Old 06-13-2019, 10:37   #1 (permalink)
Member: 2252481
Sonork: 1660352
Thanks Meter: 206
miracle box not opening no peep sound (Replied & Closed)
server connections error check internet yet my internet ok
The Following User Says Thank You to Techsky For This Useful Post:
Old 06-13-2019, 10:48   #2 (permalink)
vishnudatt's Avatar
Member: 1306196
Sonork: 100.1654602
Thanks Meter: 1,578
Arrow
check your port driver................
The Following User Says Thank You to vishnudatt For This Useful Post:
Old 06-13-2019, 12:18   #3 (permalink)
Member: 2252481
Sonork: 1660352
Thanks Meter: 206
drivers ok bro when network error related to usb drivers ?
Old 06-13-2019, 13:52   #4 (permalink)
vishnudatt's Avatar
Member: 1306196
Sonork: 100.1654602
Thanks Meter: 1,578
Arrow
no network,
i think driver problem update your box firmware then try
Old 06-13-2019, 15:42   #5 (permalink)
Member: 2252481
Sonork: 1660352
Thanks Meter: 206
how yet i can't access setup i told its was working well before now am forced to use vpn now can be connected
Old 06-13-2019, 15:52   #6 (permalink)
Member: 2420741
Sonork: 100.1668113
Thanks Meter: 7
Same problem here bro. When i run Miracle thunder, i get the error "Server Connection Error Check Intenet!" Yet my connection to the internet is OK. This started two days ago. Also i note that the Miracle box server is not online. Any solution please?
The Following User Says Thank You to wnthiani For This Useful Post:
Old 06-13-2019, 16:18   #7 (permalink)
Member: 2420741
Sonork: 100.1668113
Thanks Meter: 7
Techsky, how do you use vpn?
Old 06-13-2019, 16:26   #8 (permalink)
Member: 2252481
Sonork: 1660352
Thanks Meter: 206
do you have skype you contact me there because miracle team are sleeping they can't help their client
Old 06-13-2019, 16:49   #9 (permalink)
Member: 2420741
Sonork: 100.1668113
Thanks Meter: 7
I wish i had skype.. I have tried a free vpn and surprisingly the miracle server site was online! Now the problem is how to make Miracle box .exe to use the vpn interface. Thanks friend for the tip anyway..
Old 06-14-2019, 06:09   #10 (permalink)
[SV]'s Avatar
Member: 1690589
Sonork: 100.1609373
Thanks Meter: 39,695
No Need any VPn for Miracle
write here info
Miracle Sn
Which Version u r using
from which country you are from
The Following User Says Thank You to [SV] For This Useful Post:
Old 06-14-2019, 06:20   #11 (permalink)
Member: 2252481
Sonork: 1660352
Thanks Meter: 206
ver2.95 from Kenya am using vpn now
The Following 2 Users Say Thank You to Techsky For This Useful Post:
Old 06-14-2019, 06:30   #12 (permalink)
Member: 2420741
Sonork: 100.1668113
Thanks Meter: 7
Bro SV, thanks for the response.. but how can we get the Serial number if the box cannot even open up? There is no serial number at the box package, and there is no serial number at the miracle key dongle. Also please note that the Miracle server is not accessible from Kenya, this is somewhere in Africa. Kindly assist...
Old 06-14-2019, 06:33   #13 (permalink)
Member: 2420741
Sonork: 100.1668113
Thanks Meter: 7
Wow Techsky, kindly your vpn browser is set to browse from which country?
Old 06-14-2019, 07:39   #14 (permalink)
Member: 2420741
Sonork: 100.1668113
Thanks Meter: 7
Which vpn are you using bro? Am trying to use Hola but it's not working yet...
Old 06-14-2019, 09:20   #15 (permalink)
Member: 2420741
Sonork: 100.1668113
Thanks Meter: 7
[QUOTE='[SV];13693636']No Need any VPn for Miracle
write here info
Miracle Sn : MBCM170819NC0714
Which Version u r using : Miracle Box
from which country you are from: Kenya
Page generated in 0.18570 seconds with 8 queries
