Old 10-18-2014, 17:29   #6466 (permalink)
maanarman's Avatar
Member: 686395
Sonork: 100.1608345
Thanks Meter: 3,822
Samsung gt-n9300 info wipe done
SAMSUNG GT-N9300 INFO WIPE DONE
THANKS TO MIRACLE BOX
Old 10-18-2014, 17:30   #6467 (permalink)
maanarman's Avatar
Member: 686395
Sonork: 100.1608345
Thanks Meter: 3,822
Htc desire hd read info and wipe done
HTC DESIRE HD READ INFO AND WIPE DONE
Old 10-18-2014, 17:32   #6468 (permalink)
maanarman's Avatar
Member: 686395
Sonork: 100.1608345
Thanks Meter: 3,822
More x2-02 flash done
MORE X2-02 FLASH DONE
The Following User Says Thank You to maanarman For This Useful Post:
Old 10-18-2014, 17:34   #6469 (permalink)
maanarman's Avatar
Member: 686395
Sonork: 100.1608345
Thanks Meter: 3,822
Mtk 108 flash done
MTK 108 FLASH DONE
Old 10-19-2014, 08:24   #6470 (permalink)
.::THE ROCK::.'s Avatar
Member: 1617868
Sonork: 100.1625996
Thanks Meter: 2,028
Micromax a72 pattern unlock
Welcome to use miracle box(World's First Fuzzy Logic Based Tool)
SoftWare Version 1.92 Update:14-09-01
Firmware Version:1.12
Connected OK.
Connecting Internet...
Check the new version. updating ...
Fuzzy Logic Method is very safe and reliable !
1.Phone Power off
2.Add SU, is for not normally Root, you can choose this
3.Clear code for USB debugging can not manually open
4.With clear code function Cleared password, please recover ROOT
Waiting for USB Port...
Set Micromax A110 PreLoader USB VCOM Port (COM20)
Please Hold "ON" to connect with the phone...
Connected to Phone.
CPU: MT6575 SW: E201 Ver: CB00
Downloading Boot8 ...
Nand Flash Type: NOR_NEW_006E
Nand Flash Code: 002C00BC(00900055)
Nand Flash Size: 0x21000000 Hex Bytes
INT/EXT RAM Size: 0xC4800+0x0
Reading ROOT DATA...480000_500000
C:\Program Files\Miracle Box\MTK6575nandboot1410191246.img
Writing ROOT DATA...480000_500000
Root OK.
Done (Enter Any Pattern To Unlock Screen)
total?? 0 mins38 s
Connecting to Phone,Wait..ok
Hardware:mt6575
Board:lcsh75cu_gb2
CPU ABI:armeabi-v7a
Manufacturer:alps
Model:micromax a72
Android Ver:2.3.6
bootloader ver:unknown
User:release
Baseband ver:maui.11amd.w11.50.sp.v30, 2013/04/07 09:55
Build number:alps.gb2.mp.v2.21
Region:us
Language:en
Chipset:
IMEI1:9113071+++++++
IMEI2:9113071+++++++
Root: Rooted
Done
Wipe data...
>>Done
Old 10-19-2014, 09:31   #6471 (permalink)
maanarman's Avatar
Member: 686395
Sonork: 100.1608345
Thanks Meter: 3,822
Q mobile a600 read info and wipe done
Q MOBILE A600 READ INFO AND WIPE DONE
Old 10-19-2014, 09:32   #6472 (permalink)
maanarman's Avatar
Member: 686395
Sonork: 100.1608345
Thanks Meter: 3,822
Samsung m100s read info and reset factory done
SAMSUNG M100S READ INFO AND RESET FACTORY DONE
Old 10-19-2014, 09:35   #6473 (permalink)
maanarman's Avatar
Member: 686395
Sonork: 100.1608345
Thanks Meter: 3,822
Q mobile m400 flash done
Q MOBILE M400 FLASH DONE
Old 10-19-2014, 13:59   #6474 (permalink)
Member: 2249798
Thanks Meter: 26
lava 135...
lava 135 successfully formated by miracle.....
