What is phone problem??why use write cert? |
Share full report here please |
2015/01/03 - 13:06:30 : Prepairing ...OK 2015/01/03 - 13:06:30 : Device Found! 2015/01/03 - 13:06:30 : Reading Phone Informations ... 2015/01/03 - 13:06:30 : 2015/01/03 - 13:06:30 : Model : SM-G900V 2015/01/03 - 13:06:31 : Android Version : 4.4.4 2015/01/03 - 13:06:31 : PDA Version : G900VVRU1ANI2 2015/01/03 - 13:06:31 : CS Version : G900VVZW1ANI2 2015/01/03 - 13:06:31 : Phone Version : G900VVRU1ANI2 2015/01/03 - 13:06:31 : IMEI : 2015/01/03 - 13:06:31 : S/N : 00000000000 2015/01/03 - 13:06:32 : Checking Root ...OK 2015/01/03 - 13:06:32 : Phone Root OK. Continue.. 2015/01/03 - 13:06:32 : Prepairing... OK 2015/01/03 - 13:06:35 : Writing Certificate... OK 2015/01/03 - 13:06:37 : Rebooting... OK! 2015/01/03 - 13:06:37 : 2015/01/03 - 13:06:37 : Operation Time: 00:00:13 2015/01/03 - 13:07:19 : Certificate Parameteres Retrived. 2015/01/03 - 13:07:19 : Writing Certificate Procedure Started. 2015/01/03 - 13:07:19 : -------------------------------------------------------------------------------------- 2015/01/03 - 13:07:19 : 1- Turn-on the Phone Goto 'General > About' Tap 7 times on Build Number' 2015/01/03 - 13:07:19 : 2- Return to General Tab Tap on Developer Options 2015/01/03 - 13:07:19 : 3- And Check 'Usb Debugging' ON 2015/01/03 - 13:07:19 : 4- Dial *#0808# in USBSetting Window Select 'DM+MODEM+ADB' 2015/01/03 - 13:07:19 : 5- Tap on Reboot When Phone Load Complete Connect Usb Cable To Phone 2015/01/03 - 13:07:19 : 6- (Install All Needed Driver) 2015/01/03 - 13:07:19 : -------------------------------------------------------------------------------------- 2015/01/03 - 13:07:24 : Prepairing ...OK 2015/01/03 - 13:07:24 : Device Found! 2015/01/03 - 13:07:24 : Reading Phone Informations ... 2015/01/03 - 13:07:24 : 2015/01/03 - 13:07:25 : Model : SM-G900V 2015/01/03 - 13:07:25 : Android Version : 4.4.4 2015/01/03 - 13:07:25 : PDA Version : G900VVRU1ANI2 2015/01/03 - 13:07:25 : CS Version : G900VVZW1ANI2 2015/01/03 - 13:07:25 : Phone Version : G900VVRU1ANI2 2015/01/03 - 13:07:25 : IMEI : 2015/01/03 - 13:07:25 : S/N : 00000000000 2015/01/03 - 13:07:26 : Checking Root ...OK 2015/01/03 - 13:07:26 : Phone Root OK. Continue.. 2015/01/03 - 13:07:26 : Prepairing... OK 2015/01/03 - 13:07:30 : Writing Certificate... OK 2015/01/03 - 13:07:31 : Rebooting... OK! 2015/01/03 - 13:07:31 : 2015/01/03 - 13:07:31 : Operation Time: 00:00:13 After writing certificate still no IMEI |
You cannot repair unkonw baseband with cert :-) |
Use wipe fs and share report here if imei is 01 |
N900V, N900P sulation Imei Repair and Unlock i got the sulotion for the N900V, N900p Cert Repair if i can get N910U Cert i will post the Cert file for the N900V and the steps by step how to do it it thank You |
you cannot write cert on unknown baseband phone write cert done :-) Quote:
i9515 after unlock no imei no networck i9515 cert pease after unlock no imei no networck |
