Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > HUA Team Products > HUA GOLD Old
HUA GOLD Old BY HUA TEAM
Old 04-07-2013, 21:19   #46 (permalink)
Asansam dongle's Avatar
Member: 1707100
Sonork: 100.1590245
Thanks Meter: 13,598
http://forum.gsmhosting.com/vbb/f716...ansam-1406440/
Old 04-09-2013, 18:05   #47 (permalink)
dr_moosavi's Avatar
Member: 814775
Sonork: 100.1587334
Thanks Meter: 972
How to work Go file support button?
Old 04-11-2013, 08:13   #48 (permalink)
dr_moosavi's Avatar
Member: 814775
Sonork: 100.1587334
Thanks Meter: 972
How To imei repair galaxy S III i9300?
Old 09-14-2013, 17:28   #49 (permalink)
dr_moosavi's Avatar
Member: 814775
Sonork: 100.1587334
Thanks Meter: 972
Read here before use No Network one click Button
This method working for Countries without imei policy and phones that show no register to network after repair imei and super imei or special imei.please dont send any replay post about not working or still no network(you Country have imei policy and post deleted without answer).
send name country in Private Messages for asansam box only
http://forum.gsmhosting.com/vbb/member.php?u=1911891
Please dont test in Countries have imei policy same turkey or dubai or United kingdom.We have working on this countries and fix soon for this users.
How to repair no network?
-Open asansam
-Select model via type
-Goto android service
-Select repair no network in misc.job
-select usb cable to phone and wait 20 sec(need root)
-select interface port in setting
-Press do it button
-Wait for finish step1
-Connect uart cable to phone now(rj45 s7070)
-Wait for finish step2
-done and repaired successfully
http://forum.gsmhosting.com/vbb/f716...ution-1712069/
http://forum.gsmhosting.com/vbb/f716...m-box-1712364/
http://forum.gsmhosting.com/vbb/f716...fully-1712366/
How to repair no network s4 via usb?
-Open asansam
-select modem port in setting
-Press do it button
-Wait for reset phone and finish step2
How to Reset Pattern without usb debugging?
-Open asansam
-Select Remove pattern w/o ud
-insert usb to phone
-press do it
-done and Now Draw Any pattern you Want to Enter Phone Menu
http://forum.gsmhosting.com/vbb/f716...7/#post9726046
How to Remove password without usb debugging?
-Open asansam
-Select Remove password w/o ud
-press do it
-done and Now Enter Any password to enter Menu
http://forum.gsmhosting.com/vbb/f716...4/#post9726040
How to Remove pin code without usb debugging?
-Open asansam
-Select Remove pin w/o ud
-press do it
-done and Now Enter Any PIN Code to enter Menu
http://forum.gsmhosting.com/vbb/f716...5/#post9726043
The Following User Says Thank You to dr_moosavi For This Useful Post:
Old 10-12-2013, 00:39   #50 (permalink)
Asansam Box's Avatar
Member: 1911891
Thanks Meter: 6,241
HOW TO START IN SAFE MODE ON SAMSUNG GALAXY ACE
When you first have your device you may have installed a lot of the apps to test them out and see which one you like and which one you don't. On occassion you may face a bad app that has bug in it and it can cause your phone's operating system to misbehave it self. If you phone is not working properly you could go into safe mode and remove those of*****ng app. Here's how:
1. Switch off the phone by pressing on the Power button.
2. Then turn the phone back on, while it is turning on press and hold the Menu button.
3. Now continue to hold the Menu button until you see the Home screen. On the home screen you see it say Safe Mode on the left hand corner.
4. Now that you are in Safe Mode you can go and remove any buggy apps that you don't want to keep.
When you are done in Safe Mode, you can get out of it by pulling out the battery, wait for one minute and the put it back in. Boot your phone up normally and you will be in the standard usable mode.
HOW TO EXIT SAFE MODE ON SAMSUNG GALAXY ACE
When your mobile device is having trouble sometimes it can force itself into safe mode so that you could continue to run your phone and fix the problem app that the cause the phone to crash. But when you are done how do you get out of Safe Mode? Here's how:
1. Turn off the phone by pressing the Power button.
2. Then pull out the battery. Wait for 30 seconds.
3. Now put the battery back in.
4. Start up the device and see if the Safe Mode on the left hand corner has disappear. If it's not there then you have successfully started your phone in the standard mode.
