miracle box not opening no peep sound (Replied & Closed) server connections error check internet yet my internet ok |
check your port driver................ Quote:
no network, i think driver problem update your box firmware then try Quote:
how yet i can't access setup i told its was working well before now am forced to use vpn now can be connected |
Same problem here bro. When i run Miracle thunder, i get the error "Server Connection Error Check Intenet!" Yet my connection to the internet is OK. This started two days ago. Also i note that the Miracle box server is not online. Any solution please? |
Techsky, how do you use vpn? |
do you have skype you contact me there because miracle team are sleeping they can't help their client |
I wish i had skype.. I have tried a free vpn and surprisingly the miracle server site was online! Now the problem is how to make Miracle box .exe to use the vpn interface. Thanks friend for the tip anyway.. |
No Need any VPn for Miracle write here info Miracle Sn Which Version u r using from which country you are from |
ver2.95 from Kenya am using vpn now |
Bro SV, thanks for the response.. but how can we get the Serial number if the box cannot even open up? There is no serial number at the box package, and there is no serial number at the miracle key dongle. Also please note that the Miracle server is not accessible from Kenya, this is somewhere in Africa. Kindly assist... |
Wow Techsky, kindly your vpn browser is set to browse from which country? |
Which vpn are you using bro? Am trying to use Hola but it's not working yet... |
[QUOTE='[SV];13693636']No Need any VPn for Miracle write here info Miracle Sn : MBCM170819NC0714 Which Version u r using : Miracle Box from which country you are from: Kenya |
