New miracle box help After installing my new miracle box, i tried running the software but it refused to connect. Welcome to use miracle box(World's First Fuzzy Logic Based Tool) SoftWare Version 1.61 Update:13-10-10 Detection current driver version is low, you need to install the new drive. Drivers directory(..\BOX_Data\Drivers\Box Driver\xxx(1.8.0)) S/N: >>>>>About Firmware Version:1.10 Connected OK. Connecting Internet... You use Latest Miracte Software 1.61 >>Fuzzy Logic Method is very safe and reliable ! Any solution????????? Thanks in advance |
sir me miracle box user hu mere pass bahut sare mobile aaye hai rda/coolsand cpu wale lekin ek bhi mobile cholu nahi huwa jab ki mene un mobile ko format or write flash bhi karkr dekh liya hpir bhi mobile on nahi huawa agar aapke pass koi solution ho to batao |
sir mere pass miracle box hai lekin mene bahut se mobile rda/coolsand mobile sekhe hai jo format karne par chalu nahi hota or jo on hote hai vo band ho jate hai please gide me |
contact with me i try to solve prob |
chk in my profile yahoo skype and sonark id there |
After installing my new miracle box, i tried running the software but it refused to connect. Welcome to use miracle box(World's First Fuzzy Logic Based Tool) SoftWare Version 1.72 Update:14-01-07 Detection current driver version is low, you need to install the new drive. Drivers directory(..\BOX_Data\Drivers\Box Driver\xxx(1.8.0)) Firmware Version:1.10 Connected OK. Connecting Internet... network connected error >>Fuzzy Logic Method is very safe and reliable ! Any solution????????? |
first of all instal or update driver again if not work chnge drive or loctaion of set up like d or e |
yes ihave same pro. dear .... you are right help anybody |
http://www.prolific.com.tw/UserFiles...ler_v1_9_0.zip install this driver and enjoy |
i think your box is connected that error just tells you that your driver is not the latest one go to device manager update your driver browse to my computer....program files.......miracle box (..\BOX_Data\Drivers\Box Driver\xxx(1.8.0)) and your done hope it helps |
my problem is solved by the gsm srilanka thankyou very much but now icant connect to internet it says network connected error plz solve my problem sir |
that error show sometimes when internet connection is busy or signal is weak and you open miracle software but that error doesnt affect the box's performance |
thanx for your rply but each and every time when i open the software it show this message network connected error |
@ALL network conect eroor is normal, miracle old server changed, wait for new server address add for new update. dont care it and for ur job it not effect. |
