Old 10-24-2012, 10:28   #1321 (permalink)
maanarman's Avatar
Member: 686395
Sonork: 100.1608345
Thanks Meter: 3,822
AGTEL 1130 WRITE FLASH DONE
Old 10-24-2012, 10:29   #1322 (permalink)
maanarman's Avatar
Member: 686395
Sonork: 100.1608345
Thanks Meter: 3,822
AGTEL LUCKY READ FLASH DONE
Old 10-24-2012, 10:30   #1323 (permalink)
maanarman's Avatar
Member: 686395
Sonork: 100.1608345
Thanks Meter: 3,822
LC 3010 READ FLASH FORMAT DONE
Old 10-25-2012, 12:49   #1324 (permalink)
Member: 1745576
Thanks Meter: 12
Please Hold "ON" to connect with the phone...
Definition Applied
Abort by User
Definition Applied
Definition Applied
Connected to Phone.
CPU: MT6252A(6250)_S0101 Ver: CE00 md:8B00
Downloading Boot7 ...
Nor Flash Type: [MX] MX25U6435E
Nor Flash Code: 00C20025(00370000)
Nor Flash Size: 0x800000 Hex Bytes
Verifying Baud...
Set Baud:921600 OK.
Reading infr(Nor)...
The phone information:
TINNO52_10A_GEMINI64_PCB01_GPRS_MT6252_S01.SPICE_M 5456_IND_VER7_1.BIN_FLNMX25U6435E
the file not be encrypted
Done.
Definition Applied
CPU: MT6252 Ver: CE00 SW:0101
Test Mode, Reading Information From the Phone...
Definition Applied
Definition Applied
Connected to Phone.
Verifying Baud...
Set Baud:921600 OK.
Reading(Nor)...
Read OK.
Total time: 1 mins 38 s
File Save to: C:\Documents and Settings\hony\Desktop\spice 5455
Definition Applied
Formatting as a safe mode
LCD Data saved to C:\Program Files\Miracle Box\MT6252_LCD.dat
OK ! (items= 190)
Old 10-25-2012, 12:50   #1325 (permalink)
Member: 1745576
Thanks Meter: 12
Connected to Phone.
Nor Flash Type: [WINBOND] W25Q16CV
Nor Flash Code: 00EF0040(00150000)
Nor Flash Size: 0x200000 Hex Bytes
Verifying Baud...
Set Baud:921600 OK.
JOYTECH52_10A_GEMINI16_PCB01_GSM_MT6252_S01.GFIVE_ S2423_C4_SG_IN_C1000I_V1_0.BIN
Done.
Definition Applied
Can Not Enter TestMode
Maybe the USB power no enough
Definition Applied
Definition Applied
Connected to Phone.
Verifying Baud...
Set Baud:921600 OK.
Reading(Nor)...
Read OK.
Total time: 0 mins 24 s
File Save to: C:\Documents and Settings\hony\Desktop\JOYTECH52_10A_GEMINI16_PCB01 _GSM_MT6252_S01.GFIVE_S2423_C4_SG_IN_C1000I_V1_0.B IN
Definition Applied
can not select SafeMode,then into complete mode
Definition Applied
Definition Applied
you can Set Formatting Addr
Connected to Phone.
Formatting Nor Flash...
Format Start Addr: 0x1E4000, Size: 0x1C000
Formatted OK.
Old 10-25-2012, 12:52   #1326 (permalink)
Member: 1745576
Thanks Meter: 12
Connected to Phone.
CPU: MT6252A(6250)_S0101 Ver: CA05 md:8B00
Verifying Baud...
Set Baud:921600 OK.
Reading(Nor)...
HONGYU52_10A_GEMINI16_PCB01_GSM_MT6252_S01.A105B3_ JFY01_K1_KIMFLY_120216.BIN
Read OK.
File Save to: C:\Documents and Settings\hony\Desktop\HONGYU52_10A_GEMINI16_PCB01_ GSM_MT6252_S01.A105B3_JFY01_K1_KIMFLY_120216.BIN
Definition Applied
CPU: MT6252 Ver: CA05 SW:0101
Not OK, Close [Safe Mode], and Redo !
Definition Applied
Definition Applied
Connected to Phone.
Verifying Baud...
Set Baud:921600 OK.
Reading(Nor)...
Read OK.
Definition Applied
Definition Applied
Definition Applied
Connected to Phone.
Verifying Baud...
Set Baud:921600 OK.
Reading(Nor)...
Read OK.
Definition Applied
Definition Applied
Definition Applied
Connected to Phone.
Verifying Baud...
Set Baud:921600 OK.
Reading(Nor)...
Read OK.
Definition Applied
Connected to Phone.
