Old 10-06-2012, 16:42   #1126 (permalink)
Member: 921094
Sonork: 100.1603246
Thanks Meter: 326
Mtk 1130 format
MTK 1130 FORMAT
Old 10-06-2012, 17:40   #1127 (permalink)
maanarman's Avatar
Member: 686395
Sonork: 100.1608345
Thanks Meter: 3,822
Qmobile e950 power off after 30sec
Old 10-07-2012, 09:18   #1128 (permalink)
maanarman's Avatar
Member: 686395
Sonork: 100.1608345
Thanks Meter: 3,822
Welcome to use miracle box(World's First Fuzzy Logic Based Tool)
SoftWare Version 1.28 Update:12-09-28
S/N: >>>>>About
Firmware Version:1.05
Connected OK.
Connecting Internet...
Network connected error
Fuzzy Logic Method is very safe and reliable !
Definition Applied
Definition Applied
Definition Applied
you can Set Formatting Addr
Please Hold "ON" to connect with the phone...
Connected to Phone.
CPU: MT6235_S8A01 Ver: 8C00 md:0000
Downloading Boot6 ...
Nand Flash Type: [HYNIX] HY27xA081G1M/A
Nand Flash Code: 00AD0079(00A50000)
Nand Flash Size: 0x8400000 Hex Bytes
Formatting Nand Flash...
Format Satrt Addr£º0x3000000, Size: 0x5000000
Nand bad Block: 1
Format nand OK
if Input is space, read sn
WARNING : IMEI CHANGE IS ILLEGAL
Changing Android IMEI:
1.Turn on the phone by battery
2.Enter the menu: Set --> development --> USB debug(Activate)
3.Insert USB cable or define USB pinout, install android driver
4.Select function IMEI(switched on)
5.Input IMEI1 or IMEI2 , press START
Definition Applied
Abort by User
Definition Applied
CPU: MT6235 Ver: 8C00 SW:8A01
Test Mode, Reading Information From the Phone...
NONE IMEI
Definition Applied
Please Turn on your phone by battery before pressing START
Connectted
Changing IMEI1
>>NONE WRSN OK
Old 10-07-2012, 14:53   #1129 (permalink)
Member deceased !!
R@SEL.NET's Avatar
Member: 670820
Sonork: 100.1583728
Thanks Meter: 1,348
symphony d30 read code done..
S/N: >>>>>About
Connected OK.
You use Latest Miracte Software 1.28
Definition Applied
Definition Applied
CPU: MT6252 Ver: CB02 SW:0101
UnLock Code: 08963
R IMEI1 OK: 35503703385570-4
R IMEI2 OK: 35503703390370-2
NONE IMEI3
>>NONE IMEI4
Old 10-07-2012, 16:32   #1130 (permalink)
maanarman's Avatar
Member: 686395
Sonork: 100.1608345
Thanks Meter: 3,822
QMOBILE E900 HANG PROBLEM
Old 10-07-2012, 16:33   #1131 (permalink)
maanarman's Avatar
Member: 686395
Sonork: 100.1608345
Thanks Meter: 3,822
XPTEL 1130 FLASHING
Old 10-07-2012, 16:36   #1132 (permalink)
maanarman's Avatar
Member: 686395
Sonork: 100.1608345
Thanks Meter: 3,822
DIESEL D700 READ FLASH AND FORMAT OK
S/N: >>>>>About
Connected OK.
Definition Applied
Definition Applied
Connected to Phone.
CPU: MT6252A(6250)_S0101 Ver: CA05 md:8B00
Downloading Boot7 ...
Nor Flash Type: [WINBOND] W25Q16CV
Nor Flash Code: 00EF0040(00150000)
Nor Flash Size: 0x200000 Hex Bytes
Verifying Baud...
Set Baud:921600 OK.
Reading(Nor)...
The phone information:
HEXING52_10A_GEMINI16_PCB01_GSM_MT6252_S01.T219_14 K_XDF_DL_DC_L06_V10.BIN
the file not be encrypted
Read OK.
Total time: 0 mins 25 s
File Save to: C:\Documents and Settings\Administrator\Desktop\D700 DIESEL HEXING52_10A_GEMINI16_PCB01_GSM_MT6252_S01.T219_14 K_XDF_DL_DC_L06_V10
Definition Applied
Definition Applied
Connected to Phone.
Formatting Nor Flash...
Format Start Addr: 0x1DD000, Size: 0x23000
Formatted OK.
Definition Applied
CPU: MT6252 Ver: CA05 SW:0101
W IMEI1 OK: 35120903459614-0
W IMEI2 OK: 35120903426284-2
NONE IMEI3
>>NONE IMEI4
Old 10-07-2012, 16:38   #1133 (permalink)
maanarman's Avatar
Member: 686395
Sonork: 100.1608345
Thanks Meter: 3,822
NOAL Q60 HANG ON FIRST LOGO
Old 10-07-2012, 16:42   #1134 (permalink)
maanarman's Avatar
Member: 686395
Sonork: 100.1608345
Thanks Meter: 3,822
QMOBILE E950 MSG NOT SENT PROBLEM
Old 10-07-2012, 16:44   #1135 (permalink)
maanarman's Avatar
Member: 686395
Sonork: 100.1608345
Thanks Meter: 3,822
CARRIES M333+ READ FLASH FORMAT
S/N: >>>>>About
Connected OK.
Definition Applied
Definition Applied
Connected to Phone.
CPU: MT6252A(6250)_S0101 Ver: CE00 md:8B00
Verifying Baud...
Set Baud:921600 OK.
Reading(Nor)...
HONGYU52_10A_GEMINI16_PCB01_GSM_MT6252_S01.C363K1_ KELS06_M333P_KELS_120510.BIN
Read OK.
File Save to: C:\Documents and Settings\Administrator\Desktop\M333+ CARRIES HONGYU52_10A_GEMINI16_PCB01_GSM_MT6252_S01.C363K1_ KELS06_M333P_KELS_120510
Definition Applied
Definition Applied
Connected to Phone.
Format Start Addr: 0x1E4000, Size: 0x1C000
Formatted OK.
Definition Applied
CPU: MT6252 Ver: CE00 SW:0101
W IMEI1 OK: 35120902560790-6
W IMEI2 OK: 35120902888816-4
NONE IMEI3
>>NONE IMEI4
Old 10-07-2012, 16:46   #1136 (permalink)
maanarman's Avatar
Member: 686395
Sonork: 100.1608345
Thanks Meter: 3,822
BUS MOBILE 1130 READ FLASH FORMAT
Old 10-07-2012, 16:48   #1137 (permalink)
maanarman's Avatar
Member: 686395
Sonork: 100.1608345
Thanks Meter: 3,822
GMOBILE J5000 DEAD MOBILE RECOVER
Old 10-07-2012, 16:50   #1138 (permalink)
maanarman's Avatar
Member: 686395
Sonork: 100.1608345
Thanks Meter: 3,822
MBD M8000 WRITE FLASH OK
Old 10-07-2012, 16:51   #1139 (permalink)
maanarman's Avatar
Member: 686395
Sonork: 100.1608345
Thanks Meter: 3,822
BIFER B30 DEAD MOBILE RECOVER
The Following User Says Thank You to maanarman For This Useful Post:
Old 10-07-2012, 16:53   #1140 (permalink)
maanarman's Avatar
Member: 686395
Sonork: 100.1608345
Thanks Meter: 3,822
J5000 COOLSAND FLASH OK
Page generated in 0.36766 seconds with 10 queries