Old 11-29-2013, 10:10   #51 (permalink)
Member: 1911891
Thanks Meter: 6,241
How to select model on asansam box?
Video
Old 11-29-2013, 10:16   #52 (permalink)
Member: 1911891
Thanks Meter: 6,241
How to select port(step2 in unlock and imei operation) on asansam box?
Video
Old 11-29-2013, 10:21   #53 (permalink)
Member: 1911891
Thanks Meter: 6,241
How to select tab on asansam box?
video
Old 11-29-2013, 10:28   #54 (permalink)
Member: 1911891
Thanks Meter: 6,241
How to use go support file button on asansam box?
video
Old 11-29-2013, 10:34   #55 (permalink)
Member: 1911891
Thanks Meter: 6,241
How to remove safe mode with asansam box?
video
Old 12-03-2013, 08:27   #56 (permalink)
dr_moosavi's Avatar
Member: 814775
Sonork: 100.1587334
Thanks Meter: 972
Please read this post before use imei repair button(pit models)
what is pit models?
GALAXY S1/S2/S3/S4/NOTE/NOTE2/S PLUS/
-Select model
-Select interface port in select port setting
-enable 1 in asansam setting
-Goto general service
-Insert imei in IMEI1
-Press repair imei button
-insert usb cable to phone
-wait for step1 operation
-Remove usb and insert uart cable to phone(step2)
-wait for step2 operation
-Repair successfully
read here carefully::::
mbc cable(red or blue or black) is for enter to download mode only(gift cable)
please dont use for imei repair and make a new post about not work not connection !!!!
you cannot use uart cable and imei repair when modem is damaged(imei is null/unknown baseband/phone version unknown)
dont try again via asansam box or any samsung box and make a new post about imei not repaired no success or have bug :-)
imei repair operation for pit models need root and enable usb debugging and you cannot use without root (dont try again please)
Old 12-20-2013, 22:39   #57 (permalink)
dr_moosavi's Avatar
Member: 814775
Sonork: 100.1587334
Thanks Meter: 972
What Is "KNOK"?
What Is "KNOK"?
KNOX provides a "private space" on a KNOX equipped mobile device where the
customer can store pictures, applications etc.
It will allow only the authorized user (i.e. the customer) to access the KNOX area on
the device as a password is required to access the KNOX area on the device.
To protect the information held within the KNOX area, if the device is rooted, the
device will set its KNOX status, called "KNOX WARRANTY VOID", to 0x1 and disable
KNOX permanently so that nobody can access to the space anymore.
It is not possible to "reset" or "reactivate" KNOX when the "KNOX WARRANTY VOID"
bit is set to 0x1. When the device has been rooted, only by replacing the PBA (as an
Out-Of-Warranty repair action) can the customer be able to use KNOX feature..
how to check KNOX WARRANTY VOID status
1) Enter Download Mode on the device.
- Press Volume down key + Home key + Power key to enter Download Mode.
- Press Volume up key to enter Odin mode.
2) Check KNOX WARRANTY VOID.
- If KNOX WARRANTY VOID is 0x1, It means the phone has been rooted and
KNOX has been "disabled".
Once it is set, it is not possible to rest the status to 0x0 and if the device were to be
returned to the customer with the "original" rooted board then the customer would not
be able to use KNOX.
If the device KNOX WARRANTY VOID status is set to 0x1, then the PBA
replacement of the device is an OUT OF WARRANTY repair.
Dont Killed Your Phone
From Jellybean 4.3, it is not possible to downgrade the Android OS version Otherwise Your Phone Will Be DEAD Or Hang Samsung logo.
ASANSAM working to fix the KNOX problem
Soon ...
The Following 3 Users Say Thank You to dr_moosavi For This Useful Post:
Old 03-06-2014, 13:12   #59 (permalink)
dr_moosavi's Avatar
Member: 814775
Sonork: 100.1587334
Thanks Meter: 972
how to flash pit models with asansam version 2.4.7?