Formatted OK.
if Input is space, read sn
WARNING : IMEI CHANGE IS ILLEGAL
Changing Android IMEI:
1.Turn on the phone by battery
2.Enter the menu: Set --> development --> USB debug(Activate)
3.Insert USB cable or define USB pinout, install android driver
4.Select function IMEI(switched on)
5.Input IMEI1 or IMEI2 , press START
Definition Applied
Error:R001
Definition Applied
W IMEI1 OK: 35***
W IMEI2 OK: 35********
NONE IMEI3
NONE IMEI4
Old 10-25-2012, 12:52   #1327 (permalink)
Member: 1745576
Thanks Meter: 12
MTKScaning Pinouts,Please press Power-Key...
Nothing Pinouts Scanned out
You use Latest Miracte Software 1.30
Fuzzy Logic Method is very safe and reliable !
OK. type: MTK Model:6253
Definition Applied
Connected to Phone.
CPU: MT6253_S8A00 Ver: 8A02 md:0000
Boot ERR: 1000_1941
Definition Applied
Connected to Phone.
Nor Flash Type: [INTEL] PF38F30xxM0x1xx
Nor Flash Code: 00898903
Nor Flash Size: 0x1000000 Hex Bytes
Verifying Baud...
Set Baud:921600 OK.
Reading(Nor)...
HEXING53_09A_GEMINI_PCB01_GPRS_MT6253_S00.SPICE_QT 58_IND_VER4_6.BIN_FLNPF38F3050M0Y3DH
Read OK.
Total time: 3 mins 20 s
File Save to: C:\Documents and Settings\hony\Desktop\HEXING53_09A_GEMINI_PCB01_GP RS_MT6253_S00.SPICE_QT58_IND_VER4_6.BIN_FLNPF38F30 50M0Y3DH
Definition Applied
Connected to Phone.
Verifying Baud...
Set Baud:921600 OK.
Writing(Nor)...
Write OK.
Total Time: 4 mins 6 s
Definition Applied
CPU: MT6253 Ver: 8A02 SW:8A00
W IMEI1 OK: 91**********
W IMEI2 OK: 91**********
NONE IMEI3
NONE IMEI4
Old 10-25-2012, 12:55   #1328 (permalink)
Member: 1745576
Thanks Meter: 12
Connected to Phone.
Reading(Nor)...
LEATEK52_1632_10A_PCB01_GSM_MT6252_S01.L_2476A_V1_ 18_1.BIN
Read OK.
Total time: 0 mins 6 s
Definition Applied
Waiting for USB Port...
Set port to COM10
Connected to Phone.
Formatted OK.
Definition Applied
Set port to COM10
Definition Applied
Set port to COM10
W IMEI1 OK: 35************
W IMEI2 OK: 35************
NONE IMEI3
NONE IMEI4
Old 10-25-2012, 12:57   #1329 (permalink)
Member: 1745576
Thanks Meter: 12
OK. type: MTK Model:6250
Definition Applied
Connected to Phone.
Nor Flash Type: [MX] MX25U1635E
Nor Flash Code: 00C20025(00350000)
Verifying Baud...
Set Baud:921600 OK.
Reading(Nor)...
LEATEK52_1632_10A_PCB01_GSM_MT6252_S01.L_2476A_V1_ 3_2.BIN
Read OK.
Total time: 0 mins 25 s
File Save to: C:\Documents and Settings\hony\Desktop\LEATEK52_1632_10A_PCB01_GSM_ MT6252_S01.L_2476A_V1_3_2.BIN
Definition Applied
Definition Applied
Connected to Phone.
Verifying Baud...
Set Baud:921600 OK.
Reading(Nor)...
Read OK.
File Save to: C:\Documents and Settings\hony\Desktop\LEATEK52_1632_10A_PCB01_GSM_ MT6252_S01.L_2476A_V1_3_22
Definition Applied
Definition Applied
Definition Applied
Definition Applied
The File Information:
Abort by User
HONGYU52_10A_GEMINI16_PCB01_GSM_MT6252_S01.A105A3_ KCA110_01_MUP_111222.BIN
Definition Applied
Connected to Phone.
Boot ERR: 0_0
Definition Applied
Connected to Phone.
Verifying Baud...
Set Baud:921600 OK.
Erasing...31
Writing(Nor)...
Write OK.
Total Time: 0 mins 37 s
Definition Applied
NONE IMEI3
NONE IMEI4
Old 10-25-2012, 12:58   #1330 (permalink)
Member: 1745576
Thanks Meter: 12
SPDScaning Pinouts,Need not press Power-Key...
OK. Spread
Definition Applied
Scanning USB Serial port...
SU2Serial Port: COM71
Connecting to Phone,Wait..
Done.
Infor: SPRD3
Initialize boot10...
CPU type: 6530A
Flash type: NOR
Flash ID: 00C80060(00180000)
Flash Model: GD27LQ128
Flash Size: 0x1000000(16.0M)
Being analyzed,Wait...
None IMEI
None password
Definition Applied
Done.
Infor: SPRD3
CPU type: 6530A
Flash type: NOR
reading,Wait...
Read Completed.
File save to: C:\Documents and Settings\hony\Desktop\6530A_GD27LQ128.bin
Definition Applied
Done.
