Old 07-08-2016, 18:06   #1 (permalink)
dapinderjit's Avatar
Member: 145082
Thanks Meter: 798
Thumbs up mm a114 dead how to write flash error
Welcome to use Miracle Box
(World's First Fuzzy Logic Based Tool)
Update:16-05-23
Firmware Version:1.16
Connected OK.
Fuzzy Logic Method is very safe and reliable !
License Expire Date: 2017-06-11
Check Authentication...
You use Latest Miracle Software
______________________________
Miracle Box Version 2.35-A
Release: 16th June 2016
# With Cool Sand / RDA Read/Write/IMEI.
# With SPD SC9830 New Mobile Supported.
# With Other Lots Features Added.
__________[FACEBOOK]__________
http://facebook.com/amiracleteam
___________SUPPORT]___________
http://support.amiracleteam.com
Info:
version:4.2.2
model:A114
brand:Micromax
manufacturer:Micromax
Definition Applied
1. Power Off Phone , Remove Battery, Insert Battery Back
2. Insert USB cable. In some cases Required Hold BootKey
3. Use Miracle Boot Key In cases Boot key not Find
4. Battery Should be Charged more then 50%
Waiting for USB Port...
Set MediaTek PreLoader USB VCOM (Android) (COM19)
Please Hold "ON" to connect with the phone...
Connected to Phone.
CPU: MT6582 SW:0001 Ver: CA01
Downloading Boot8 ...
EMMC Size: 0x00E7000000
Flash Type: EMMC
INT/EXT RAM Size: 0x20000/0x40000000
Writing(Nand/eMMC)...
Writing MBR
Writing EBR1
Writing UBOOT
>>Write error code: 0000
Old 07-08-2016, 21:34   #2 (permalink)
Member: 2528453
Sonork: Gsm unlock
Thanks Meter: 62
check battery charge full battery & try again.............
Page generated in 0.14797 seconds with 8 queries
