRP Reset Done In One Click By Miracle Box
Old 09-18-2017, 15:14   #26949 (permalink)
Thanks Meter: 4,075
Lenovo A536 Dead Recover Done By Miracle Box
Old 09-19-2017, 09:09   #26950 (permalink)
Member: 2750710
Sonork: 100.650600
Thanks Meter: 7
ZEN ADMIRE BUZZ FRP RESET SPD 9830 CPU
MARICLE BOX IN ONE CLICK
MARICLE BOX 2.55
Definition Applied
2. Please Hold BootKey(UP and DOWN),Insert USB cable
Scanning USB Serial port...
SU2Serial Port: COM37
Done.
Infor: SPRD3
Initialize boot25...
Reset Frp...
>>Done.
Old 09-19-2017, 15:48   #26951 (permalink)
Thanks Meter: 4,075
Intex Aqua Y4 Stuck On Logo Done By Miracle Box
Old 09-19-2017, 15:50   #26952 (permalink)
Thanks Meter: 4,075
Lenovo A6000 Stuck On Logo Done By Flash With Miracle Box
Old 09-19-2017, 15:52   #26953 (permalink)
Thanks Meter: 4,075
Lenovo X3a40 Dead Recover Done By Miracle Box
Old 09-19-2017, 15:53   #26954 (permalink)
Thanks Meter: 4,075
Oppo A33F Imei Repair Done In One Click Without Root Only With Miracle Box
Note: Imei Change illegal In Some Country And Miracle Team AND GSMHOSTING Did Not Support Any illegal Activities If You Do This Do It Your Own Risk
Our Tool Only For Repair Damage Imei Form Phone Back Sticker
Old 09-20-2017, 13:36   #26955 (permalink)
Member: 1703431
Thanks Meter: 2,104
Samsung SM-J500F (Galaxy J5) Pattern Lock Remove Factory Reset Done By Miracle Box
Page generated in 0.38061 seconds with 10 queries
