Miracle Box GSMCampus |
12-29-2018, 08:24 | #1 (permalink) |
Freak Poster Join Date: Mar 2007
Member: 459869 Status: Offline Thanks Meter: 47 | Mtk vivo & oppo unlock help (Replied & Closed) My Oppo F5 CPH1725 & Vivo 1713 v5s MTK unlock help, is there any setting or vcom, preloader & mtk driver problem? please help & advice oppo log: Code: Definition Applied 1. Power Off Phone , Remove Battery, Insert Battery Back 2. Insert USB cable. In some cases Required Hold BootKey 3. Use Miracle Boot Key In cases Boot key not Find 4. Battery Should be Charged more then 50% Definition Applied you can Set Formatting Addr Waiting for USB Port... Set Preloader And Gadget Serial (COM8) Connecting to Phone,Wait.. Connected to Phone. CPU: MT6763 SW:0001 Ver: CA01 Downloading Boot8 ... >>The Boot not support the Phone, or CPU Bad. Select other Boot. Code: Definition Applied 1. Power Off Phone , Remove Battery, Insert Battery Back 2. Insert USB cable. In some cases Required Hold BootKey 3. Use Miracle Boot Key In cases Boot key not Find 4. Battery Should be Charged more then 50% Waiting for USB Port... Set MTK USB Port (COM23) Connecting to Phone,Wait.. Connected to Phone. CPU: MT6755 SW:0001 Ver: CB00 Downloading Boot8 ... >>BootData ERR( change port set): Last edited by [SV]; 12-29-2018 at 12:34. Reason: (Replied & Closed) |