Full flash:
Select model
Select pit file
select boot file
select pda or code file
select modem or phone file
select csc file
enable repartition
enable boot update
insert usb to phone(download mode)
press flash button
Flash:
select model
select tar or tar.md5 or md5 file in pda
press flash button
2014/03/04 - 15:15:31 : Searching For Phone [SAMSUNG USB PORT]... OK
2014/03/04 - 15:15:31 : Phone Found on COM37
2014/03/04 - 15:15:31 : Initialize Phone ... OK
2014/03/04 - 15:15:31 : Prepairing... OK
2014/03/04 - 15:15:32 : Setting Pit File... OK -> 0x6500000000000000
2014/03/04 - 15:15:32 : Reading PIT Data ...OK
2014/03/04 - 15:15:32 : Phone Pit File Saved in : 'C:\ASANSAM2\BACKUP\PIT_WHILE_FLASH\I8262_20140304 151532.pit'
2014/03/04 - 15:15:32 : Analizing PIT Entries... OK
2014/03/04 - 15:15:32 : Pit Entry Num: 28
2014/03/04 - 15:15:32 : Uploading BOOT Area
2014/03/04 - 15:15:35 : ----> Uploading File 'oemsbl' As Partition 'OEMSBL'... OK
2014/03/04 - 15:15:37 : ----> Uploading File 'appsbl' As Partition 'APPSBL'... OK
2014/03/04 - 15:15:39 : ----> Uploading File 'qcsbl.mbn' As Partition 'QCSBL'... OK
2014/03/04 - 15:15:40 : ----> Uploading File 'qcsblhd_cfgdata.mbn' As Partition 'CFG_DATA'... OK
2014/03/04 - 15:15:40 : Uploading PDA Area
2014/03/04 - 15:15:42 : ----> Uploading File 'oemsbl' As Partition 'OEMSBL'... OK
2014/03/04 - 15:15:44 : ----> Uploading File 'appsbl' As Partition 'APPSBL'... OK
2014/03/04 - 15:15:46 : ----> Uploading File 'qcsbl.mbn' As Partition 'QCSBL'... OK
2014/03/04 - 15:15:47 : ----> Uploading File 'qcsblhd_cfgdata.mbn' As Partition 'CFG_DATA'... OK
2014/03/04 - 15:16:04 : ----> Uploading File 'boot.img' As Partition 'APPS'... OK
2014/03/04 - 15:16:23 : ----> Uploading File 'recovery.img' As Partition 'RECOVERY'... OK
2014/03/04 - 15:37:09 : ----> Uploading File 'system.img.ext4' As Partition 'SYSTEM'... OK
2014/03/04 - 15:37:38 : ----> Uploading File 'userdata.img.ext4' As Partition 'USERDATA'... OK
2014/03/04 - 15:37:44 : ----> Uploading File 'persist.img.ext4' As Partition 'PERSIST'... OK
2014/03/04 - 15:37:44 : Uploading PHONE Area
2014/03/04 - 15:38:46 : ----> Uploading File 'fat.bin' As Partition 'FAT'... OK
2014/03/04 - 15:38:46 : Uploading CSC Area
2014/03/04 - 15:40:39 : ----> Uploading File 'cache.img.ext4' As Partition 'CACHE'... OK
2014/03/04 - 15:41:36 : ----> Uploading File 'hidden.img.ext4' As Partition 'HIDDEN'... OK
2014/03/04 - 15:41:36 : Resetting... OK
2014/03/04 - 15:41:36 : Operation Completed
2014/03/04 - 15:41:36 : Operation Time: 00:26:08
Old 03-06-2014, 13:12   #60 (permalink)
dr_moosavi's Avatar
Member: 814775
Sonork: 100.1587334
Thanks Meter: 972
Full flash:
Select model
Select pit file
select boot file
select csc file
enable repartition
enable boot update
press flash button
Flash:
select model
press flash button
Phone Stuff for FREE & KEy-GEn For Logo Editor ! BoNtEk - ThA WtC MeMbA Nokia Multimedia 8 10-31-2012 20:17
Unlock Manual! MrProdent Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-12-2004 09:13
About 5110 & Winlock GByte9 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 11-08-1999 03:54
Nokia 5110 & 6110 Schemics MyKy Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 08-06-1999 08:36
Upload & Download Eprom Lousangeles Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 06-24-1999 05:45
Page generated in 0.25431 seconds with 9 queries