Old 10-19-2014, 14:41   #6475 (permalink)
konok.kk's Avatar
Member: 1089621
Sonork: kk
Thanks Meter: 62
MTK 6252 Imei Write Done
Definition Applied
Set MTK USB Port (COM4)
CPU: MT6252 Ver: CA05 SW:0101
Test Mode, Reading Information From the Phone...
UnLock Code: 1122
R IMEI1 OK: FFFFFFFFFFFFFF-15
R IMEI2 OK: FFFFFFFFFFFFFF-15
NONE IMEI3
NONE IMEI4
if Input is space, read sn
WARNING : IMEI CHANGE IS ILLEGAL
Definition Applied
W IMEI1 OK: 35565822776814-6
W IMEI2 OK: 35565822851659-3
NONE IMEI3
NONE IMEI4
Old 10-20-2014, 06:20   #6476 (permalink)
Member: 1617868
Sonork: 100.1625996
Thanks Meter: 2,028
Nokia 108 blinking solved
Connected OK.
Set MediaTek PreLoader USB VCOM Port (COM10)
Connected to Phone.
CPU: MT625A_S0001 Ver: CA01 md:8000
Downloading Boot9 ...
Nor/SF Flash Type: [WINBOND] W25Q32BV
Nor Flash Code: 00400000(00EF0040)
Nor/SF Flash Size: 0x400000 Hex Bytes
Nand Flash Type: NOR_NEW_FF00
Nand Flash Code: 00000000
Nand Flash Size: 0x0 Hex Bytes
INT/EXT RAM Size: 0xFFFF0000+0x0
Reading infr(Nor)...
The phone information:
BREE50D_PCB01_GSM_MT6250_S00.BREE_10_04_11_P2.BIN
the file not be encrypted
Done.
Definition Applied
you can Set Formatting Addr
Connected to Phone.
Formatting Nor Flash...
Format Start Addr: 0x3A6000, Size: 0x4E000
>>Formatted OK.
Old 10-20-2014, 09:25   #6477 (permalink)
konok.kk's Avatar
Member: 1089621
Sonork: kk
Thanks Meter: 62
SPRD6531A Read Security Code Done
Definition Applied
Scanning USB Serial port...
SU2Serial Port: COM17
Done.
Infor: SPRD3
Initialize boot9...
CPU type: 6531A
Flash type: NOR
Flash ID: 00EF0040(00160000)
Flash Model: W25Q32BV
Flash Size: 0x400000(4.0M)
Being analyzed,Wait...
IMEI1 :357725040326457
IMEI2 :357725040326465
IMEI3 :358570010103893
IMEI4 :910575601400468
Unlock Code: 7649
Unlock Code: 1234
If try all code and wrong, please read whole flash and then analyzed
Old 10-20-2014, 12:30   #6478 (permalink)
Member: 1764566
Sonork: SUSPENDED
Thanks Meter: 5,835
Intex Aqua Star Dead recover Done By Miracle Box
Intex Aqua Star Dead recover Done By Miracle Box while og ToOl Error
The Following User Says Thank You to IMRAN_ANSARI For This Useful Post:
Old 10-20-2014, 12:33   #6479 (permalink)
Member: 1764566
Sonork: SUSPENDED
Thanks Meter: 5,835
Videocon A24 Unknown Baseband Repair IMEI Solved Only By Miracle Box
Videocon A24 Unknown Baseband Repair IMEI Solved Only In % seconds Only By Miracle Box
Unknown Baseband Solved
Repair IMEI
The Following 3 Users Say Thank You to IMRAN_ANSARI For This Useful Post:
Old 10-20-2014, 12:35   #6480 (permalink)
Member: 1764566
Sonork: SUSPENDED
Thanks Meter: 5,835
Samsung S5360 Factory Reset Done
Samsung S5360 Factory Reset Done by Miracle Box
Page generated in 0.45363 seconds with 10 queries