Infor: SPRD3
CPU type: 6530A
Flash type: NOR
Formating...
Format Completed.
Old 10-25-2012, 12:59   #1331 (permalink)
Member: 1745576
Thanks Meter: 12
Abort by User
Definition Applied
Abort by User
Definition Applied
Definition Applied
Connected to Phone.
CPU: MT6252A(6250)_S0100 Ver: CA04 md:8B00
Verifying Baud...
Set Baud:921600 OK.
Erasing...127
Writing(Nor)...
Write OK.
Total Time: 2 mins 39 s
ZV268A48_PCB01_GPRS_MT6252_S01.SPICE_QT53_IND_V1_5 .BIN
Definition Applied
Definition Applied
Connected to Phone.
Verifying Baud...
Set Baud:921600 OK.
Erasing...127
Writing(Nor)...
Write OK.
Total Time: 2 mins 36 s
Definition Applied
Please Turn on your phone by battery before pressing START
Connectted
Changing IMEI1
WR SN ERR
NONE WRSN OK
Definition Applied
Connectted
Changing IMEI1
OK, IMEI1: 91***********
Changing IMEI2
OK, IMEI2: 91***********
Reading IMEI3
Old 10-25-2012, 13:01   #1332 (permalink)
Member: 1745576
Thanks Meter: 12
OK. Mstar MSW853X
Scaning PC port...
port:I:
Definition Applied
Abort by User
None SU2Serial Port.
Abort by User
Definition Applied
Abort by User
Abort by User
none usbport, maybe driver not installed
Definition Applied
Abort by User
Abort by User
No usbport
Definition Applied
Definition Applied
Done.
Initialize boot3...
Boot Done.
Flash type: NOR
Flash ID: 0020882E
Flash Model: NUMONYX_M58LR128KC
reading,Wait...
Read Completed.
File save to: C:\Documents and Settings\hony\Desktop\Mstar_NUMONYX_M58LR128KC000
Definition Applied
Done.
Not support Reset.
Definition Applied
Done.
Not support Reset.
Definition Applied
Not Support Auto Detec,Please Try Boot1.
Definition Applied
Definition Applied
Done.
Initialize boot3...
Boot Done.
Flash type: NOR
Flash ID: 0020882E
reading,Wait...
Read Completed.
File save to: C:\Documents and Settings\hony\Desktop\Mstar_NUMONYX_M58LR128KC2
Definition Applied
Not support Reset.
Definition Applied
Not support Reset.
Definition Applied
Done.
Initialize boot3...
Boot Done.
Flash type: NOR
Flash ID: 0020882E
Eraseing Flash...
Erase Completed.
writing,Wait...
Write Completed.
Definition Applied
Done.
Initialize boot3...
Boot Done.
Flash type: NOR
Flash ID: 0020882E
Eraseing Flash...
Erase Completed.
writing,Wait...
Write Completed.
Old 10-25-2012, 13:02   #1333 (permalink)
Member: 1745576
Thanks Meter: 12
Connected to Phone.
CPU: MT6253_S8A00 Ver: 8A04 md:0000
Nor Flash Type: [ST] M58WR064HU
Nor Flash Code: 002088C0
Verifying Baud...
Set Baud:921600 OK.
Reading(Nor)...
M5093_KDI_MAGICON_PCB01_GPRS_MT6253_S00.KACM5093_E N_HI_01_811.BIN_FLNM36W0R6050U4ZS_W0
Read OK.
Total time: 1 mins 40 s
File Save to: C:\Documents and Settings\hony\Desktop\M5093_KDI_MAGICON_PCB01_GPRS _MT6253_S00.KACM5093_EN_HI_01_811.BIN_FLNM36W0R605 0U4ZS_W0
Definition Applied
CPU: MT6253 Ver: 8A04 SW:8A00
LCD Data saved to C:\Program Files\Miracle Box\MT6253_LCD.dat
OK ! (items= 120)
Old 10-25-2012, 13:04   #1334 (permalink)
Member: 1745576
Thanks Meter: 12
Abort by User
MstarScaning Pinouts,Need not press Power-Key...
OK. Mstar MSW853X
Scaning PC port...
port:I:
Definition Applied
Done.
Initialize boot3...
Boot Done.
Flash type: NOR
Flash ID: 0020882E
reading,Wait...
Read Completed.
File save to: C:\Documents and Settings\hony\Desktop\Mstar_NUMONYX_M58LR128KC.bin
Definition Applied
Done.
Initialize boot3...
Boot Done.
Flash type: NOR
Flash ID: 0020882E
Please Select Flash file First.1995
Unlock Code: 0000
Unlock Code: 1995
Please Select Flash file First.1122
Unlock Code: 1122
Analyzed Completed.
Old 10-25-2012, 19:03   #1335 (permalink)
maanarman's Avatar
Member: 686395
Sonork: 100.1608345
Thanks Meter: 3,822
PRIDE A101 READ FLASH DONE
Page generated in 0.42938 seconds with 10 queries
