Oppo F5 MT6763 7.1.1 Reset Code & Reset FRP With Miracle Box Successfull Done. Oppo F5 MT6763 7.1.1 Reset Code & Reset FRP With Miracle Box Successfull Done. Code: Fuzzy Logic Method is very safe and reliable ! https://i.imgur.com/o7QkAa4.png AKMAL HUSSAIN.. |
sir after this mobile blinking on oppo |
sir after this mobile blinking on oppo only frp option select no pattern removed when frp & user data selected mobile goes blinking any solution please |
Go to recovery mode and do wipe data factory reset BR GSM AAKAS MIRACLE TEAM |
Frp Done Definition Applied 1. Power Off Phone , Remove Battery, Insert Battery Back 2. Insert USB cable. In some cases Required Hold BootKey 3. Use Miracle Boot Key In cases Boot key not Find 4. Battery Should be Charged more then 50% Definition Applied you can Set Formatting Addr Waiting for USB Port... Set MediaTek USB Port (COM296) Connecting to Phone,Wait.. Connected to Phone. CPU: MT6763 SW:0001 Ver: CA01 Downloading Boot8 ... EMMC Size: 0x0747C00000 Flash Type: EMMC INT/EXT RAM Size: 0x40000/0xC0000000 Formatting Nand Flash... Format Satrt Addr£؛0x5A88000, Size: 0x100000 Format Satrt Addr£؛0x195100000, Size: 0x5B1AFBE00 >>Format nand OK(Android Need to wait a few minutes the phone is switched) |
whats the key to do frp vol+ or vol- plz tell me sugession |
