Old 08-31-2017, 08:03   #241 (permalink)
SLSUTHAR's Avatar
Member: 2482480
Thanks Meter: 112
miracle box can not connect to the server
Old 08-31-2017, 08:12   #242 (permalink)
Member: 1253084
Sonork: 100.1646767
Thanks Meter: 9
Miracle Box Ver 2.54 Released Qcom power [16/08/2017]
i also face this problem miracle box can not connect to the server
Old 08-31-2017, 08:32   #243 (permalink)
Member: 1816289
Thanks Meter: 3
Why only you have problems with the software and the server ??? No one has such problems as you !!!! You always have something that does not work!
Old 08-31-2017, 08:44   #244 (permalink)
Member: 2648485
Thanks Meter: 4
server is online now enjoy the miracle
Old 08-31-2017, 09:25   #245 (permalink)
Member: 1204309
Sonork: smartcel1
Thanks Meter: 5
Originally Posted by smartcel1 View Post
again cant connect server.
pls solve this issue
problem solved. thank you team
Old 08-31-2017, 15:19   #246 (permalink)
Member: 1429214
Sonork: 786
Thanks Meter: 76
root is bigest problem dear team not supported adb with root any another mobile phones
Old 08-31-2017, 16:28   #247 (permalink)
Member: 1362565
Thanks Meter: 2
Smile problem register and update
I have miracle box and dongle, I just renew my actavtion. I download the update 2.54 I try to install and it install 2.53, I did check 100 times and download 5 times 2.54 and install but after inslall it show 2.53.
plus I am trying to register the box for me to download files and the line for country&dealer don't let me write nothing so I a blocked..???
please help...
I have this box over 1 year and did not use it so much please help
Old 08-31-2017, 18:13   #248 (permalink)
Registered User
Member: 2507333
Thanks Meter: 14
miracle not done one plus imei
Starting..
Opening Port.. COM82 (Qualcomm HS-USB Diagnostics 9025 )
Compile : Aug 21 2017 18:05:52
mei 1 Read-only Failed to Write...
Imei 1 Write Successfull...
miracle not work
Old 08-31-2017, 19:12   #249 (permalink)
Member: 2728687
Sonork: zayin yumba
whats happening with this setup?
Old 08-31-2017, 20:34   #250 (permalink)
Registered User
Member: 2507333
Thanks Meter: 14
Conncet Ok.
CPUID:0x0006B0E1
>>can not identify
Old 08-31-2017, 23:21   #251 (permalink)
Member: 2728687
Sonork: zayin yumba
anyone facing problem with v2.54 use v2.53 solved and working good
Old 09-01-2017, 18:43   #252 (permalink)
Thanks Meter: 4,071
Micromax A102 Stuck On Logo Fixed By Miracle Box
Old 09-01-2017, 18:45   #253 (permalink)
Thanks Meter: 4,071
CYYH G5 SPD 8810-8820 Pattern Lock Removed Done Without Any Risk With Miracle Box
Old 09-01-2017, 18:46   #254 (permalink)
Thanks Meter: 4,071
Lava Iris 352E Dead Recovered Done By Miracle Box
Old 09-01-2017, 18:47   #255 (permalink)
Thanks Meter: 4,071
Lava Pearl User Code Read Done Without Data Lose With Miracle Box
Page generated in 0.17319 seconds with 9 queries
